Question about Honeywell 3820 Wireless Handheld Barcode Scanner
My Panther will not scan and has been charged up.
My Follett Panther is charged. I can type in the barcode number but it will not scan.
2 Suggested Answers
issken
  • 1472 Answers
SOURCE: My 3820 will no longer
srodgers609
One of the problems I had with my scanner is that the USB port that I had the scanner in when bad. My scanner cable was a little short and it put extra pressure on the port. After time some of the connections in the port broke. To fix the problem I had to replace the USB card in the system.
So I would recommend that you tryu the scanner on another computer and/or another USB controller to see if it works properly. If it does you know that it is the USB port. If it does not then I would look at the cable of the scanner.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Aug 25, 2011
Follett dolphin phd
So, I had a large scan.log file which I would have lost if I followed the instructions above. Instead hold the shift, on scan and bksp buttons simultaneously. The device will reboot with your file still functional!
Aug 27, 2013 | Computers & Internet
Help recognizing a type of UPC-A barcode
Hi, the easiest way to figure out the barcode type is to scan it with a reader...Then you could choose the barcode control or font to create the barcode yourself.
May 29, 2012 | Computers & Internet
My 3820 will no longer scan Follett barcodes. It makes several error beeps every time I try to scan anything
srodgers609
Issken
Aug 25, 2011 | Honeywell 3820 Wireless Handheld Barcode...
MC70 Scanner does not fire the scan ray every time the button is depressed. Also not scanning when it does fire.
If you are using Datawedge as your scanning applicaiton then the scanning varies depending on teh setting and what type of barcoeds you want to read. Contact me www.datexcorp.com and we can walk you through it at no charge
Mar 17, 2010 | Symbol MC70 Barcode Scanner
Laser not working, screen won't show, beeps continuously.
i think i can help u with this, if u unscrew the unit and carefully unhook ur the cables in side then will see two Philips screws, unscrew them and unhook the display cable its on the side
now gently try to take the board out and put it back on then hook the display cable back and screw the board back and for the scanning
unhook and re hook ur scan cable that will make it work,i hope that will solve ur problem
Jun 11, 2009 | HHP Dolphin 9550 Barcode Scanner
The laser is not working on my Follett PHD- Dolphin scanner
You need to do a system hardware reset. Do this by remove battery and find small pin hole just below the battery terminal single pin side. It may be covered over by black sticky pad. Get paper clip wire and put through hole to you feel small click. Hold down for 10 sec and then put battery back in to see the unit run a rebooting procress.
Hope this fix it
Jun 09, 2009 | Computers & Internet
Scanner shows number but won't scan to computer
If you're sure that the barcode is correct then ignore the following.
Otherwise, download a free barcode font and install.
1. Open up wordpad .. and type any number say "12345", and then convert it by choosing the barcode font.
2. Print out the barcode (usually at least 26pt)
3. Leave wordpad as the active window and scan the barcode
4. "12345" should be inserted into the wordpad document.
Now you know that it works.
This should work on the default setting of most scanners.
Mar 21, 2009 | Computers & Internet
TK-1000
Here at Legacy Global we can help you. Call Diana at 1-847-750-9231.
Aug 27, 2008 | Computers & Internet
Zebra Z4m Barcode printer
That using these symbols. Select a better code 128A or B.
Aug 18, 2008 | Toshiba TEC BSX5 Thermal Label Printer
Scan badge number on Blackberry Rim 857 wiht apriva
I have the same setup, I pushed in (to the left), the wheel thing or the one below, and it gave me a prompt to type in the badge number, I typed 1 and pushed in the wheel thing to enter it and I got to the main screen (with Aprivamessenger (the smiley face), Messages (the envelopes icon) and so on. I know NOTHING about this system. I bought it hoping to scan barcodes for my library.
I hope that this gets you further along
J.
Feb 16, 2008 | Apriva (B5700E)
Honeywell 3820 Wireless Handheld Barcode Scanner Logo
75 people viewed this question
Top Honeywell Computers & Internet Experts
Les Morrison
Les Morrison
k24674
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
