Question about General Electric GE 7 0 Cu Ft Super Capacity Electric Dryer - DCVH680EJ / DCVH680EJMR - colo
GE dryer turns on but doesn't spin
The drum is not spinning but the dryer turns on and sounds like the motor is running.
  • General Master
  • 8,220 Answers
Probably nothing but a broken belt. Ge dryers can be tricky. Most of them cannot be accessed from the rear anymore. Lots of videos on youtube now that show how to replace a dryer belt on a GE dryer.
Posted on Mar 20, 2014
Dryer drum doesn't spin
If the motor runs and the drum doesn't turn then most likely the belt is broken.
Oct 23, 2012 | GE DBVH512EFWW Dryer
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
When i tried to turn on the dryer, i get a humming / buzzing sound and the drum / motor doesn't spin anymore
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 07, 2011 | GE DWSR463EG Electric Dryer
Those symptons (humming/buzzing ¬ starting) are 99 out of a 100 times a sign of a motor that has locked up.
Gene
Aug 07, 2011 | GE Dryers
The dryer is plugged in and the circuts seem to work however the dryer is making a humming noise but it will not turn on fully.
what do you mean it won't fully turn on?do you mean the motor won't run because usually when it humms you either have a bad motor or something is jammed and stopped the motor from spinning.try this,open the door,with one hand hold the door switch in and with the other hand spin the drum,have someone else push the start button while you do this,if it starts the motor is bad,if you can't spin the drum something could be stuck in the blower wheel or the belt broke and could of jammed up the motor but it sounds like you have a bad motor.let me know what you find and next time send the brand name and model number.
May 04, 2011 | Dryers
When I went to turn on my dryer, I rotated the switch to turn it on. However, it makes the normal sound but the drum is not spinning and the dryer will not stay on. When I rotate the on switch and I let...
It sounds like the drum bearing is bad. It can prevent the drum from turning and overheat the motor and cause it to shut off.
Another possibility is that the belt has broken and the motor is just spininig. Some dryers have a safety that prevents the dryer from staying on it the drum is not turning.
Apr 08, 2011 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
My brand new GE profile frontloader dryer quit spinning. Still blows and I can hear the motor. Other than that no odd sounds and the drum spins manually without resistance. Model DPVH890EJMG How do I fix...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 16, 2010 | GE Dryers
Ge electric harmony dryer fan motor not turning just moves side to side 1/4 of an inch back and forth . fan freeweels free, if i spin it buy hand.
with belt off see if motor free spins .the blower wheel should not free spin with the belt on and entire drum will turn with it otherwise you could have a bad motor and a blower wheel
Jan 24, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
General Electric GE 7 0 Cu Ft Super Capacity Electric Dryer - DCVH680EJ / DCVH680EJMR - colo Logo
262 people viewed this question
Top General Dryers Experts
Tim Whalen
Sal DeAngelo
Are you a General Dryer Expert? Answer questions, earn points and help others
