Question about Mtd Garden
How to tension belt - Mtd Garden
    Sergeant:
    Champion:
  • 266 Answers
Usually the belts are under spring tension...but here are the replacments in case yours has stretched
http://www.ereplacementparts.com/mtd-belts-ps-20039-13.html
Posted on Mar 20, 2014
Serpentine belt
BELT ROUTING DIAGRAM 1997 Mercury Sable 3.0L SFI 6cyl The Belt Routing Diagram
Fig. Fig. 16: Rotate the belt tensioner and...
Fig. Fig. 17: ... remove the belt from around one of the pulleys to remove the belt
WARNING Use caution when removing or installing the belt and make sure the tool does not slip from the drive belt tensioner or personal injury or damage to the belt tensioner and the belt may occur.
  1. Attach a 15mm socket or wrench to the bolt attaching the tensioner pulley.
  2. On all 3.0L (OHV) engines, rotate the drive belt tensioner clockwise to relieve belt tension and slide the belt off the pulleys.
  3. On 3.0L (DOHC) engines, rotate the tensioner counterclockwise to relieve belt tension and slide the belt off the pulleys.
To install:
  1. Install the drive belt on all the pulleys except the tensioner pulley.
  2. Rotate the belt tensioner as outlined in the removal procedure to relieve belt tension and install the belt onto the tensioner pulley. Make sure the V-grooves make proper contact with the pulleys. Make sure the spring keeper releases or improper belt tension will occur.
Aug 05, 2012 | 1997 Mercury Sable
1997 Jeep cherokee larado squeals replaced the drive belt a few times and it keeps tearing
Inspect the belt tensioner for the following conditions:
Noise
  • If the belt squeals, the tensioner force may be insufficient. Check the belt length gauge, if the length is correct, replace the tensioner.
  • If the tensioner clatters or rattles during engine operation, there may be internal interference or wear. Replace the tensioner.
  • If the belt chirps, you may have a worn pulley or tensioner or cracks in the tensioner bas or arm. Check the mounting bolts, if they are okay, replace the tensioner.
Sticking or Seized Tensioner or Idler
  • If the tensioner does not operate smoothly or doesn't move, you may have: internal thrust surface damage/wear, internal damage/wear, or a broken spring, replace the tensioner.
Appearance
  • Inspect the tensioner arm for cracks or other damage. If the tensioner is broken, it should be replaced.
  • Look for excessive tensioner movement at idle, which can indicate internal wear, an out-of-round pulley or loose mounting bolts. Check the mounting bolts, it they are in good condition, replace the tensioner.
  • Make sure the tensioner is not tilted or misaligned. Also make sure a gap exists between the tensioner arm and base. If you notice a problem, check the mounting surface, it the surface is okay, replace the tensioner.
Belt Tracking
  • If the belt does not track properly on the pulley tracking surface, you'll need to troubleshoot the problem. Check the mounting bolts and the system alignment. Then, make sure the correct belt is being used for the vehicle. If all of these things are intact, replace the tensioner.
Belt Length Indicator
  • A belt length indicator is built into each tensioner.
  • The gauge identifies the effective operating range of the tensioner.
  • It consists of a pointer and either two or three length marks.
    • On a three-mark gauge minimum belt length, maximum belt length and ideal belt length are indicated.
    • On a two-mark gauge only minimum belt length and maximum belt length are indicated.
    • Ideal belt length on a two-mark gauge is generally half way between the minimum and the maximum.
  • When a belt wears and stretches with age the tensioner will move towards the maximum belt length to maintain proper tension.
  • As the pointer nears the maximum length mark, replace the belt.
May 04, 2012 | 1996 Jeep Grand Cherokee
I need to replace the belt tensioner on a 2000 Chysler Caravan with a 3.0L engine, with a/c. I would appreciation a diagram for properly installing the serpentine belt, and some instructions on how to...
Hi, I have pasted the procedure for belt replacement below. To replace the tensioner as well, first take the belt off. Then remove the pulley from the tensioner. This will expose the single bolt that holds the tensioner on. Replace the tensioner and then the pulley (if replacing all). Then reinstall the belt.
Alternator/Power Steering Pump Belt
The alternator/power steering pump belt is provided with a dynamic tensioner to maintain proper belt tension.
  1. Disconnect the negative battery cable.
  2. Raise the front of the vehicle and safely support it with jackstands.
  3. Remove the right front splash shield.
  4. Release tension by rotating the tensioner clockwise (use a box-end wrench on the tensioner bolt shown in the picture.
  5. Remove the belt and install a replacement.
  6. Proper belt tension is maintain by the dynamic tension.
  7. Install the right front splash shield. Lower the front of the vehicle.
  8. Connect the negative battery cable.
    Fig. Alternator/power steering pump belt tensioner bolt location
Aug 13, 2011 | 1996 Dodge Caravan
Replace serpentine belt
Removal & Installation
  1. Rotate the drive belt tensioner clockwise and remove the drive belt.
    WARNING Never suddenly let go of the tensioned idler pulley. The force of the spring pressure suddenly released may damage the idler pulley mechanism. Always release the spring pressure gradually.
    Fig. Rotate the belt tensioner to relieve tension on the belt-4.6L engine shown, others similar
To install:
  1. Route the belt over the pulleys making sure all the grooves in the pulleys and the belt line up correctly. Refer to the accessory belt routing section of this manual.
  2. Rotate belt tensioner clockwise and slip drive belt over idler pulley on tensioner.
To install:
  1. Route the belt over the pulleys making sure all the grooves in the pulleys and the belt line up correctly. Refer to the accessory belt routing diagrams above.
If for any reason, the tensioner is crooked, replace it!!! Also, install the belt with the writing facing you like you are trying to read a book. This WILL (a trick I learned at Mercedes) prevent even a new belt from squeeling!!
Dec 16, 2010 | 2003 Ford Explorer
How do i loosen the auto tensioner on my 02 civic si
2002 Honda Civic SI 2.0L MFI VTEC DOHC 4cyl
  1. Place a long-handled, boxed-end wrench or a belt tension release tool (A) on the drive belt auto-tensioner from above the engine. Slowly turn the wrench in the direction shown to release the tension, then remove the drive belt.
    WARNING This is a hydraulic type auto-tensioner; you must turn the wrench slowly.
  2. Install the new belt in the reverse order of removal.
Fig. Removing the serpentine belt-2006 Civic with 2.0L engine shown
Fig. Move the auto tensioner (A) to remove the serpentine belt (B)-S2000
Fig. Move the auto-tensioner (A) using the belt tension release tool to relieve tension from the drive belt (B), and remove the drive belt-Accord with 2.4L engine
Fig. Move the auto-tensioner (A) using the belt tension release tool to relieve tension from the drive belt (B), then remove the drive belt-Accord with 3.0L engine
I hope helps with this. Good luck.
Dec 29, 2009 | 2002 Honda Civic
How do i loosen the belt to get the alternater off
.whtbtnshow{font-family:;font-size:10pt;font-style:;font-weight:;text-decoration:;color:;}
Accessory Drive Belt Tensioner
Removal & Installation To Remove:
  1. Rotate the accessory drive belt tensioner clockwise.
  2. Remove the accessory drive belt.
  3. Remove the accessory drive belt tensioner bolts.
  4. Remove the accessory drive belt tensioner.
To Install:
  1. Install the accessory drive belt tensioner.
  2. Install the accessory drive belt tensioner bolts. Tighten to 18 ft-lb (25 Nm).
  3. Install the accessory drive belt.
  4. Rotate the accessory drive belt tensioner counterclockwise.
Oct 26, 2009 | 1998 Lincoln Navigator
Serpintine belt replacepent
Installation > 5.9L Diesel Engine 5.9L Diesel Engine
WARNING Do not attempt to check belt tension with a belt tension gauge on vehicles equipped with an automatic belt tensioner.
Drive belts on diesel engines are equipped with a spring loaded automatic belt tensioner. This belt tensioner will be used on all belt configurations, such as with or without air conditioning.
  1. Depending on the year of the vehicle, a 3/8 inch or 1/2 inch square hole is provided in the automatic belt tensioner. Attach a 3/8 inch or 1/2 inch drive-long handle ratchet to this hole.
  2. Rotate ratchet and tensioner assembly clockwise (as viewed from front) until tension has been relieved from belt.
  3. Remove belt from water pump pulley first.
  4. Remove belt from vehicle.
To install:
WARNING When installing the accessory drive belt, the belt must be routed correctly. If not, engine may overheat due to water pump rotating in wrong direction. The correct belt with correct length must be used. Position drive belt over all pulleys except water pump pulley.
  1. Attach a 1/2 inch ratchet to tensioner.
  2. Rotate ratchet and belt tensioner clockwise. Place belt over water pump pulley. Let tensioner rotate back into place. Remove ratchet. Be sure belt is properly seated on all pulleys.
Oct 09, 2009 | 2001 Dodge Ram 2500 Truck
How to change serpentine belt, 2004 Toyota Tundra
locate tensioner pulley; release tension from belt; remove belt; make sure not to forget how the belt is routed; route belt around all pulleys but tensioner; put tension on tensioner pulley; route belt over tensioner pulley
Oct 03, 2009 | 2004 Toyota Tundra
Cant find 97 ford taurus serpentine belt diagram
Drive Belt Replacement ani_caut.gif WARNING: IF EQUIPPED, DO NOT ALLOW DRIVE BELT TENSIONER (6B209) TO SNAP BACK AS DAMAGE TO DRIVE BELT TENSIONER OR PERSONAL INJURY COULD RESULT.
NOTE: Minor cracks in the V-grooved portion of the serpentine drive belt (8620) are considered normal and acceptable. If the drive belt has chunks missing from the ribs, the drive belt should be replaced.
NOTE: Conditions requiring drive belt replacement are excessive wear, rib chunk-out, severe glazing, frayed cords or other conditions. Replace any drive belt exhibiting any of these conditions.
NOTE: When installing drive belt on pulley, make sure that all V-grooves make proper contact with pulleys.
Drive Belt, Serpentine—Except SHO
Removal
  1. ani_caut.gif WARNING: USE CAUTION WHEN REMOVING OR INSTALLING DRIVE BELT TO MAKE SURE THAT TOOL DOES NOT SLIP FROM DRIVE BELT TENSIONER OR PERSONAL INJURY AND/OR DAMAGE TO DRIVE BELT TENSIONER AND DRIVE BELT MAY OCCUR.
    Using a 15 mm socket or wrench on bolt attaching drive belt tensioner pulley, rotate drive belt tensioner clockwise on 3.0L (2V) and 3.0L (2V) FF, rotate the drive belt tensioner counter clockwise on 3.0L (4V) to remove drive belt from pulleys. Make sure spring keeper engages into slot.
    Drive Belt Tensioner—3.0L (4V)
Installation
  1. Install drive belt over all pulleys (except drive belt tensioner).
  1. Rotate drive belt tensioner as described under the removal procedure and install drive belt over drive belt tensioner pulley. Make sure that all V-grooves make proper contact with pulleys. Make sure spring keeper releases or improper belt tension will occur.
    Pulley, Routing—Accessory Drive Belt 3.0L (2V)/3.0L (2V) FF Engine
    Item Part Number Description 1 10300 Generator 2 6C348 Idler Pulley 3 3A674 Power Steering Pump 4 19703 A/C Compressor 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 8501 Water Pump 8 8620 Drive Belt
    Pulley, Routing—Accessory Drive Belt 3.0L (4V)
    Item Part Number Description 1 3A674 Power Steering Pump 2 8501 Water Pump 3 19703 A/C Compressor 4 8620 Drive Belt 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 10300 Generator
3.4L SHO Engine
Removal
  1. Remove the right front wheel and tire assembly. For additional information, refer to Section 04-04.
  1. Remove the inner fender splash shield.
  1. Remove the alternator shield.
  1. ani_caut.gif WARNING: USE CAUTION WHEN REMOVING OR INSTALLING DRIVE BELT TO MAKE SURE WRENCH DOES NOT SLIP FROMDRIVE BELT TENSIONER OR POSSIBLE PERSONAL INJURY AND/OR DAMAGE TO DRIVE BELT TENSIONER AND DRIVE BELT MAY OCCUR.
    Using a 3/8 inch ratchet on the lifting lug, rotate drive belt tensioner counterclockwise (upward) and engage spring keeper. Remove drive belt from drive belt tensioner.
  1. Lower vehicle.
  1. Remove drive belt.
Installation
  1. Install drive belt over all pulleys (except drive belt tensioner ).
  1. Raise vehicle on hoist.
  1. Rotate drive belt tensioner , as described under Removal procedure and install drive belt over drive belt tensioner pulley. Make sure all V-grooves make proper contact with pulleys. Make sure the spring keeper is released or improper belt tension will occur.
  1. Install the alternator shield.
  1. Install the inner fender splash shield.
  1. Install the wheel and tire assembly. For additional information, refer to Section 04-04.
    Pulley Routing—Accessory Drive Belt, 3.4L SHO
    Item Part Number Description 1 3A733 Power Steering Pump Pulley 2 6B217 (RH) Idler Pulley 3 19703 A/C Compressor 4 8620 Drive Belt 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 10346 Generator 8 6B217 (LH) Idler Pulley 9 6B217 (Center) Idler Pulley
Drive Belt, Water Pump
Removal
  1. NOTE: If removal of the water pump drive pulley is required, refer to Section 03-03.
    Rotate drive belt tensioner clockwise by hand and remove drive belt from drive belt tensioner .
  1. Remove drive belt from water pump drive pulley and water pump pulley.
Installation
  1. Position drive belt onto water pump drive pulley and water pump pulley.
  1. Rotate drive belt tensioner clockwise by hand and install drive belt over top of drive belt tensioner pulley. Make sure all V-grooves make proper contact with pulleys.
    Pulley Routing—Water Pump Drive Belt
    Item Part Number Description 1 6B209 Drive Belt Tensioner 2 6A312 Crankshaft Pulley 3 8501 Water Pump 4 8620 Drive Belt
Jun 01, 2009 | 1997 Ford Taurus
What tools do I need to remove both engine belts from my wife's 2004 Concorde.do I need ome special tensioner tool to move the tensioner the other belt is a regular v belt and it goes around the...
2.7L & 3.5L Engines same Tools & Procedure Rate Me Please 1/2 in. breaker bar & Special Tool 7198 for conventional V-belts and Poly-V belts
  1. REMOVAL
    AIR CONDITIONING BELT
    NOTE: The A/C drive belt self tensioner is NOT a dynamic tensioner. After adjustment the tensioner bracket bolts are tightened. The torsion spring is no longer responsible for tensioning the A/C belt. The torsion spring is only used for initial belt tensioning.
    1. Remove generator/power steering belt to gain access to A/C belt. Refer to GENERATOR/POWER STEERING BELT for procedure.
    1. Loosen BUT DO NOT REMOVE tensioner locking bolt and pivot bolt (Fig. 2).
    2. Insert 1/2" drive breaker bar into square opening on belt tensioner. Rotate tensioner counterclockwise until belt can be removed from pulleys (Fig. 2).
    3. Slowly rotate tensioner clockwise to relieve spring load.
    CLEANING
    Clean all foreign debris from belt pulley grooves. The belt pulleys must be free of oil, grease, and coolants before installing the drive belt.
    INSPECTION
    Belt replacement under any or all of the following conditions is required:
    • Excessive wear
    • Frayed cords
    • Severe glazing
  • Poly-V Belt system may develop minor cracks across the ribbed side (due to reverse bending). These minor cracks are considered normal and acceptable. Parallel cracks are not (Fig. 3).
    NOTE:
    Do not use any type of belt dressing or restorer on Poly-V Belts. INSTALLATION
    AIR CONDITIONING BELT - NEW
    WARNING: DO NOT REMOVE A/C BELT TENSIONER LOCKING BOLT WITHOUT FIRST HOLDING THE TENSIONER WITH A 1/2" DRIVE BREAKER BAR, AS PERSONAL INJURY COULD RESULT.
NOTE: Verify that torsion spring position is in the new belt position before installing a NEW belt (Fig. 4). If torsion spring is not in the new belt position, follow steps 1-7 to change the tensioner spring from the USED belt position to the NEW belt position.
  1. Insert a 1/2" drive breaker bar into the square opening on the tensioner. Hold counterclockwise pressure on tensioner while removing the locking bolt (Fig. 2).
  2. Carefully release spring load of the torsion spring on the tensioner.
  3. Remove pivot bolt, tensioner, and spring from front timing cover.
  4. Insert spring arm into the NEW belt position on the tensioner (Fig. 4).
  5. Install torsion spring, tensioner, and pivot bolt.
  6. Install pivot bolt. Tighten only finger tight, at this time.
  7. Using a 1/2" drive breaker bar, apply counterclockwise pressure until locking bolt can be installed.
    1. Install the NEW belt by rotating the tensioner counterclockwise until the NEW belt can be installed on pulleys. See (Fig. 5) for belt routing.
    2. Release tensioner and remove breaker bar. Belt is automatically adjusted with the tensioner's torsion spring.
    3. Tighten tensioner locking bolt and pivot bolt to 28 Nm (250 in. lbs.) (Fig. 2).
    4. Install generator/power steering belt.
    AIR CONDITIONING BELT - USED
    NOTE: A "used belt" is considered having more than 500 miles of service use. NOTE: Perform steps 1-7 to change the tensioner spring from the NEW belt position, to the USED belt position.
    1. Insert a 1/2" drive breaker bar into the square opening on tensioner. Hold counterclockwise pressure on tensioner, while removing tensioner locking bolt (Fig. 2).
    2. Carefully release the tension of spring on tensioner.
    3. Remove pivot bolt, tensioner, and spring from front cover.
    4. Insert spring into the USED belt position on tensioner bracket (Fig. 4).
    5. Install spring, tensioner bracket, and pivot bolt.
    8. Install the USED belt by rotating tensioner counterclockwise until belt can be installed on pulleys. See (Fig. 5) for belt routing.
    9. Release tensioner and remove breaker bar. Belt is automatically adjusted with the tensioner's torsion spring.
    10. Tighten tensioner locking bolt and pivot bolt to 28 Nm (250 in. lbs.) (Fig. 2).
    11. Install generator/power steering belt.
I Hope This is Of Help To YOU IF So PLEASE HELP ME RATE ME it Helps Thank You Very Much and Happy Motoring !!!!!!!!
Jan 21, 2009 | Chrysler Concorde Cars & Trucks
Garden Logo
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
