Question about Singer 1725
Bobbin winder on singer 1725
The bobbin winder does not wind correctly the thread is not tight on the bobbin it is loose and slightly messy. It does not wind evenly there is always more thread on the bottom.
    Champion:
    Habit-Forming:
  • 201 Answers
Hai, Please change the new bobbin winder. Because bobbin winder and winding is very important.
Posted on Mar 21, 2014
textile
  • 10 Answers
SOURCE: Problem with winding thread onto
first you must make sure the winder shaft is turning by moving it to the right a little and see if you can turn it by hand.
If it is turning ok then there is a rubber ring on the other end of the winder shaft and it should come in contact with the drive which turnes it ,if it is worn it might need a new rubber.
Posted on Aug 19, 2008
  • 69 Answers
SOURCE: Singer 7444 trouble winding bobbin
It sounds like you don't have any tension on the thread when winding the bobbin. Make sure that you are running the thread through the tension disc on the top of the machine before going to the bobbin winder.
Posted on Mar 01, 2009
  • 3 Answers
SOURCE: Bobbin is not winding correctly
slide plate may be worn - i had the same problem. try holding down the center of the bobbin with a pin while slide plate is in the winding position.
Posted on Mar 03, 2009
  • 980 Answers
SOURCE: Singer 9410 bobbin problems
It should not affect the winding, the reason the needle is still going up and down is because the oil has gone dry on the shaft and unless you can get to the shaft where the balance wheel is then it would be wise to take the machine in for a service, loose stitching on the bottom is a tension problem, make sure the top tension is set about 4 or 5
Posted on Oct 26, 2009
  • 980 Answers
SOURCE: I have a singer 503A. The bobbin winder will not
When you have the winder rubber on try and turn the winder by hand, if it does not move the chances are the winder has seized, if the winder wheel is moving but not the spindle then the grip (thread) has worn, if you cannot move the whole winder by hand and it has seized you need to get some WD40 and spray a few drops down the spindle, take an electric drill and put it over the top of the spindle and switch it on slowly and it will probably free it off, be aware of oil splashing out.
you mighjt get a digram from www.tandtrepair.com
Posted on Feb 24, 2010
Singer Tradition - my bobbin winder has stopped winding so I have to wind thread on manually.
Check on a standalone bobbin winder called "Sidewinder." Make sure it is compatible with your bobbins--some bobbins won't work on the Sidewinder. If it is compatible, then for ~$30 you can wind all your bobbins. (I have one that is powered by battery or by electricity.)
Amazon com Simplicity SideWinder Portable Bobbin Winder
Simplicity Sidewinder Portable Bobbin Winder
Simplicity SideWinder Bobbin Winder Walmart com
Jul 16, 2017 | Singer Sewing Machines
Having difficulty winding a bobbin, the thread goes across the "top" of the bobbin not inside....any help
Check that the bobbin is seated all the way down on the bobbin winder spool. However, the bobbin winder most likely needs a slight adjustment. I have several machines that tend to wind the thread either high or low on the bobbins so I just use a stiletto or pencil to raise and lower the thread as it winds. It helps to wind the bobbin at a slower speed--reduces stretch on the thread and allows you the ability to manually guide the thread onto the bobbin.
If you'd like to save wear & tear on your machine and be able to wind bobbins without unthreading the machine, look for a stand-alone bobbin winder (one brand is called "Sidewinder"). They cost around $30 and can be found online or at most fabric stores like JoAnn's. Just be sure to verify your bobbins will work on the winder--some Singer and other brand bobbins will not work.
Oct 19, 2016 | Sewing Machines
Trying to wind the bobbin on my singer 6268 but the thread keeps winding under the bobbin. What am I doing wrong?
if the bobbin winder is driven of the end of the machine then you may have to guide the thread as it winds onto the bobbin
if you are allowing the thread to come directly from the reel and it is not in line to the bobbin then what you have is what will happen
Jul 21, 2015 | Singer Sewing Machines
Boobin winder isn't working correctly
Needs to be in the tensioner as it winds on or will be loose
Mar 20, 2014 | Singer 1725
Pfaff 2046 tension problems, needle breaks
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight--loosen off one letter or number till the stitch
looks normal
7.make sure that every thread guide is used when winding the
bobbin,, so that the bobbin will wind tightly, if this doesn't help,,
then it's possible that the bobbin winder needs adjustment,, it needs
to be taken to a sewing machine shop
Aug 15, 2012 | Sewing Machines
Bobbin not winding tightly
Consult your owner's manual. Possibly, you are not threading the bobbin winder correctly. The thread does go through a tensioner somewhere along the way that creates tension on the thread.
Janome MEMORY CRAFT 9700 Instruction Book Threading For Bobbin Winding
Or perhaps the tensioner is not working properly.
If neither is problem, then you can always pick up a stand-alone bobbin winder (Amazon, JoAnn's, etc) for ~$30. One brand is called Sidewinder. These bobbin winders are marvelous because you can wind bobbins without unthreading your machine. It also saves wear and tear on your machine.
Or take your machine for service.
Mar 28, 2012 | Janome Memorycraft 9700 Computerized...
I have a Freesia 425 - I have wound the bobbin successfully, but the bobbin will not come off the winder - any explanations
The bobbin is probably cracked. They get that way when bobbins are wound in correctly, or to tight. Just break it off and get new bobbins. Just make sure your theading it correctly when winding bobbins.
May 04, 2011 | Husqvarna Freesia 425
I have a designer 1 that won't release the bobbin.
Winding too tight;
Whenever your bobbin won’t come off any Viking, Designer 1 included, it’s because it wound too tight. This is how you know. It went on easy! To get it off, don’t pry, slowly unwind all thread, it will change shapes and let go of the bobbin winder. My favorite way to wind a bobbin on a Viking is to thread the machine through the needle and go under the foot then up to the bobbin winder (it has to be under the foot or it winds too tight. If it still winds too tight, lay your thread down instead of standing it up, the weight of the thread can increase tension on the winding process also check that you use a spool cap as large as or slightly larger than your spool. If it still winds tight. I’ll explain what bad thread can do.
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test (tip: always check your thread this way when you thread your machine)
Mar 12, 2009 | Husqvarna Designer I
Feb 28, 2009 | Singer 3116 Simple
Singer 1725 Logo
174 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
