Question about Xerox Phaser 7750DN Laser Printer
Receive message of out of paper
There is paper but message reflects
    Novelist:
  • 140 Answers
Pull the paper tray completely out. using a flashlight, look into that section. There should be a black flag hanging down. That is the paper out sensor flag. If it's not hanging down, look at the roof of that section and see if you can find it hung up. If it's there, carefully pull it downward gently. If it's missing, time to call in the technician because the main board is going to have to be opened up to replace that missing part.
Posted on Jan 03, 2015
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
When I put black paper or envelope in the printer - it claims there is no paper -
The optical sensor is trying to reflect light itself, to the paper/envelope, and back to the sensor.
When no light reflects back, it claims "no paper".
Try a different colour of envelope/paper.
Or, determine in which corner of the paper that the sensor is, and paint a small amount of "Liquid Paper" onto that corner of the envelope, and let it dry thoroughly.
Then, when the sensor is over that "white" corner, the light will reflect, and you'll be able to print.
Then, scrape-off the "Liquid Paper" (or "White-Out").
Oct 04, 2010 | Office Equipment & Supplies
After printing on cardstock paper from Avery, I have attempted to print on the back side of the same paper. The printer will not allow it. Keeps sending me a message saying "out of paper", and there is...
Possible that the paper indetect is sensing a bad signal from the used paper and so is not accepting , it can also be black spots which may not reflect the opto sensors.
If with the right printing paper- new- there is no issues please do not attempt to correct.
Sep 28, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Have X3 Zebra 140Xilll printers. These printers will stop printing with a message "Error condition Paper out". But the paper is loaded. Everything seems fine. What can I do? Thanks Steve Rolland
Check and clean the sensors, also the reflective surface. Make sure there are no lables stuck to the reflective surface. Use Isopropyl Alcohol to clean.
Jan 21, 2010 | Zebra 140XiIII Plus Thermal Label Printer
HP 5510 All In One. Error message Paper Jam when printing photo paper 8X10. There is no paper jam. Plain paper runs right through.
Have you changed the paper properties to reflect that you are using a heavier weight paper?
If not, then the printer might not be set right for the paper you are using and that can cause the problem you are seeing.
Dec 05, 2009 | HP Officejet 5510 All-In-One Thermal...
Zebra 110Xilll Plus Printer Not Recognizing Media
You can run the manual calibration from the menu , just follow the directions. Also run the sensor profile to print out the digital representation of the media sensor .If you are using standard label stock this should tell you if the transmissive sensor is good. Depends on the media, follow the users manual if different media requirements.
Oct 20, 2009 | Zebra 110Xi III Plus Thermal Printer
Paper out error message
Recalibrate the printer via the Menu system, if this doesn't work you might have a faulty paper out sensor. Another thing to check that there is no old labels stuck on the upper side, this means label gum etc as the sensor is reflective.
Sep 23, 2009 | Zebra Z4M Printer
Message shows out of paper during copy or receiveing a fax
Take it back. It is broken. If It was older I would suggest some things, but it would probably invalidate your warentee
May 26, 2009 | Lexmark X5470 All-In-One InkJet Printer
Ibm 6400 Printer thin 3 copy module loading problem
the 6400 paper present sensor works off the reflection of the paper itself, so if the paper you are using is black on the back the sensor cannot work as there will be no reflection. You need to remove the sensor and rotate it in its housing 90 degres so that it is facing the flag on the paper motion sensor, you may also have to paint this flag white (reflection to work) tipex is ok for this.
Jun 02, 2008 | IBM 6400 Matrix Printer
Can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Oct 15, 2007 | Brother IntelliFax-2820 Laser Fax
Xerox Phaser 7750DN Laser Printer Logo
29 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
