Question about Sharp Aquos LC42XD1E 42 in. LCD TV
No Channels Hello There..I went out yesterday and switched my telly off by the on/off switch on top and came back last night and can't get any channels at all a box just comes up with Database empty..I have retuned it a number of times but still not getting nothing.?? Thanks Peter
    Master:
  • 397 Answers
HI, the first thing to check is that your TV aerial or cable connection is ok. Try removing the connection from the back of the TV and re-seating. If you use an aerial on the roof or in the loft, check the state of it, if it has moved or been damaged in anyway that may be your problem.
Posted on Mar 20, 2014
  • 8909 Answers
SOURCE: Problem, unable to access any digital channels. TV
If the database is empty you need to re load the system.
With your remote controller, go to menu and from that you need to select install or setup.
This will scan for all available channels and store them for use.
Hope that helps.
Posted on Nov 19, 2010
  • 1779 Answers
SOURCE: hisense 42inch lcd tv
It sounds like it's the inverter panel which lites the lcd back light.
If it's under warranty, try to replace it, or take it in for svc.
Posted on Feb 27, 2008
SOURCE: Error message - "data base is empty"
Hi John
I have the same problem, although my set is a 32". See my posting on AVForums.com (UK)
http://www.avforums.com/forums/freeview/984253-sharp-aquos-lc32d44e-losing-memory.html
My email address is pastel10@btinternet.com in case you want to contact me
Paul
Posted on Apr 24, 2009
roety
  • 585 Answers
SOURCE: My Sharp Flat Panel Television LC19SB25U has Picture but No Audio
Sharp has had a few problems with their audio boards, not finding any bulletins on this model, but a few complaining about low audio on amazon reviews section. If using an antenna you will experience some channels with low audio. If using cable you should get good sound on all channels..
the 9.1 and 9.2 are digital channels and sharp does display them for at least a few seconds when you switch to that channel. Check all your setting in the audio to Stereo never SAP. To options for you are get a cable box, first check in the back and see if there is another coax in, if there are two try both rescanning after connecting.
GD lk
Eric
Posted on Aug 16, 2009
  • 53 Answers
SOURCE: Cannot tune all digital cahnnels on Sharp aquos
Start by doing a factory settings/ defaults on the Sharp rather than a normal automatic retune.This should then be ok. You need to empty the existing presets first so it will find the new type of signal BBC is now using.
If still not working for BBC1 +2 then look at whether you have too much aerial signal strength. (ie a booster/splitter that you could bypass)
Posted on Nov 07, 2009
Mitsubishi cold 3.0 v6 workshop manuals
If your philips tv keeps losing it's stations when you switch it off, this my be a solution -----my 42" tv would need to be retuned every time I wanted to watch it this fault just started over night it was all working fine then sat down to watch tv and had to retune tv from scratch I could then watch telly all night fine change channels no probs all great switch it off next day retune and so it went on if you have this problem switch telly on then hold in menu button on tv until screen goes black (this reboots software) then retune tv as normal it will ask if you want a full retune (yes) when this is complete digital and analogue your tv should now remember channels when switched off and work as it used to ----( Hope this helps you if you have had this problem it worked for me ). Good Luck
May 29, 2014 | Televison & Video
Hello have a problem with tv Model is: lg
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6281
The above link goes to lg's website describing the red flashing light where the power switch is, and
another switch down below which can turn that light off.
Try switching that other switch below off so the light turns off. Then, switch it back on.
If that doesn't work, then service should be scheduled for this discontinued model.
Hope this helps on your lg tv.
Jun 29, 2010 | Compaq Presario 5000 PC Desktop
Hello lost my starview box last night tryed the codes but no fix yet could someone please tell should i be on NTL or TW (Middlesbrough Area) many thanks in advance
ye just go to installation and manual scan then auto scan make sure ntl is selected 1st, channels might be mixed up but sort mannualy ,a pain just takes a bit of time
Feb 23, 2010 | StarTech.com StarView SV211K 2-port KVM...
Hi box super went last night have no channels has any1 got any codes for northeast area thanks a lot
hi. my starview box stopped working 2 days ago.
can anyone HELP
new codes please
25-08-2010
zaks
Channels lost on starview box
Yeah i had the same problem with starview 4. i upgraded the firmware and still no good. i then by accident set the default key. it worked. i'm not sure if it will work for u.
Aug 30, 2009 | StarTech.com StarView SV211K 2-port KVM...
Digivox doesnt recieve setanta sports 1
try deleting all channels then scanning agian i lost sky1,2,3, and iv just got them all back on
May 02, 2009 | StarTech.com StarView SV211K 2-port KVM...
New codes !! april
my box went off i tried these codes on telewest and all off my channels came back on , good luck and pass it on if it helps .
Apr 02, 2009 | StarTech.com StarView SV211K 2-port KVM...
Roper washer ras6233kq
Hello, So unit should fill with water though right? Just no spin and drain. more than likly you have a bad lid switch. look and see if there is a hole somewhere on the frame. usually on the lid you will see a actuator that plunges into the lid switch. When you close the lid you should hear a click if there is no click you a bad lid switch.
Dec 24, 2008 | Roper RAS6233KQ Top Load Washer
Technosonic stb2009 working fine until last night when the picture froze and the sound went off. Changed channels only to find that all channels are blank, did a reinstall only to be told to check my...
It seemed to sort itself out. I switched it off for 24 hrs and then the following evening switched it back on and hey presto it was working again, haven't a clue how it did it but it did
Aug 12, 2008 | Televison & Video
Part of [icture missing
Brand name & model number would be helpful.
Have you tried reset or re-boot by unplugging the ac cord
for awhile,then plug back in,try again?
Is it under warranty or did you receive it second-hand??
Let me know....T.
Oct 19, 2007 | Televison & Video
Sharp Aquos LC42XD1E 42 in. LCD TV Logo
179 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
