Question about Miele S7260 Bagged Upright Vacuum
Split suction hose
Hi The suction hose has split due to overextension and needs to be replaced. Anyone have contacts to get cheap replacement hose and know how to take ends off and refit? Many thanks
    Champion:
  • 203 Answers
Try e spares on the internet they have most parts
and to replace is very easy
Posted on Mar 20, 2014
2 Suggested Answers
small6363
  • 18394 Answers
SOURCE: Miele S7210 upright how do I remove a split hose from the handle end
THIS LINK IS THE MANUAL
http://www.totalvac.com/manuals/miele-vacuum-S7000-manual.pdf
Posted on Oct 16, 2012
BAD SUCTION WHEN USING ATTACHMENTS
Bad suction often means a blockage somewhere, so check all the possible areas for blockage that relate to the hose. Also, check the hose for splits, as they often split at either of the ends - this would greatly affect the suction when using the hose and tools (and can sometimes only be spotted when the hose is stretched at the end points).
Jul 21, 2014 | Dyson DC03 Bagless Upright Cyclonic Vacuum
Vacum is fine just no suction on attachment hose how to unclug hose
Hi there, I see this problem pretty often because where the hose joins the machine proper there is a slight reduction in airway size. I have made a video to show you how to remove the hose so take a look at that. If you find a split in the hose you will need to buy a new DC07 hose because it will reduce suction ans cause blockages more frequently.
Feb 12, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
Animal not picking up through main plate
Look underneath and you will see a short length of clear plastic hose with spiral wire reinforcing. Very often that hose splits (which allows air in and reduces suction around the brush roller) - you may need to get it off to inspect it thoroughly. To get it off, pull it off at the end closest to the motor and then unscrew it from the end near the brush. If it is split it will need replacing (a new one is not expensive, and it's false economy to try to tape over the old one - except as a very temporary measure).
If the hose is not split, look for a blockage somewhere.
Apr 09, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Suction perfect when in upright position, but when tilted to actually clean there is total loss of suction - cannot see blockage anywhere. Thanks for your help.
If you are confident there are no blockages, look underneath, where the brush is, and you will see a short length of reinforced clear plastic hose. This often develops a split which results in loss of suction. You can pull the hose off at the motor end and then unscrew it from the brush end to examine it thoroughly. If you find a split, it's best not to try and tape it up (except as a very temporary measure) - a new one is not expensive.
Feb 26, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
There is no suction to the floor sweeper. The
Sounds like you have two separate problems here.  If the brush bar does not rotate, probably the belt is broken. This is easily replaced, but you need to be precise about which model you've got so you get the right belt.
Loss of suction is due either to a blockage or, quite often, to a split in the short length of clear plastic hose that leads back from the brush bar enclosure.  Repair is possible but replacement is better.
If you need more help, post here again.
Apr 21, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC 14 lost suction to beater bar/ suction to hose/stick
My Dyson DC14 had no suction...see if this works...turn the Dyson upside down...there is a length of hose that connects the bottom of the vacuum to the top, careful remove one end of the hose and check for debris...mine was clogged. Removed the clog and voila...it works. Thanks for the above info on checking the hose for cracks.
Apr 11, 2009 | Dyson DC14 All floors Bagless Upright...
Dyson vacum cleaner lost suction got the DC14 and it doesn't seem to have much suction in the floor head, the hose still has good suction. I have checked all the paths for blockage and there is none.
Forgive me if I'm thinking of the wrong model, but I think the DC14 has a short length of clear plastic tubing between the floor head and the fixed vacuum pipe-work. This tube can split and let air in which, of course, reduces suction at the head. You need to inspect it very carefully, as the split is often where it's really difficult to see!
If this is the problem, a repair with tape is possible but rarely completely satisfactory. A new bit of tube is the best solution.
Apr 08, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Split hose?
this piece is available but is very difficult to install. the upper handle needs to be split to reach the upper part of this hose. i would call the manufactuer and find a local warranty service center to get this part.
Sep 03, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover Agility, No Suction!!!
I had the same problem. Lower the handle to the floor and check the black spiral suction hose at the neck of the machine. The lower hose in my Hoover split. Check and see if yours has done the same thing. If so, the lower suction hose will have to be replaced. Hope this helps.
Oct 04, 2007 | Hoover F6212-900 / F6215-900 SteamVac...
Miele S7260 Bagged Upright Vacuum Logo
146 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
