Question about E-Machines emachines (emachinees) CD-ROM Drive
My cd-rom is stuck : won't open even if I click on the eject button, there's NO little hole where I could enter a paper clip to open it manuelly. What can I do ????
I tried shutting down the computer, with a screw driver, but now, I don't know anymore what to do. Thanks
  • E-Machines Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard.
If this does not fix the problem it might be a registry problem
"you only need to do the following"
if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and typeregedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computerOpen My Computer and check to see if your CD or DVD drives have returned.
You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Posted on Mar 20, 2014
  • 4 Answers
SOURCE: Emachines w3507 DVD Rom Broken
There may be a hole but it will be under the lip of the door, kind of impossible to get to. You may have to remove the drive from the emachine and unscrew it and open it manually with a small screwdriver. I regularly buy and repair or use parts from used samsung drives which is what emachines uses almost exclusively. The only upside to this is that once open, you can swap the faceplates and doors onto newer drives. If the led light is not in the middle then you can swap out the little plug in circuit too.
Posted on Nov 28, 2007
hardkiss69
  • 43 Answers
SOURCE: CD rom drive wont open!!!
Hi, it only means that the drive is already damage and you need to contact the manufacturer of your computer and verifiy if your computer is stil under warranty so that they can replace the drive with no additional cost but for some reason if you have physically damage the drive then you will be charge for the said repair so it depends on the warranty of the computer.
Hope this helps!!!
Thanks
Posted on Sep 18, 2008
  • 998 Answers
SOURCE: DVD/CD ROM does not open
There should be a small hole on the front panel of the DVD-ROM. Take a paper clip and insert it into the hole and push to open the tray. If the DVD-ROM tray continues to malfunction, you'll need to replace it. DVD-ROMS run anywhere from $25.00 to $75.00.
Posted on Oct 17, 2008
  • 54 Answers
SOURCE: cannot open the disk drive.
It happens when you stop using your drive
use pins and insert in small hole present above the LED[light]
Posted on Dec 10, 2008
  • 1244 Answers
SOURCE: I can't even figure out how to open the CD Drive
theres a button its hid ! on the front panel small look like part of the panel have to push it in firm and hold it just a second or two
Posted on Jan 14, 2010
I have a cd I put in, but do not know how to remove it from my computer need help
1. Open the Computer window on your PC: Either double-click the Computer icon on the desktop, or open the Start menu and choose Computer.
2. Click the DVD drive icon: Clicking the icon selects that drive.
3. Right click on it and choose 'Eject' from the drop-down list.
OR
Try the following only if the above steps didn't work or in times of urgency, such as when the computer is locked up (or turned off), you can manually eject a disc/cd by pushing a straightened paper clip into the tiny hole (the "beauty mark") on the front of the DVD drive.
f90a6593-7fec-4205-a633-379cc4b71e53.jpg8572a8b8-67cd-4c33-bbf8-d5d51bfdd48d.jpg8681c4da-0608-43dc-b4b8-cee760b38e11.jpg
Nov 28, 2013 | Computers & Internet
My cd rom drive has power but when you try to eject the tray it won't go out...my laptop brand is HP PAVILION DV7-1135NR ENTERTAINMENT NOTEBOOK PC
There are two ways to open the CD drive door ifthe button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD drivemay be faulty and needs replacing.
Aug 22, 2011 | HP (198702-001) Plug-In Module DVD Drive
My cd is stuck and the eject button won't eject it. Is there any way I can get it out?
Aug 10, 2011 | Dell Inspiron One 2305 Desktop Computer...
The CD rom does not open?
Take a paper clip now straighten it push it in the tiny hole on the front of the CD ROM drive
the drive should open
Apr 12, 2011 | LG (GCC4243N) CD-RW/DVD-ROM (Combo) Burner
I don't know how to open the CD compartment on this laptop.
Open My Computer, right click on the icon for the cd unit and click Eject.
Dec 04, 2010 | Dell Latitude D600 Notebook
It cannot open or eject the drive
If there is something stuck in the drive and you need to get it out, there is a tiny little hole on the right side (beside the eject button). Just take a paper clip and stick it in there. You will hear a click and the drive will unlock and eject.
For operational use, does you computer see the drive in My Computer? I would open the case and take a look to ensure that the cables are all tightly plugged in.
Nov 25, 2010 | Samsung SC-152L (dssm52xcdoem) Internal...
How do i eject a stuck cd from gateway one 710 series I have tried the eject button on the keyboard but will not give it up...
Have you tried the eject button from the tray? If all that you need is a tool to eject the tray without touching the tower, I suggest you to go to this link and download the Eject-CD freeware runtime file EjectCD.exe - approx 30kB. Alternative if your tray is locked and can not open with the above methods, you have to locate a small hole in the front panel of the tray and put into that hole something like a connector (for papers) or a strong wire in order to push the internal system to open.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Apr 08, 2010 | Gateway ONE GZ7108 All-in-One Desktop PC
Cd rom drawer on dell laptop won't open
hello, have you tried going into "My Computer" then right clicking on cd drive and click "Eject"? if not, try that.
if you have then take a thin paper clip open up one side of it so its straight.
After you have paper clip straighten up look carefully around the cd rom's eject button and you will notice a tiny hole.
Take the paper clip and keeping it straight slowly and gently insert in the hole and soon you will feel little resistance push it a little bit more and that should eject your CD rom.
if it opens up leave the cd rom open and reboot your laptop once and see if your drive now work normally and ejects the way it should?
hope this helps, post back if you have issues.
Kind regards,
Amar Sondhi
Jan 22, 2010 | Dell Inspiron™ 600M PC Notebook
The CD ROM Drive is not ejecting properly
hi,
Locking device / software installed
First, verify no locking software is being loaded, which would allow the CD-ROM tray not to open. If you are unable to determine this, reboot the computer and as it is booting up, attempt to eject the tray. No power to computer or CD-ROM drive
If you have recently installed a new CD-ROM drive or you have moved the computer, it is possible that the power to the CD-ROM may have become loose or disconnected. Check the cable connections. Bad eject button
If you are running Microsoft Windows 95, Windows 98, Windows NT 4.0, Windows 2000, Windows ME, or Windows XP, open My computer, right-click on the CD-ROM drive and choose the option to eject. If this ejects your CD-ROM drive tray, it is likely that the button on the CD-ROM drive has become defective and it is recommended that the drive be replaced. CD stuck within drive
It is possible that a CD may have become stuck within the CD-ROM drive. If the CD-ROM drive has a small hole (that is not the head phone jack), using a paper clip, place the paper clip within the hole and attempt to manually eject the CD-ROM tray. If the CD-ROM drive is only partially able to be opened, attempt to pull the tray gently to see if it can be manually ejected. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become bad, dislodged, or that a CD is positioned in the drive, which does not allow it to open. Incompatibility with IDE / ATAPI interface
If you have an IBM compatible computer and recently installed the CD-ROM drive and are unable to open the drive, attempt to temporarily disconnect the IDE cable to verify that you not experiencing an issue with an incompatibility between the CD-ROM and motherboard. Once the IDE cable has been disconnected, power on the computer and see if the CD-ROM drive tray is now able to be opened. If the drive is able to be opened with the IDE / ATAPI cable disconnected, it is recommended you use the interface card supplied with the CD-ROM drive or the ATAPI interface on the sound card / motherboard. Bad drive
Unfortunately, if after following the above recommendations you are still unable to properly open the CD-ROM drive using the button on the front of the CD-ROM drive, it is likely defective and should be replaced. Caution: If you are able to open the CD-ROM drive using a paper clip. We do not recommend that you continue using the CD-ROM drive by manually ejecting the CD-ROM using a paper clip. The drive should be replaced and this is not meant to be used as a temporary solution. Additional information and tips for buying a new CD-ROM drive can be found on our CD-ROM buying tips section.
Jul 02, 2009 | Computers & Internet
My cd rom is stuck, when i click eject button it won't open.
There should be a small hole in the front, use a paper clip and push into the hole to eject tray mannualy. The cause of the tray not ejecting is that the belt from the motor that ejects the tray is worn, need to change it.cheers.
Dec 01, 2008 | Gateway (5502156) CD-ROM Drive
Computers & Internet Logo
47 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
