Question about LG Washing Machines
LG WASHING MACHINE MOTOR NOT TURNING JUST ROCKING FROM SIDE TO SIDE
WHEN MACHINE STARTS DRUM DOES NOT TURN JUST ROCKS FROM SIDE TO SIDE
    Sergeant:
    Champion:
  • 266 Answers
Pretty good sign the belt is broken.
Posted on Mar 20, 2014
Testimonial: "Sorry not belt... machine is direct drive...!!"
SOURCE: LG WF-764STP
Your problem might be the motor capacitor
Posted on Aug 31, 2007
  • 958 Answers
SOURCE: washing machine drum won't turn under power
is the washing machine went to its usual cycle? put water in?
if you think the motor should have run already, then it could be the motor or the motor inverter.
check the motor leads for equal resistance, if i'm right, you may have a three phase motro so the three leads that comes out should have equal resistance.
also, if you can monitor the voltage present in the motor leads while it is plug in and you are waiting for the motor to run, if there is voltage then there is a problem with the motor, if there is no voltage present, then the inverter unit would be the defective part.
tnx 4 using fixya,
drcool
Posted on Sep 28, 2008
barkencoa
  • 3463 Answers
SOURCE: WASHING MACHINE DRUM WILL NOT TURN
There is no adjustment provided for lining up the pulleys.
If it comes off then there are a couple of reasons that come to mind,the belt is too slack, the belt is worn,the drum is out of alignment with the motor pulley, caused by worn drum bearings, the motor is loose, a loose drum pulley, or you are not lining the belt up properly, overloading can also throw the belt off.
Hope this helps.
Plz leave feedback.
Ta.
Posted on Dec 09, 2008
SOURCE: Drum will not spin
I unplugged the machine for 1 hour and the computer reset, and it is working fine
Posted on Jan 05, 2009
blueextc3221
  • 15935 Answers
SOURCE: Sounds like rocks are in the washer when it spins the clothes.
Rear Tub Bearing Replacement Whirlpool Frigidaire Kenmore Front Loar Washers
This advice is for replacing the rear wash tub shell of most Kenmore Elite HE model FRONT LOADERS, along with Whirlpool Duet, and some Frigidaire FRONT LOADER models. This is a repair that would be rated as difficult due to the extensive disassembly and reassembly of components.
The requirement to replace the rear wash tub shell is usually attributed to the rear tub bearing failure in which the bearings are molded into the tub and cannot be replaced otherwise. In some situations the replacement of the inner spinner basket (stainless steel tub) may also be required due to the corrosion and breakage of the spider arms in the back of the basket that support the basket.
SYMPTOMS: Washer exhibits excessively loud “rumbling” type noise during the spin cycle, excessively vibrates, or won’t spin at all.
DETERMINING IF THE BEARING AND SPIN BASKET ARE BAD: With the washer door open, place your hand inside the basket and push straight up. If there is excessive play in the tub (wobbles up and down) the bearing is probably bad. If the spinner basket scrapes against the outer tub shell when you give it a spin, you will have to replace the inner spin basket as well. Unfortunately, you cannot see the condition of spinner basket supports until it is removed from the outer tub shells. In some cases, a brownish colored stain my show up on clothing as the bearing seal has been breached and leaks into the spinner basket.
Before starting this repair, make sure you read through all instructions thoroughly and place the washer is in an area that gives you plenty of space to work.
DISASSEMBLY:
1. Unplug washer and turn off water supply.
2. Disconnect washer inlet supply lines and remove drain hose from standpipe.
3. Using a shop vac, pull a vacuum on the drain hose to remove all residual water from the drain lines, tub and drain pump. If you do not own a shop vac, remove the lower panel under the door and locate the drain pump. If the drain pump has a clean out trap, lay out some old towels, and open the trap to allow water to drain. If the pump does not have a drain trap, disconnect one of the drain pump hoses.
4. Remove the lower panel under the door (if you haven’t done so in the previous step) and remove the washer top and back panels.
5. Disconnect the dispenser hose from the top of the wash tub and disconnect the hose on the side of the tub going to the pressure switch.
6. Remove the hose that leads from the bottom of the wash tub to the drain pump and remove the drain hose that leads to the standpipe.
7. Remove the door bellow (rubber door boot) from the door frame ONLY and push inside the tub. Leave the other end of the door boot attached to the tub shell. If this is a small front loader, the bellow is cemented to the washer door frame. Use a putty knife to slowly peel the rubber from the door facing. If this is a large HE or Duet model, the bellow is held in place by a small hoop spring. It is located in the seam of the bellow along the door frame at the six o’clock position. Pull the spring out and carefully stretch it apart to remove the hoop from the seam. With the hoop removed, the bellow can be pushed inside the wash tub. Remember to remove the bellow from the water inlet tube that leads from the dispenser.
8. Remove the washer support shocks from the wash tub. The large HE model and Duet models are removed by grasping the upper portion of the shock and turning counter-clockwise. The shock will snap loose and can be pushed aside. Leave the lower portion installed in the bottom of the washer. If this is a small front loader, the shocks are held in place by plastic pins. The pins have a locking tab that needs to be compressed while pushing the pin out of the hole. This is NOT any easy task and it will take some effort. HINT: If you use a long socket that fits snugly over the pointed end of the plastic pins, it will compress the locking tab and enable you to use a hammer to carefully tap them free. NOTE: Large HE models and Duets have 4 shocks, while the smaller models may only have 2.
9. Remove the Drive Motor belt by grasping it near the top and pulling towards you while rotating the large pulley. The belt should slip off.
10. Remove the Drive Motor and Motor Control Board. Carefully label all connections, so you know here the go when have to re-install them.
11. Remove the back casing brackets so the entire back of the washer is open.
12. Remove the rear counter weight from the wash tub to minimize some of the weight.
13. This next step may require two persons: With the tub still suspended by the upper support springs, slowly lay the washer all the way on its back while supporting the wash tub. NOTE: Place something under the washer to support the tub shaft as you lay the washer back (i.e., old blankets, cardboard boxes, etc.) Once the washer is lying down, remove the upper support springs and set the cabinet upright. The wash tub should be now free from the washer cabinet.
14. Set the wash tub assembly upright and remove all the screws around the perimeter of the tub shell halves. NOTE: An electric screw driver with socket attachment works wonders and will speed up this process. If the tub is held together with clips, use a screwdriver along the tub edge under each clip and pry up to remove.
15. NOTE: If you plan on reusing the door bellow, use care not to damage any of the rubber. Place some old towels down and lay the wash tub assembly with the front opening face down. Lift the rear shell off the inner wash basket shaft. You can now inspect the spider arm supports of the spin basket. If the supports are cracked or broken, or if the shaft is worn, you will need to replace the spinner basket.
16. Remove the spinner basket assembly and inspect the front tub shell. In most cases the front shell can be reused and will not require replacement. If the inside of the front shell is damaged, however, it will require replacement.
REASSEMBLY:
1. Reassembling the tub shell parts and inner spin basket is self-explanatory. Just make sure you tighten all screws evenly in a crossing pattern as you tighten the tub shells. If the tub is held together with clips, they can be tapped back into place with a hammer. Use the same crossing pattern to ensure the shells are tightened evenly.
2. Lay the assembled tub shell with the opening face up. Make sure you support the spin basket shaft.
3. Lay the washer casing down over top the washer tub shell.
4. Insert the upper shell support springs into the wash tub and support spring brackets.
5. Raise the washer casing to the upright position, making sure the tub does not swing forward into the washer front. Re-install the rear counter-weight and washer back brackets.
6. Re-install the washer support shocks.
7. Re-install the drain line hose.
8. Re-install the Motor Control Unit and Drive Motor.
9. Re-install the Drive Belt pulley and belt. The belt is installed by placing it into the Drive Motor shaft, first. Make sure there is a one-groove gap between the belt and the end of the drive shaft. With your left hand hold the belt on the drive pulley and guide it around as you turn the pulley with your right hand in a clockwise direction. This can take some effort.
10. Re-install the hoses that lead from the bottom of the wash tub to the drain pump, and pressure switch.
11. Re-insert the water inlet tube into the rubber door bellow, ensuring the rubber is seated past the flange on the tube.
12. Pull the door bellow through the door frame opening and reseat it. If this is a small model front loader the door bellow will have to be cemented back in place with appliance door gasket adhesive. If this is a larger model front loader that has a hoop spring to hold the bellow in place, insert as follows:
- Place the hoop into the groove of the door bellow along the facing of the door frame with the spring in the 6 o’clock position.
- With both hands gradually work your way around to the 4 and 8 o’clock positions and stretch the spring apart.
- Push the spring and hoop into the groove.
NOTE: It may require a second person to get the door bellow back in place.
1. Re-install the rubber dispenser hose to the top of the wash tub.
2. Re-install back panel and top panel and hook washer back up to water source. Make sure the drain hose is placed back in the standpipe.
3. Leave the bottom washer panel off and plug unit back in. Test operate and check for leaks. If no leaks are present, re-install bottom panel.
Some other parts that may have to be considered when performing a rear tub shell replacement:
- Rubber Door Bellow
- Spinner Basket (if arm supports are damaged)
- Front Tub Shell (if signs of internal damage)
- Drive Pulley (can sometimes become damaged trying to remove old one)
- Drive Belt (check belt during parts removal for wear)
- Wash Tub Support Shocks (The shocks can sometimes break when trying to remove)
NOTE: 1. If you replace the front tub shell you will need to remove the door bellow and front counter-weights and install them on the new shell. 2. If you replace the spinner basket, some do not come with the wash tub fins. Make sure you remove and re-install the old ones in the new tub if required.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Washing machine shakes badly when spinning.
If not an unbalanced load, then it is an unbalanced drum. Turn the drum by hand when it is empty and it should spin smoothly (not freely because it is attached to the motor so there will be resistance). Can you hear a knocking or grinding? Push and pull the drum in and out, again any knocking? With your hands at 3 and 9 o'clock push with one hand while pulling with the other and rock the drum back and forth. Try it with hands at 12 and 6. Does it feel loose or makes a knocking?
Grinding is usually a sign if the bearings going or gone and knocking may indicate a broken drum holder (sometimes called a spider)
If everything sounds and feels okay then it may just be the machine is not level or secure. Rock the machine and if it wobbles check the feet and adjust until no more rocking. The feet do bend or adjust themselves over time, even making some kind of impression on the floor that makes it settle to a different level.
Jan 24, 2016 | Washing Machines
How do i troubleshoot for a ball sensor,switch on a LG laundry washer?
machine needs to be level.so it cant rock side to side or front to back adj feet .when u load machine put half in and rotate drum half turn and put the rest of load in.that should balance load.dont overload.try running empty if it still showing ua
Aug 09, 2014 | LG WM Washing Machines
How to restart?
normally pressing and holding start or stop will reset .removing drain hose from wall and holding at ground level will empty all washing machines.so have it in a bucket.either its not level so adjust feet so it cant rock about then dont overload it turn drum as u load that will help balance.
Jul 28, 2014 | LG WM2016CW Front Load Washer
Ftf530es knocks during spin cycle
Good Morning Friend,
I understand that your Frigidaire washer, model# FTF530ES, is having trouble with the drum rocking back and forth, from front to back. I suggest making sure that your washer is level. I would check from front to back, side to side, as well as from corner to corner. If you have leveled your appliance and are still noticing the drum rocking from front to back I would suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire FTF530FS Front Load Washer
I have moved into a building with a brand new washing machine and every time I run the washer it moves around and it is starting to damage the machine and my walls. what can I do to stop this?
Hi from retired Englishman in France,
It is imperative that washing machines are absolutely 'level', especially most noticeable when carrying out the spin cycle.
You need, in a hurry, to have the 4 (probable) feet underneath adjusted so that all of them are FIRMLY on the floor. New machines in the UK and France come with an adjustment spanner- I will presume yours has.
The ones at the rear can be left alone provided they are 'locked' with a locking nut and will not rotate. Probably just one of the two at the front needs to be tightened down firmly to stop the machine being capably of being rocked by firm pushes. If it rocks from the right-hand side then it is the right-hand side which should be adjusted.Conversly the left-hand side.
Having this done will save potential damage to the washing machine dampers/shock absorbers which are part of the internal suspension of the drum.
Good luck,
John C
Jan 25, 2011 | LG Washing Machines
Drum rocks front to back and vibrates
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 14, 2010 | LG WM-2277HW Front Load Washer
During spin, machine moves!
Did you remove the transport rods from the back of the unit? this will cause the unit to jump around a lot when it goes into the spin cycle. Also make sure the feet are all level and the unit doesn't rock from side to side.
Mar 22, 2010 | LG WD-16115FD Front Load Washer
My lg wd1274 fhb has started rocking violently during a wash cycle
Check the machine for level. It has to be dead on. After you do this if it still vibrates you either have bad shocks or a bent spider shaft on the back of the drum. Hope the level fixes it because a spider shaft replacement is a complete tear down. Plus while you have it down you should change both bearings and the inner seal in the drum housing.
Jan 14, 2010 | LG Washing Machines
When drum starts to turn locks up then will turn one way but not the other.then after 2 or 3 times it will turn the other way then le code comes up
Possibly a bad load sensor ($20 part 6501KW2002A)
For me it was the bearings were shot. Heard
loud noise during spin then the unit stopped and displayed the LE error.
Removed the rear panel then removed the large center bolt. Grabbed both sides of the Stator cover and rocked it back and forth till it came off. Noticed that the drum had been leaking which caused the bearings to break away which lodged in the motor.
Now I'm replacing with diff brand since i'm not sure what all damage this caused.
Pictures posted:
http://www.fixya.com/support/t608508-very_loud_grinding_noise_lg_wm_2277hw
Sep 27, 2009 | LG WM-2277HW Front Load Washer
Washine machine won't turn last spin.
If it has a Start-Reset button, try pressing and holding for 3 seconds..
Select a drain and spin prog and try again
Plz rate my suggestion.
Thanks.
Dec 26, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
