Question about Moen Inc. CHROME 1H KITCHEN FAUCET CA87007"
Slow drip that can be stopped by tightening the collar below the lever, what's the fix
The collar below the lever loosens as the spout is moved towards the right, counterclockwise. if I tighten it the drip stops, but every time we use the faucet the collar loosens again. whats the problem?
2 Suggested Answers
c7121
  • 160 Answers
SOURCE: moen kitchen faucet spout
there should be a removable "button" on the faucet base below the handle. under there, there should be a set screw. loosen the screw, remove the handle. now u can adjust the base, collar, etc. to ur liking...don't forget to reassemble everything the same way u removed them.
Posted on Dec 13, 2009
Testimonial: "that was one reason I was looking for a diagram to show EXATLY how everything goes back !! will try your suggestion thanks"
I do not have the side spray, but there is a dripping that is getting hard to stop. Can't stop the drip and would like to know what I need to do to fix. I have already tightened the screw on the top....
faucet needs new gaskets and springs located below the handle. remove handle, loosen collar nut and remove, pull cartridge out straight up, remove gaskets and springs, take to local Home Depot and buy new and replace. install cartridge, install collar nut, install handle. All finished.
Aug 30, 2011 | Kohler Fort© Single Lever Handle Kitchen...
Tip
How to rebuild a single handle delta kitchen faucet.
Step 1- Shut off water supply to your faucet.
Step 2- Use 1/8" allen wrench to remove handle from faucet.
Step 3- Next it has a retaining ring to loosen, they make a little spanner wrench to fit this in all complete rebuid kits. And then you are ready to loosen the collar.
To do this would be best to have a tool to grip the collar and not do damage to it. Some hardware stores carry rubber slip on's to fit on chanel locks pliers to avoid marking. Or if you have access to a strap wrench that will work.
Step 4- After collar removed, remove plastic cap and washer and ball. Seats and springs are located in valve bottom. Remove seats and springs with a small screw driver.
Step 5- Pull up spout to remove it to replace the o ring's on shaft. Also if it has a sprayer the diverter is in the base near the bottom. A little round brass diverter for sprayer.
Step 6-Install o rings for spout on base and diverter for sprayer if it has one. Plumbers grease will make install of spout easier to go back onto base. Now you can reinstall spout back onto base .
Step 7- Install new seat's and spring's with a small screw driver. Line screw driver to port and let spring and washer slide into place and press it gradually into place to seat in.
Step 8- Install new ball and notice that it has a groove in it to line up in valve.
Step 9- Install washer and plastic cap with slot in proper space.
Step 10- Install cap and tighten and adjust retaining ring to tighten up movement from spout from side to side. At this point you can turn water back on to make sure you have no leaks before tighting handle in place.
Step 11- Install handle and you're in business, and have rebuilt your very first faucet with knowledge to tackle the next plumbing project. Take your time and look closely how everything is put together, so you will know how it goes back together.
on May 28, 2010 | Plumbing
Tip
How to rebuild a single handle detla faucet.
If you have to draw a diagram of the faucet and how you disassembled it.
on May 24, 2010 | Plumbing
I used different length supply lines because th hot water line was a little short. Would this cause the side sprayer to move when the main faucet is turned on or the faucet head to drip?
No the length doesn't matter. When you turn the faucet on, you also fill the hose to the sprayer, and it may expand slightly, causing the sprayer to move a little. Is the drip from the end of the spout at the aearator? or is it around the faucet lever. If it is the lever, you should be able to tighten it slightly. If it's the end, make sure your aearator is clean.
Jul 18, 2010 | Kohler Fort© Single Lever Handle Kitchen...
Low water pressure from faucet, but plenty of pressure in water lines.
1-Remove aerator from end of faucet spout to check to make sure it is not obstructed by anything. Grit builds up there and causes flow to decrease , but it can be taken appart and cleaned out.
2-If you have a sprayer attachment to it sometimes the diverter goes bad. This sends water to spray head.
Cut water off remove handle with allen wrench and loosen collar on top to gain access to remove spout. after removing handle and collar you can pull up on spout or work it side to side easily to remove it.
In the middle at the bottom it has a removeable diverter that can be removed and replaced.
If it comes appart it will restrict water flow.
3- If you have to remove faucet to make sure no obstructions any where esle.
I hope this may be some help for you to have a starting point.
May 20, 2010 | Kohler Fort© Single Lever Handle Kitchen...
Tip
Ball-Type Single Lever Faucets
BALL-TYPE SINGLE-LEVER FAUCETS
  • The single-handle faucet with a ball inside to control both hot and cold water may either leak at the spigot or at the handle. A handle leak is usually caused by improper adjusting-ring tension. Simply adjust the tension to stop the leak. Leaks at the handle can also result from a worn cam gasket. Dripping from the spigot is usually caused by worn spring-loaded, soft rubber seat assemblies.
  • Parts for ball-type faucets are available in kits. Get the spring/seats kit for spigot leaks, or the complete kit for handle leaks. It may be advisable to use the complete kit to replace all working parts of the faucet at the same time. In any case, you'll need a kit containing the spanner/hex wrench for removing the handle (hex end) and turning the adjusting ring (spanner end).
  • Without turning the water off, loosen the handle set screw. Slide the handle from its stem.
  • For a handle leak, try using the spanner wrench to tighten the adjusting collar. Tighten it by turning the wrench and collar clockwise until the faucet doesn't leak when it is turned on and off. If the adjustment is too loose, the faucet will leak. If you turn it too tight, the handle will be hard to move. When the adjusting ring cannot be turned with the wrench, it is corroded. At this point, you will need to remove the cap to free the adjusting ring. (See next step.) You must turn the water off before removing the cap! Apply penetrating oil to the threads, remove the ring and clean all parts before reassembling.
  • Install the seats. For faucet leaks at the spigot, you must install new rubber seats and springs. You must turn off the water to make this repair. Unscrew the chrome cap by turning it counterclockwise. If it won't turn easily, wrap electrical tape around the cap and turn it with pliers. The adjusting ring, which is threaded into the cap's center, will come off with it. For a seats/springs replacement, pull the ball up and out by its stem. The gasketed cam will come with it. Now you can locate the two rubber seats and springs inside the faucet body. Remove them with pliers or yours fingers and install the new ones. The springs go into the holes first, and the cupped sides of the seats fit over the springs.
  • Service the ball. If the ball is dirty or coated with scale, clean it or replace it with a new one. Both plastic and brass balls are available, but use a plastic one if your home has hard water.
  • Reassembly. Put the ball and cam back into the faucet with the slot in the side if the ball fitting over the pin in the faucet body. Then make sure the tab on the cam slips down into the notch in the body. Not aligning the tab and notch is the number one cause for a faucet leaking after it is repaired. Finally, screw on the cap and adjust the ring as described in Step 2. If a properly adjusted ball-type faucet leaks at the cap, the cam and gasket must be replaced.
  • Swing spouts. If a single-lever ball faucet leaks at the base, you should replace the O-rings. Remove the spout-retaining parts, as well as the spout. Wrap the spout-retaining nut with electrical tape to protect it, and remove the nut with a wrench or pliers by turning counterclockwise. Remove the spout by pulling it up and side-to-side. One or more O-rings should now be exposed. Take the O-rings to your hardware or home center store to get matching O-rings for replacement. Clean any scale that appears on the spout base, faucet body, and the inside of the swinging spout. Install the new O-rings and reverse the steps above to reassemble the faucet.
on Jan 16, 2010 | Plumbing
PTO Tension JD 155C
Look between top of deck and bottom of machine for a rod coming from the rear topside of deck and going up to bottom of machine.Where it connects to machine there is a small pin you must pull to disconnect it.Once done loosen locknut and turn collar in,away from nut,3 or 4 turns to give PTO lever more pull.Tighten locknut,put rod/collar up and over crossbar and into hole it came out of,install pin.You may need to move PTO lever as if you were going to engage blades to help collar line up with hole.
Jan 09, 2010 | John Deere 48 in. EZ Trak Power Flow...
Moen kitchen faucet spout
Dec 13, 2009 | Moen 7310 Legend Single-Handle Kitchen...
2009 kawasaki klx 250 - need correct procedure for front wheel removal
•Using the jack under the frame, and stabilize the motorcycle.
Special Tools - Jack: 57001–1238
•Loosen the left and right axle clamp bolts •Unscrew the axle nut . •Place a stand under the engine to raise the front wheel
off the ground. •Remove the axle, and pull out the wheel. Take off the
collars and caps from each side of the front hub.
CAUTION
Do not lay the wheel on the ground with the disc
facing down. This can damage or warp the disc.
Place blocks under the wheel so the disc does not
touch the ground.
•Insert a wood wedge between the disc brake pads this
prevents them from being moved out of their proper position,
should the brake lever be squeezed accidentally.
Front Wheel Installation •Apply grease to the seals. •Fit the projection on the cap to the groove on the collar. •Install the caps , collars on the left (longer collar)
and right (shorter collar ) side of the hub. •Insert the axle from right side. •Unbolt the right and left axle clamp bolts temporally. •Tighten the axle nuts •Tighten the left axle clamp bolts.
Torque - Front Axle: 78 N·m (8.0 kgf·m, 58 ft·lb)
Left Axle Clamp Bolts: 20 N·m (2.0 kgf·m, 14.5
ft·lb)
NOTE
○Tighten the two clamp bolts alternately two times to ensure
even tightening torque.
Oct 13, 2009 | 2006 kawasaki KLX 250
Dripping shower head
If it is dripping from the connection where it goes to the water spout you can unscrew the connection and wrap teflon tape or Pipe Joint Compound on the Threads. Now you can Thread the Shower Head Back on, with No Leak. IF..... It is leaking from the Shower Head Itself There May Be a Problem with the diverter handle/lever. If it has a Pull Type Lever, sometimes you can screw the Lever up or down for the proper water restriction to the Shower Head. However if the Hot and Cold Handle/Lever is OFF, There should not be any Water coming out from anywhere! If water is coming out off the Tub Spout, with the Shower Off, then you will have to replace some washers or Cartridges in the faucet(s) to stop the dripping. You can do this easily....Just Ask) Remember though, that some shower Heads may Drip for a Few Minutes After they are Turned off. There is still water in the Supply neck and needs to escape, either though the tub Spout or Shower Head.......Hope this Solution Helps you with your Drips.....Joe
Jan 25, 2009 | Grohe Aquatower 3000 Shower Tower...
Moen Inc. CHROME 1H KITCHEN FAUCET CA87007" Logo
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
