Question about Dalen Gardeneer srho-4 solar rotating head owl
I purchased a Dalen Gardeneer srho-4 solar rotating head owl. It blew over and the head fell off. I have not been able to re-mate to the owl body so that it will rotate and bobble in the slightest br
Head fell off a new Dalen Gardeneer srho-4 solar rotating head owl I recently purchased. I am unable to reattach the head so that it will once again operate as advertised. I did not find any broken pieces of the rotating mechanism under the head. Can you help to repair.
How to remove the head of a Giottos camera tripod
Most tripods have a 1/4" thread attached to the centre column, which then screws into the base of the head (some may have a 3/8" thread, but the principle is the same).
Grasp the head firmly in one hand, the shaft firmly in the other, and rotate the head counter clockwise to remove the old head. If it has been in situ for some time, it may be stiff to rotate.
Once you have removed the old head, lubricate the threads on the centre column, then attach the new head, rotating this one clockwise.
If the old head will not unscrew under firm manual pressure, remove the centre column and place in a vice, packing it with wooden battens to protect it. Then attempt to unscrew the head, using a mole grip or similar if necessary.
Sep 12, 2016 | Giottos Photography
Limerick based on Lears nursery rhymes
There was an Old Man with a beard,
Who said, "It is just as I feared!-
Two Owls and a Hen,
four Larks and a Wren,
Have all built their nests in my beard."
There was a Young Lady of Ryde,
Whose shoe-strings were seldom untied.
She purchased some clogs,
And some small spotted dogs,
And frequently walked about Ryde.
There was an old man in a tree,
Whose whiskers were lovely to see;
But the birds of the air,
Pluck'd them perfectly bare,
To make themselves nests on that tree.
not terribly good in my opinion
Feb 17, 2014 | Sanyo 7200W Solar Grid Tie System - 32...
The tiny hose for the steam has fallen off how do I fix this problem
you need to replace go to www.eurovac.com and buy it.
God bless you
Jul 06, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have lost the battery cover to my Night Owl Optics. Where can I purchase another.
Check with Night Owl Optics. The company is located in El Paso, TX. They might sell you one, if not duck tape very well. stewbison
May 29, 2011 | Night Owl Optics Explorer NOCX3 Monocular
I NEED THE TWO BUTTONS FOR MY NIGHT OWL OPTICS, THE RUBBER BUTTONS FELL OUT, WHERE CAN I GET THEM.
you mean that Red Star glue doesn't work. Call Night Owl Optics in El Paso, TX. See if they will sell you the rubber button covers. If not, contact me and I will find something to make you a button cover. stewbison
Apr 19, 2011 | Night Owl Optics Cyclops Compact NOCC3...
Where can I get a manual for the Night Owl NOXM-50? I bought the last one at a store and I did not get a manual or warranty with it.
Hello, Night Owl Optics in located in El Paso, Texas. Give them a call or look up their web page and see if the PDF downloads. Do you have the receipt of purchase on this Nigh Owl NOXM50?
If not, forget about the warranty. GB....stewbison
Dec 24, 2010 | Night Owl Optics NOXM50
My Salter Electronic scale (3007) got soaked and is giving incorrect / unstable readings. I am trying to take it apart ASAP to dry the board, contacts, etc. but cannot work out how to detach the weighing...
The weighing pad mates with a circular metal plate underneath and needs to be rotated clockwise to unclip from the metal plate. Peel back the lower right corner of the instruction label on the bottom. This reveals a hole through which a philips head screwdriver needs to be inserted to loosen a screw which then allows the weighing pad to be rotated. The screw only needs to be loosened, not removed.
Sep 02, 2010 | Salter 3007 Aquatronic Digital Scale
I purchased a philips norelco 8150XL shaver and have been using it for a month. I hit the power button one day and heard a click sound, but no rotation of blades. When I pop the head of the shaver, motor...
It sounds like one of the heads is damaged and causing it to 'lock up'. Remove each of the heads one at a time and turn the blade inside of the comb with your fingers. They should move freely. I suspect that one will not rotate. If this is the case, you will need a new set of heads. You will find them at shaveroutlet.com. See link belwo
http://shaveroutlet.com/norelco-philips-hq9-replacement-heads-p-252.html
It is also possible that the retainer could be installed wrong. Make sure that the heads are in proper position and that the retainer is undamaged and put correctly in place
Mar 10, 2010 | Philips Health & Beauty
Dalen Gardeneer srho-4 solar rotating head owl Logo
476 people viewed this question
Top Dalen Gardeneer Home Experts
john h
Tom Chichester
Are you a Dalen Gardeneer Home Expert? Answer questions, earn points and help others
