Question about Welding Tools
Lincoln weld pak 100, no heat penatration on the D setting
I used to be able to weld badass welds on any size of metal with my Lincoln weld pak 100. now its like it is stuck in the A setting when I am using it in the D setting, the wire speed is down low between 2 and 3 and nocking the trigger back. and I noticed its blowen the 20 amp breaker at the fuse box after 5 mins of welding, and the thermal switch doesn\'t seam to be working when U push it in it stays out do U think the thermal switch is the problem?
  • mark martin
    mark martin Mar 20, 2014
    lincoln weld pak 100 is capable of welding way out of those so called pyramiters. grind out V,then heat,then mutible pass welds,its 1 bad little welder. I have gotten my moneys worth out it and then some.
  • 407 Answers
I believe your voltage control rheostat (potentiometer) must be worn out. Check your owner's manual for the part number and request it, it's not expensive and it is an easy part to replace. If you are doing that would be a good idea to do the same for your speed control rheostat.
Or clean them if you can, take off all the carbon particles that it build up with the time.
Posted on Mar 31, 2014
2 Suggested Answers
97F350diesel
  • 1326 Answers
SOURCE: My lincoln welder lost its heat penetration
It only produces 100amps. You can only weld thinner metal 3/16" comfortably. Any thicker will resuld in less/no penetration.
Posted on Sep 22, 2009
Weld-pak 100 Hd Problem
There is a reset button located in the wire feed spool compartment,
check to see it stays in when pushed. It is a safety when the machine
overheats, it normally resets when machine cools off. If it is working properly I suggest contacting Lincoln Electric Dealer for service.
Mar 03, 2012 | Lincoln Welding Tools
Lincoln precision tig 225. Makes bad aluminum welds in AC. Welds show signs of contamination. Have tried new argon bottle. No leaks in gas lines. Using pure and 2% thoriated tungsten, 3/32, pure...
Hello; Make sure AC Auto Balancing is Enabled; And when Welding Aluminum Aways use 100% Pure Green Coded Tugsten.Make Sure you dont have 75/25 or possibly if you know for sure your frequency balancing on your machine is working you could possibly have a bad bottle of gas try the bottle of gas on the machine that you say that runs good if it runs good put it back on the 225 if the problems still exist there is something wrong with your machine`s Ac high freqency Auto Balancing.Make sure all connections are good,check tig head for loose connections. Step Up to A 1/8 size tugsten it will carry more heat and gets less contanimated.Every time you stick your tugsten it will run contanimated untill you burn it off or clean it ,if you stick you tugsten go ahead and put a clean piece back in the tig head, Contanimated tugsten wil run dirty for 5 to 20 minutes Untill you BURN it Back Clean !?
Sep 03, 2011 | Lincoln Precision Tig 225 Ready Pak With...
I have a lincoln power mig 255 and every time i weld little holes appear in the welds. what could this be?
Hi:
This could be a problem of gthe gas you are using. Make sure to use mix 75/25 argon/CO2 for mild steel welding, argon 100% for aluminum and trimix helium/argon/CO2 for stainless steel.
Also check your heat (voltage) 16-22 is enough for weld of most steels less than 1/2 inch.
Aug 06, 2011 | Lincoln Magnum 100L 10' 025035
ARC 100, 115v, 60HZ, 20A. When I run a beed, the
With these smaller machines you have a common problem. The way to get the weld to hold is on thicker material you have to sometimes pre-heat the metal in order to get it to stick. Also if ther is no flux nor gas the material has to be clean, free of dirt, oil, and rust. These machines are for very light use only. For welding material over 8 th inch, I suggest investing in a welder with at least 100 amps
Jul 25, 2011 | Lincoln Welding Tools
What gauge exstention cord do i use for a lincoln weld pak 100?
Hi:
Weld pak 100 is a 120 volt unit, you will be ok with a gage 12.
Most 120V commercial extensions out there are 14 gage, if you want to buy one, choose no longer than 25 ft long.
With a 12 gage you can go to 50 ft. with no problems.
If this was useful to you please vote. Thanks.
Mar 27, 2011 | Welding Tools
I have a Lincoln Weld Pak 100 that was working fine. I shut down the machine though and when I came back to it about 5 hours later the wire feed motor wouldn't turn anymore. Has anybody else had the same...
Check the voltage at the wire feed motor when the trigger is pulled.
I had a Weld Pak 100 that with 0 volts at the wire feed motor, and the problem wound up being that 2 of the big power (stud) diodes were shorted.
Feb 26, 2010 | Welding Tools
Mar 17, 2009 | Welding Tools
Welding Tools Logo
158 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
