Question about Samsung DMR77LHS Tall Tub Dishwasher
Fuse location on dmr77lhs/xac
Pictures or video for location of fuse
I have a Samsung floor model TV model number HCP4363WX/XAC I think it's the color aliment but picture looks fuzzy it kinda looks like it 3D how do I fix this issue.
That tv is a rear projection tv. It uses 3 CRT tubes that are Blue, Red, and Green and converges the pictures on top of each other. The convergence chip needs to be replaced. Samsung Akai Projection TV Repair Kit for one or more of the following...
You can order the repair kit from here and it comes with step by step instructions for the repair. I have personally used them before with a lot of success.
Jan 25, 2017 | Samsung Televison & Video
Samsung hpt4264x xac won't turn on
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_14_2012_3_24_00_pm.jpg
May 14, 2012 | Samsung Televison & Video
Samsung DMR77lhs drain pump wiring
The orange lead goes on the connector on the edge of the pump. The white lead goes on the connector toward the middle.
Jan 08, 2012 | Samsung DMR77LHS Tall Tub Dishwasher
I have a Samsung HLP5663WX/XAC. I have sound but no picture. The lamp light is blinking and I can't turn the power off unless I unplug the tv. Any help would be good.
This kind of symptoms indicated that the DMD module is loading down the control bus and stuck to this process. You have to replaced it part no. BP96-00678A. I saw your board at Ebay.com.
Hope I helped you.
Have a nice day!
Jdvillanueva
Dec 12, 2011 | Samsung DLP HL-P5663W 56" TV
Trying to find exactly where the fuse is on the Samsung DMR77LHS dishwasher - I have the right panel off but I see no fuse - is it in one of those 2 black boxes? Samsung CS Dept is the single worse,...
Hello, randmanx
I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Sep 22, 2011 | Samsung DMR77LHS Tall Tub Dishwasher
My Samsung DMR77LHS dishwasher has lost power completely near the end of a cycle. About an inch of water remains. I have power to the unit. I checked the 15 amp fuse in the unit - it had blown. I replaced...
Hi, whenever a fuse of that magnitude, or any fuse really, Blows, you should never just replace it, as to have any device, blow a fuse, trip a breaker, requires a major fault, they do NOT blow spontaneously ever. So you have had a major short circuit inside your machine, at some stage, usually this is in, the main Controller Board, most likely the bridge rectifier has gone short circuit, or a capacitor, But it could be anything even the motor?anything like this then will blow the fuse. The reason the fuse blow is to prevent a fire and explosion or both, as if an unlimited amount of current could be drawn, it would be catastrophic, so a fuse blows to disconnect the power. The Cause of this MUST be discovered before one ever attempts to replace the fuse. Luckily, it seems in this case the fault has blown an open circuit on the main Board, and this has prevented any further trouble.
Really after such an event as this one should engage the services of a professional, as anyone untrained may mis something that later on my even prove fatal. Get this unit looked at by a professional service person, ask for a 'Quote" if concerned about costings, then you can make an informed decision as to what to do.
Your support site is below,
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP06&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=DMR77LHS
Sep 14, 2010 | Samsung DMR77LHS Tall Tub Dishwasher
My Samsung DMR77LHS dishwasher has NO power showing on display board, checked electrical hookups it ok. Outlet has power. Pressed Power On/off button, no response, all lights are off...
hti had athe same problem, and the fuse fixed it. it turns on now,
you can get to the fuse casing, small tube about 1.5 inches , black, by flowing the electrical line to the, inside , or the under carriage, on the side of the bottom of the unit.
15 amp 250 volt at radio shack.
Sep 12, 2010 | Samsung DMR77LHS Tall Tub Dishwasher
Samsung YP-S3JAB/XAC mp3 player
GOT IT!!!!!
let it convert and try to transfer.....after it reports failed to transfer, go to default folder for converted file(win7 is documents/video/emodio/videos) copy to s3/s3/video.
done
Nov 08, 2008 | Samsung YP-S3JAB Digital Media Player
Samsung DMR77LHS Tall Tub Dishwasher Logo
50 people viewed this question
Top Samsung Dishwashers Experts
vince
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
