Question about Maytag SkyBox MBV1976A Beverage Dispenser
Need a new wire harness for dispensing buttons
The wire harness that operates the dispenser button is burnt out I have contacted matag the same year I bought it from them and they state that do not make replacement parts it has now been 10 years that I have been looking for a solution to this issue instead of having to open the door every time I want a beverage
    Top Expert:
  • Maytag Master
  • 76,682 Answers
Sorry we have no wiring harnesses or any parts for anything.
Posted on Mar 21, 2014
chadschloss
  • 11 Answers
SOURCE: Skybox won't dispense anything
check the door where the cans come out. there is a sensor or the left side. if it is too far away from the door or if it's broken, it will do exactly what you said. i read somewhere that you can adjust the sensor closer to the door. i just bought one of the last one of these on the shelves 2 days ago and mine won't cool at all. stupid maytag..
Posted on Mar 08, 2007
SOURCE: won't dispense
I had the exact same problem. I installed a new flapper door switch and it is now working. Here's the order info from partselect.com:
Item
Number
Description Availability Shipping
Method
Unit
Price
Quantity
Ordered
Extended
Price
PS901892 BOARD, FLIPPER DOOR P In Stock 3-5 Business Days $14.81 1 $14.81
Posted on Dec 31, 2007
  • 6 Answers
SOURCE: cannot get soda to dispense
Check tip on Skybox home page.
Posted on Jan 17, 2008
Master_Tech
  • 770 Answers
SOURCE: Dispenser will not cool on the highest setting
I have a service manual on the sky box post your email and i will send it to you
Posted on Mar 15, 2008
SOURCE: Lights flash, but no beverage dispensed.
Check for jam or to see froze up
Posted on Aug 18, 2008
I have a Matag MSD2458GE refrigerator. Water dispenser on the door works but, the ice maker doesn't work at all. Seems no water reaching it. Needs new filter, but no ice before replace filter light.
According to your user's manual, "If water flow to the ice maker or dispenser decidedly decreases or if an objectionable taste or
odor returns,change the filter sooner than
recommended."
"Leave the refrigerator door open while removing and installing filters or plugs; this will prevent water
from flowing through the system and running into
the fresh food compartment.
• A newly installed water filter cartridge may cause
water to temporarily spurt from the dispenser"
Automatic ice maker not operating
the stop arm in OFF (up) position
•the water supply turned off
•the water pressure too low
•the freezer too warm
Ice dispenser not operating
ice jam in the dispenser
•ice maker not operating
• lock switch on (see page 11)
Water dispenser not operating
• water pressure too low
• lock switch on (see pg. 11
To locate an authorized service company in your area,contact the Maytag dealer from whom your appliance was purchased; or call Maytag
Appliances Sales Company,Maytag Customer Assistance at the number listed below. Should you not receive satisfactory warranty service,please
call or write:
Maytag Appliances Sales Company
Attn:CAIR
Center
P.O. Box 2370
Cleveland,TN 37320-2370
U.S.
1-800-688-9900
CANADA
1-800-688-2002
U.S. customers using TTY for deaf,hearing impaired or speech impaired,call 1-800-688-2080.
Feb 24, 2017 | Refrigerators
No water from dispenser Matag New filter solenoid valve working, tube to dispenser seems to be blocked
Hello Hans;
My name is Peter. I am a retired field service refrigeration technician.
There could be several areas that would effect your water dispenser not working:
1.) When you depress the water dispenser do you hear a 'Click'? If not you have a bad water dispenser contact switch.
I would send you a diagram but I do not have your model number.
2.) In the lower back of your fresh food section is your water dispenser water tank. At times this can freeze near the freezer section. Look in the lower corner of the freezer & your fresh food section for ice build-up.
3.) You could have a bad water filter. This does happen often. Remove the water filter and test you water dispenser.
4.) Do you have water leaking out of the bottom of your dispenser door? If so you have a split in the tubing in your water dispenser door.
5.) Is your ice maker working? Often the water valve to your refrigerator becomes plugged up and you do not get sufficient water pressure 60 PSI to operate your water dispenser solenoid valve.
Nov 15, 2014 | Maytag MFD2561HE Stainless Steel Bottom...
My Matag water dispenser is behaving strangely. When I press the dispenser button, water flows for about one second, then stops, and seems to switch briefly to ice dispensing before resuming water flow for...
Hi Alan,
You need to check the wires on the back of the dispenser console to be sure that they are seated correctly. If the wires are all OK, you will need to replace the display console. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 08, 2012 | GE GSH25JFR Side by Side Refrigerator
Lock out light is on ice and water dispenser of whirlpool GS5SHAXSB01 refrigerator and will not turn off. Is there a bypass?
Had the same problem. I slid out the tray at the bottom of the dispenser, removed two screws, took off the face with all the buttons on it to expose the wiring. I disconnected the very thin wire harness that supplies power to the buttons and reconnected it. I reinstalled the face, pushed and held the lock out button. This worked for me.
May 17, 2012 | Whirlpool Refrigerators
Washer was just moved to a new house and doesn't work. It has F-13 code.
F13 Dispenser circuit error
Possible causes/procedure:
1. Unplug washer or disconnect power.
2. Check mechanical linkage from dispenser motor to the top of
the dispenser.
3. Check wire harness connections to the dispenser motor and
Central Control Unit (CCU).
4. Check dispenser motor for powered rotations.
Jul 02, 2011 | Washing Machines
My 7-button Frigidaire Gallery ice/water module is not lighting up and not functioning. No ice or water is being dispensed. Wiring harnesses seem to be all intact.
Hi
If freezer door switch is not working, dispenser won't work. Does the freezer light go off & on when door is opened & closed? If you have a voltmeter, check that water valve is getting 120 volts when dispenser is pushed in. If no voltage, I would suspect the micro-switch that you hear clicking when you push in with a glass. Even though it clicks, the contacts could still be bad in it. However other than that loose/off wire, ribbon cable for front buttons off/loose, bad board, child lock are something that can make the dispenser dead.
Please check the bellow link if it helps:-
http://www.ehow.com/how_6494535_troubleshoot-frigidaire-icemaker.html
http://www.ehow.com/how_6557721_troubleshoot-frigidaire-refrigerator-icemakers.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 29, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
The inside water spout on this refrigerator stopped dispensing water
Checckwater pressure.The 1/4" water supply line should deliver at least 9 ounces of water in 5 seconds. If not, the water pressure is low. Make sure the dispenser is notlocked. Some models have a lock feature that deactivates the dispenser andcontrol buttons. The lock button is located on the dispenser front cover.This feature controls unintentional dispensing. Press the"Unlock" or "Locked" button to reactivate the dispenser andallow dispenser function. You may need to hold the button for2 to 3 seconds. A clogged or incorrectly installedwater filter will reduce the water flow to the water dispenser. Check for aproblem with the filter by removing the filter and operating the dispenser. Ifwater begins to flow, then the filter is either clogged or incorrectlyinstalled. A clogged filter will need to be replaced. Thanks.
Feb 03, 2011 | Amana ARB2259CS Bottom Freezer...
No ice or water from GE Profile side by side refrigerator freeze
I had this problem and did 3 things to correct it:
1st: I changed out the Main Circuit Board in the back of the fridge.... very easy to do, but that wasn't the problem.
2nd: I changed out the Dispenser Circuit board, which is behind the touch panel. Also very easy to do, just snaps out. but that also wasn't the problem
3rd: I checked the wire harness connection point located behind the grill at the bottom front of the fridge underneath the freezer side. This is also very easy to do, and son of a ..... that is what is was. Moister from mopping the floor had started to corrode the connections. So I purchases a cheap 3 wire plug and cut out the old and spliced in the new. You don’t actually need the plug, you can hard wire direct but if you ever have to take the door off you will have to cut the wires.
So now I’m the proud owner of an extra functioning Main Circuit Board and Dispenser Circuit board if anyone is in need.
Nick
Jun 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag SkyBox MBV1976A Beverage Dispenser Logo
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
