Question about Magnavox NB500MGX BluRay Player
PROBLEM playing sd card
Sd card not reading movies
    Sergeant:
    Champion:
  • 266 Answers
The slot is for playing many, but not all SD cards. What movies do you think it should "read"
Go to page 20 of the users manual
http://www.manualowl.com/m/Magnavox/NB500MGX/Manual/254277?page=20
Posted on Mar 21, 2014
Put films on my 32 GB sd card
Use Windows Explorer (or equivalent) to copy the movie files from your hard drive to the SD card
Jul 10, 2016 | Cameras
My fujitsu m532 can't play movies from sd card
My suggestion would be to look at the format of the movie files you're trying to play and search for a movie player app that matches that. If one exists then download, install and open file from SD card with that app. If for example file type is "*. flv" then search for "flv player for android".
My guess is you don't have an app on the tablet that is compatible with the movie file type. Hope this helps.
May 23, 2014 | Fujitsu STYLISTIC M532 Tablet
Mi pictures in my zte phone are not showing up why?
You may have corrupted the SD Card. Try shutting down the phone and remove the card. then re-install, If you have another device that will read it try that. And of course go to your file folder and see if your SD card is visible. Also try another SD card. Hope this helps Let me know Thanks!
May 14, 2014 | ZTE Score
Acer sd card
are these movies brought from google play store if so these cannot be saved to the sd card
Jan 14, 2014 | Acer Iconia B1-710
I cant play some blu-ray disc how can i get some of them to work
since it doesn't have enough RAM in it, some BDs or larger multi-layer DVDs fail to play/load entirely Its slow to buffer BD, and even slower to upscale DVDs. It doesn't support homemade DVD+/-R movies. It also doesn't support video on CD.
SOLUTION:
to get the movie to play add a 4GB SD card into it and format it for use as extra memory. Apparently, some BDs require a lot of memory. By adding the SD card, DVDs and THE BDs load faster and have no play problems. The overall downside to the RAM issues and the SD card is that, when the SD card gets full,you will have to reformat it to get anything to play. Tho, all lost disc info needs to be rebuffered onto the card the next time you watch the movie.
Mar 06, 2011 | Toshiba BDX2000 Blu-Ray Player
It goes to a black screen with a yellow sign with a arrow on it pointing down, it also has a green, yellow, and red bar at the bottom.it stops at the red.
Had this same issue. Your probably trying to play either Crank2 or StarWars. Talked to Panasonic Tech Support and they said not enough memory to play disc and gave me these instructions:
"This movie title requires that an SD card of 128MB or larger to be inserted into the BluRay player prior to inserting the BD disc each time you watch this movie.
The SD card must be formatted in the BlRay player before use. (Do not format the SD card on your PC)
Formatting an SD card in the player:
-Insert an SD card (1GB or higher) into the SD slot of your BluRay
-Press [FUNCTIONS], select "other Functions" and press [OK]
-Select "Card Management" and press [OK], then follow the on-screen commands
Once formatting is complete, leave the SD card in the SD card slot. Insert the movie disc into the BluRay player and it should play normally."
Personal note, the bar graph that has always stopped at the red will hesitate for quite a while and then the rest of the bar will fill up and BD will begin to play.
Oct 04, 2009 | Panasonic DMP-BD30K Blu-Ray Player
Copy avi format movie to SD card, Wii will not play it. why?????
The Wii does not have video playback capability. It is simply not a feature of the console.
Jan 03, 2009 | Nintendo Wii Console
I have a technika View box sp-108 which alows you to view your ipod videos etc on the 7" screen. it also doubles up as digital picture frame allowing you to load mp3 video and jpeg photos from flash...
Make sure you don't have to many folders or sub folders, best to keep it simple.
Wipe the card and format it as "FAT" not "FAT32" just right click your usb or SD card in vista or XP and select format.
Drop your MP3 album onto the card, If you use your USB Stick and SD card at the same time then it will default to SD and not play from both.
I found it would not read from one card unless I had a playlist, so I used a free program called Playlist creator 3 - get it here (only relates to MP3's)
http://www.soft32.com/download_66536.html
I dropped and xvid movie onto the SD card and it played fine, just make sure you are in the correct menu 1st! and the movie isn't in some very old format as it may not play all codecs (encoding used to make movie)
Hope this helps
Sep 22, 2008 | Audio Players & Recorders
Expansion slot for sansa
It should work if it was made by Sandisk and if it is a Micro SD memory card.
Jan 26, 2007 | SanDisk Sansa e250 MP3 Player
Magnavox NB500MGX BluRay Player Logo
127 people viewed this question
Top Magnavox Televison & Video Experts
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
