Turn on touchpad on
Touch keys wont work buti can use the mouse
    Master:
  • 397 Answers
Do you mean the mouse buttons below the touchpad do not work but the actual touchpad does? If so I would try removing/reinstalling your touchpad drivers. If that holds no success I would consider replacing the touchpad hardware.
Posted on Mar 20, 2014
3 Suggested Answers
sasha_groves
  • 68 Answers
SOURCE: Touchpad and cursor keys quit working
I used to get this problem. It is VERY annoying as you must know. try pushing the windows icon button in the top right corner of your keyboard(thats where it is on my keyboard)then use your arrow keys to scroll up to control panel, select mouse by using arrow keys and then use the tab and arrow keys to open the mouse keypad pagetab and push enable and enter key to turn it on.
IF WHEN YOU DO THAT AND your in the touchpad properties but there is no 'enable' and it says no hardware detected, then go into the same mouse window from the control panel and go to the hardware tab and either try to update driver or use the trouble shoot button.
Hope this helped =]
Posted on May 27, 2009
walesarumi
  • 6993 Answers
SOURCE: The left key on my dell touchpad is not working
that part of the touch pad is not working anymore, its faulty and you need to replace the whole touch pad.
I don't know why this is mostly common with Dell. My friend has a Dell inspirion 1501 and the touch pad has exactly the same problem as yours.
I would advice you get a USB mouse to keep you going pending the time you get the touch pad fixed.
I wish you the best of luck.
Posted on Jan 06, 2010
I turned off my touch pad to my acer aspire 5733z and it wont turn bk on
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works.
Press the combination at any time to disable the touchpad again.
hope this helps
Sep 16, 2012 | Acer Aspire 5733z-4851
Touchpad works left and right but clicking wont works
Hi
Some touchpads need harder ( not soft ) touches
you can do that, or press the mouse keys instead of clicking the touchpad
Please tell us your results
Good Luck
May 13, 2011 | Computers & Internet
My touchpad has stopped working and the only way i can properly use it, is by plugging in a computer mouse. The touchpad allows me to move the mouse arrow icon all over the screen, but when trying to...
You can turn on "tapping" and will be able to tap instead of click. It seems like hardware problem. Take the computer apart and check the flat cable from the touchpad to the motherboard. Check with a mutltimeter whether the buttons are making contact on click.
Aug 08, 2010 | Computers & Internet
Satellite P505 Model S8980 - unable to get TouchPad to work now where it did work before. The TouchPad ON/OFF button nor the Fn+F9 approach are no help. A USB-connected mouse worked fine, tho. Just no...
----- control panel - mouse - see if touch pad disabled there ----- have a look in the bios/setup and see if the touch pad is disabled there, as the PC boots - you should see which key to use to enter the bios/setup F2, F10, DEL KEY are often used ----- On some machines a combination of FN and F key can disable/enable the touch pad - F7 or F9 ----- If you point the mouse to the top of the screen you may get a menu dropdown, which will also tell which key to use to disable/enable the touchpad ----- control panel>system>{vista}lefthand side device manger or {XP}hardware>Device Manager>Mouse and other pointing devices>Touchpad>highlight touchpad and right click, Properties, may be an option here to Disable/enable,
Feb 18, 2010 | Toshiba Satellite P505-S8950 Notebook
Hope this helped =]
May 27, 2009 | Dell F3534 Touchpad
Lenovo touch pad not working properly
Have you tried pressing the Fn + F8 keys? This combination is used to disable and enable the mouse pad.
May 27, 2009 | Lenovo IdeaPad Y510 Core-2 Duo: Y510...
Touchpad on my easynote is enabled, how do i disable it?
Pressing F6 on your laptop will disable the touch pad or one of the F keys that has a picture of a finger.
Mar 22, 2009 | Computers & Internet
Whilst typing the cursor moves to another part of the document
If your laptop has the option too you can turn off touch pad through a switch above the touch pad.
If you can't find this, or you don't have one, simply go to the run command and type in devmgmt.msc, ok.
Once in the device manager go "Mice and Other Pointing Devices"
look for your touchpad, right click on it and select disable.
Please note, some laptops wont let you disable to the touchpad, mine wont, but mine has an on and off key.
ON/OFF Key
Touch Pad On
Touch Pad Off
This will keep the mouse from moving whole you type, but I suggest you get a regular mouse, especially if you have to disable the device with the Device manager.
Jan 05, 2009 | Computers & Internet
Touch pad center click button no longer works
Near your clock, you'll usually find an icon for your touch pad (probably synaptics). Open this & select mouse properties, in there look under Device Settings & try the "Reset Devices" icon.
If that don't work, Click start>control panel (classic view)>mouse.
On the Touchpad tab, make sure the 'tapping' box is checked . Click apply, click ok.
If that doesn't work, click start>run, type devmgmt.msc
and click ok.
Click the plus to expand Mice and Other Pointing Devices.
Right click and uninstall any mouse or touchpad listed.
Reboot.
Let Windows rediscover and reinstall the touchpad drivers.
Good Luck!
Jan 09, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
