Question about OE Aftermarket 1990 - 1993 Infiniti Q45 Camshaft Position Sensor W013
When should the Camshaft Position Sensor be replaced?
Engine Stalls Intermittently.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 123 Answers
Plug in a cheap OBD2 code reader. 9 pounds on ebay then enter the codes into a free app like
OBD2 Check Engine Fault Codes Android Apps on Google Play
This will allow you to see what is causing the stalls and allow you to reset the fault light.
Posted on Jun 14, 2014
What are the probable causes of camshaft sensor DTC?
Camshaft sensors do go bad. They can go bad slowly, so you don't notice the badness until your engine stalls, but restarts, or you get a "check engine" light. They are not expensive or hard to replace.
Nov 10, 2015 | 1999 Isuzu Rodeo
I have mercedes slk 230 and a code 391 keeps coming up and it stalls while driving sometimes can anybody tell me what it is? please?
Camshaft position sensor B bank 2 CKT range / performance.
Faulty Camshaft Position Sensor
Camshaft Position Sensor harness is open or shorted
Camshaft Position Sensor circuit poor electrical connection
Faulty starter motor
Starting system circuit
Dead (Weak) battery
Any of these could cause this fault code.
Aug 03, 2014 | Cars & Trucks
Engine Stalls or dies Intermittently while driving. Fuel injectors and fuel filter have been replaced.
had the same problem with 2003 silverado did everthing could think of.believe it or not ,put in new battery and solved the problem
Mar 20, 2014 | OE Aftermarket 1990 - 1993 Infiniti Q45...
Help
# P0016 Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor A)
# P0017 Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor B)
# P0018 Crankshaft Position - Camshaft Position Correlation (Bank 2 Sensor A)
# P0019 Crankshaft Position - Camshaft Position Correlation (Bank 2 Sensor B)
It's unlikely for 2 sensors on the same bank to go intermittently bad but I'd still try to rule out the sensors by swapping 2 sensors on bank 1 to bank 2 and bank 2 to bank 1. Clear the code, drive to see if bank 2 gets the code.
Jun 03, 2013 | Vehicle Parts & Accessories
2002 taurus 3.0L OHV stalls when hot have replaced IAC,camshaft position sensor,fuel pump and there are no codes on engine stall occurs most often when slowing and turning
If you have to wait to restart its usually a faulty coil or ignition module.
Someone would need to troubleshoot the ignition system when the engine fails to start to proceed. Could be a faulty relay too.
Sep 13, 2012 | 2002 Ford Taurus
P 0340 VECTRA 120CP
P0340 - Camshaft Position Sensor 'A' Circuit Malfunctionxicon.jpghttp://engine-codes.com/p0340.htmlForum CodePossible causes- Camshaft Position Sensor harness is open or shorted
- Camshaft Position Sensor circuit poor electrical connection
- Faulty Camshaft Position Sensor
- Faulty starter motor
- Starting system circuit
- Dead (Weak) battery Tech notes Sometimes and in some models, low battery voltage or a weak starter can can trigger a Camshaft Position Sensor code.
When is the code detected?The camshaft position sensor signal is not detected by the Engine Control Module(ECM) during the first few seconds of engine crankingSymptoms- Engine Light ON (or Service Engine Soon Warning Light)
- Lack/Loss of Power
- Engine StallP0340 Description The Camshaft Position Sensor is an electronic device used in an engine to record the rate at which the camshaft is spinning. This information is used by the Engine Control Module(ECM) to control ignition and fuel injection. The camshaft position sensor senses the retraction of camshaft (intake) to identify a particular cylinder. The camshaft position sensor senses the piston position. The sensor system consists of a rotating part, typically a disc, as well as a static part, the actual sensor.
Jul 06, 2012 | Cars & Trucks
My car is showing PO344 (Camshaft Position Sensor A Circuit Intermittent) as a problem it's having... I replaced the camshaft sensor about 2 years ago when I was having a similar problem; could the sensor...
All ways, the camshaft position sensor signal sent to the ECM is intermittent
The Camshaft Position Sensor is an electronic device used in an engine to record the rate at which the camshaft is spinning. This information is used by the Powertrain Control Module (PCM) or Electronic Control Module(ECM) to control ignition and fuel injection. The camshaft position sensor senses the retraction of camshaft (intake) to identify a particular cylinder. The camshaft position sensor senses the piston position. The sensor system consists of a rotating part, typically a disc, as well as a static part, the actual sensor.
When the engine is running, the high and low parts of the teeth cause the gap with the sensor to change. The changing gap causes the magnetic field near the sensor to change. The change in the magnetic field cause the voltage from the sensor to change.
When the crankshaft position sensor (POS) system becomes inoperative, the camshaft position sensor provides various controls of engine parts instead, utilizing timing of cylinder identification signals.
Check thos DTC diagnostic and possible solutions about P0344 - Camshaft Position Sensor Circuit Intermittent
Symptoms
- Engine Stall
Possible causes
- Harness or connectors (The sensor circuit is open or shorted)
- Camshaft position sensor may be faulty
- Camshaft (Intake) may be damage
- Starter motor may be faulty
Possible solution
- Charge battery
- Repair harness or connector
- Replaced Camshaft Position Sensor.
Tech notes
- Sometimes and in some models, low battery voltage or a weak starter can can trigger a Camshaft Position Sensor code.
Hope this helps.
Mar 27, 2011 | Dodge Stratus Cars & Trucks
My 1994 buick stalls only in drive what is this
Look at the simple stuff first such as spark and fuel pressure. Make sure all of the normal tune up items are taken care of such as plugs, wires, fuel filter, etc. Look at the fuel pressure and make sure that is up to spec. Also make sure the check engine light isn't on and there aren't any trouble codes stored.
If everything with the fuel system looks ok then I would look at possibly an intermittent problem with either the camshaft position sensor or the crankshaft position sensor. The Cam sensor should be located on the lower right of the engine, above the crank pulley.
The Crank sensor should be located behind the right side of the crank pulley. There could be an issue with the wiring for either sensor as well that is causing the vehicle to intermittently shut off.
Please donot forget to rate and accept my answer...
Apr 25, 2010 | Buick Skylark Cars & Trucks
1993 ford taurus, replaced all starting and charging componets still no spark to plugs. Checked all fuses and all fusible links. Replaced key switch, ignition switch,neutral safty...
The camshaft position sensor sends a signal to the PCM, powertrain control module. The PCM then determines spark plug firing. Could be the camshaft position sensor.
1996 is all I have
Camshaft Position (CMP) Sensor 3.0L (2V) Engine
The camshaft position sensor (CMP sensor) (12126):
  • is a single Hall-effect magnetic switch activated by a single vane which is driven by the camshaft (6250).
  • provides camshaft position information which is used by the ignition coil (12029) and the powertrain control module (PCM) (12A650) for fuel synchronization.
3.0L (4V) Engine
The camshaft position sensor (CMP sensor) (6B288) is:
  • a variable reluctance sensor.
  • triggered by the high-point mark on the LH exhaust camshaft sprocket (6256).
3.0L (2V) Engine
SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Syncro Positioning Tool T95T-12200-A
sth~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Prior to removal of the camshaft position sensor (CMP sensor) (12126), set cylinder No.1 to zero degrees top dead center (TDC) of compression stroke. Then note the position of the camshaft position sensor electrical connector. The installation procedure requires that the connector be located in the same position.
Removal
  1. Disconnect battery ground cable. Refer to Section 14-01 .
  1. Disconnect engine control sensor wiring connector from camshaft position sensor.
  1. Remove camshaft position sensor retaining screws and camshaft position sensor from camshaft position sensor housing.
  1. If removing camshaft position sensor housing from the cylinder block (6010), proceed with Removal Step 5. If not removing camshaft position sensor housing, proceed to installation Step 6.
  1. Remove hold-down clamp (bolt and washer assembly).
  1. Remove camshaft position sensor housing from cylinder block.
Installation
  1. sth~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: A special service tool such as Syncro Positioning Tool T95T-12200-A must be obtained prior to installation of the replacement camshaft position sensor. Failure to follow this procedure will result in improper camshaft position sensor alignment. This will result in the fuel system being out of time with the engine, possibly causing engine damage.
    Attach Syncro Positioning Tool T95T-12200-A as follows:
    1. Engage camshaft position sensor housing vane into the radial slot of the tool.
    1. Rotate tool on camshaft position sensor housing until tool boss engages notch in camshaft position sensor housing.
  1. Pre-lubricate synchronizer gear with engine oil meeting Ford specification ESE-M2C123-A prior to assembly.
  1. Install camshaft position sensor housing so that drive gear engagement occurs when arrow on locator tool is pointed approximately 75 degrees counterclockwise from the rear face of the cylinder block. This step will locate camshaft position sensor electrical connector in the pre-removal position.
  1. Roatate Syncro Positioning Tool T95T-12200-A clockwise slightly. This will engage oil pump intermediate shaft. Push downward while adjusting Syncro Positioning Tool T95T-12200-A until the Syncro Gear engages the camshaft gear.
  1. When synchronizer flange is fully seated against block, the installation tool should be facing counterclockwise of engine centerline approximately 33 to 45 degrees.
  1. Install hold-down clamp (washer and bolt) and tighten bolt to 19-30 Nm (14-22 lb-ft).
  1. Remove Syncro Positioning Tool T95T-12200-A.
  1. sth~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: If camshaft position sensor electrical connector is not positioned properly, DO NOT reposition the connector by rotating the camshaft position sensor housing. This will result in the fuel system being out of time with the engine, possibly causing engine damage. Remove the camshaft position sensor housing and repeat installation procedure, beginning with Step 1.
    Install camshaft position sensor and retaining screws. Tighten screws to 1.5-4.0 Nm (13-35 lb-in).
  1. Connect engine control sensor wiring connector to camshaft position sensor.
  1. Connect battery ground cable.
Item Part Number Description 1 T95T-12200-A Syncro Positioning Tool 2 — Water Outlet (Part of Intake Assy) 3 9424 Intake Manifold 4 N602704-S Screw and Washer 5 12126 Camshaft Position Sensor 6 12A362 Synchronizer Assembly 7 12270 Hold-Down Clamp A — Tighten to 1.5-4 Nm (13-35 Lb-In) B — Tighten to 19-30 Nm (14-22 Lb-Ft)
Apr 04, 2009 | 1993 Ford Taurus
1997 mercury sable camshaft sensor replacement
do you have 3.L 2v or 4 valve?
3.0L (2V) Engine
svh~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Prior to removal of the camshaft position sensor (CMP sensor) (12126), set cylinder No.1 to zero degrees top dead center (TDC) of compression stroke. Note the position of the camshaft position sensor electrical connector. The installation procedure requires that the connector be located in the same position.
Removal
  1. If removing camshaft position sensor housing from the cylinder blocks (6010), proceed with Removal Step 5. If not removing camshaft position sensor housing, proceed to installation Step 6.
  1. Remove hold-down clamp (12270) (bolt and washer assembly).
  1. Remove camshaft position sensor housing from cylinder blocks.
Installation
  1. svh~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: A special service tool such as Syncro Positioning Tool T95T-12200-A must be used to position the synchronizer assembly prior to installation of the camshaft position sensor. Failure to follow this procedure will result in improper camshaft position sensor alignment. This will result in the fuel system being out of time with the engine, possibly causing engine damage.
  1. Install camshaft position sensor housing so that drive gear engagement occurs. Locate camshaft position sensor electrical connector in the pre-removal position.
  1. svh~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: If camshaft position sensor electrical connector is not positioned properly, DO NOT reposition the connector by rotating the camshaft position sensor housing. This will result in the fuel system being out of time with the engine, possibly causing engine damage. Remove the camshaft position sensor housing and repeat installation procedure, beginning with Step 1.
    Install camshaft position sensor and retaining screws. Tighten screws to 1.5-4.0 Nm (14-35 lb-in).
Feb 22, 2009 | 1997 Mercury Sable
OE Aftermarket 1990 - 1993 Infiniti Q45 Camshaft Position Sensor W013 Logo
63 people viewed this question
Top OE Aftermarket GPS Experts
John Feinauer
John Feinauer
Level 1 Expert
Timllfixit
Are you an OE Aftermarket GPS Expert? Answer questions, earn points and help others
