Question about GE GSS22JET Side by Side Refrigerator
Need to rebalance refrigerator
The door will not stay open; it is off balance. Where do I find some way to fix it?
  • Susan Young
    Susan Young Mar 22, 2014
    When I open the refrigerator door to get something out, unless I open it all the way, it closes because the fridge is out of balance. It should stay open where I open it, not gravity making it close. I know there is some kind of fix somewhere on the fridge to fix the problem, but I dont know where it is. Thanks for any help!
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
Hi Susan ! If you look under the fridge at the front you can see the front two feet at either side. Both of these feet are adjustable, a collar on a threaded PVC foot with normally a straight roller at the bottom. You will need to roll the fridge out a little and using some one to help tilt the fridge back a little to get your hand on to the collar. Some are able to be turned with just your fingers with out tilting the fridge but it is easier with the weight off them. If door self closes the fridge is tilting back, tilting forward the door will stay open. Now by loosening or typically threading the collar anti-clockwise the foot height will reduce and the fridge will become more level and the door will close slower. As you get it just right to your personal liking just wiggle the fridge a little and make sure all the feet are touching the ground. The use of a level and patience can have you set it up just right for you.
I hope this helps as myself being a fridgy like my fridge door a certain way, customers like sometimes know how they like it and there is the way the fridge is ideally installed.
Posted on Apr 14, 2014
When washer gets to 12 minutes it shuts down and flashes ul
Tammy: According to Advantagesupplyfl.com: "uL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
Display clears if mini-cycle successfully rebalanced the load.
If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute
the load."
May 12, 2015 | Washing Machines
Balance adjust
They balance from the top brackets.
You can adjust it to get it right,it will take a bit of time but it can be done.
Some lgs all have bottom hinge adjustments you can check and adjust these as well.
Jan 09, 2014 | LG Refrigerators
Washes great once it gets to the final rinse and spin its banging like some thing inside the machine stripped it down nothing in it x
The load of moist clothes inside the drum is out of balance. Open the door on the machine and wait for the drum to stop, then spread the clothes around the drum as much as possible. This should help to rebalance the drum.
Jan 07, 2013 | Washing Machines
Whirlpool Cabrio spins off center and stop with ul code
Ul-Unbalanced Load
the load.
May 28, 2012 | Whirlpool Washing Machines
When I close the frig door, it blows the freezer door open. The same when I close the freezer door, it blows the frig door open.
That is because the unit is sealed. If the doors are staying opened I have posted a how to fix it linked just below.
Doors
May 26, 2010 | KitchenAid Superba Architect KSCS25INSS...
Doors not closing all the way
check level from back to front on fridge if good than check the amount of food that is stored on the door if u have a lot of bulk, weighty stuff they may be acting as a counter balance on the door when u close the left side the air that is trapped usually disperses into the unit and is not forceful enough to push open the door but if their is a lot of additional weight on door it makes the door easier to open and swing on hinge
Apr 21, 2010 | Jenn-Air JFC2089HE French Door...
My refrigerator door is unusually hard to open, I
If you open the door and then close it then open it again is difficult normal this happens espeacilly in big volume refrigerators and freezers.You should wait for sometime to open it again as it needs some time to balance the pressure.Warm air goes inside and cools down so the pressure is decreasing.If there is a pressure balance valve installed at the door check it if it funcitons.
Jun 30, 2009 | Refrigerators
Freezer making a loud noise.
Sounds as if the evaporator fan has shaft play or the blades are out of balance or striking something. When you open the door the pressure is equal but with the door closed the fan needs to push the air through the evaporator and return again and circle through fan again. I think soon would be a good time to unplug the refrigerator and remove the back panel covering the evaporator and fan motor to inspect the fan, shaft play and the evaporator for frost buildup or any obstruction of air flow. Thanks, sea Breeze
Jun 17, 2009 | Samsung RS2630WW Side by Side Refrigerator
Kenmore elite shows error code "ob". It spins for a minute but stops then repeats process. Then code pops up. How can I fix it?
Out of Balance
Rebalance the load. What is in the load of wash? Something thick and heavy? Maybe too few items. It probably can't be balanced. Open the door after pausing and reaarange the load a bit and try again.
Feb 20, 2009 | Kenmore Elite 45986 Front Load Washer
Open Questions:
See all GE GSS22JET Side by Side Refrigerator Questions
GE GSS22JET Side by Side Refrigerator Logo
94 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
