Question about OE Aftermarket 1990 - 1993 Infiniti Q45 Camshaft Position Sensor W013
Engine Stalls or dies Intermittently while driving. Fuel injectors and fuel filter have been replaced.
    Problem Solver:
  • 10 Answers
Had the same problem with 2003 silverado did everthing could think of.believe it or not ,put in new battery and solved the problem
Posted on May 02, 2014
Stalls while driving
Check your fuel filter, as well as your rubber hosed connected to fuel injector, or carb. Sound like poor fuel flow into carb.
Jul 25, 2014 | 1994 Dodge Intrepid
Dies when braking at light
The idler regulator maintains proper engine speed when stopped, whether in first gear stopped at a light or while in park. It sounds as if this part is not operating correctly and thus the engine stalls out.
Mar 16, 2014 | Pontiac Grand Prix Cars & Trucks
My gmc 4.3 stalls when warm and wont start without ether. then it runs fine
I had the exact problem with my 1993 chevy c1500. I found that the IAC was sticking so the engine would die at idle after warming up and the ignition module was pulsing the ECM intermittently after the engine warmed up so the fuel pump wasn't being turned on after the engine died....I replaced the ignition module and the IAC valve and all is good. I don't know if testing the ignition module reveals that it isn't sending pulses to the ECM.
Mar 28, 2013 | 1991 GMC Sierra
Stalls frequently
Seems like a fuel supply problem... additional fuel is added through the injectors when the engine is cold (running slightly rich) and then when it comes up to temperature or pre-set time period through the Electronic Control Unit (brain), the engine dies. Each time you shut off the car and restart it, the injectors receive extra fuel. My guess is partially clogged fuel injectors. Take the car to a Bosch Service Center and have them cleaned... its far cheaper than buying new. Change the fuel filter too! Hopefully, the fuel injection system pump is not bad (not the same as the fuel pump) as these are expensive. Get a rebuilt one, if you need a new one. Recommend Denso Iridium spark plugs to get a cleaner burn, better gas mileage, and longer service life.
Aug 27, 2012 | 2000 Ford F350 Super Duty Super Cab
1986 mercedes benz 230e runs rough and stalls
typically, this describes a dirty fuel filter.
Apr 29, 2010 | 1991 Mercedes-Benz E-Class
My car dies when I drive for a short time.
Check O2/mapp sensor. Also if you can elaborate on the behavior of the engine as it stalls, is there smoke, does it race then suddenly die out or does it barely run at a very slow unsteady idol until it floods out?
Answering with as much detail as possible will help get a more definite answer.
Good luck.
Apr 04, 2010 | 1985 Cadillac DeVille
My intrepid dies while driving
It sounds (based on your description) like there is a Fuel problem:
1. Check the fuel pressure at the port on the Fuel Rail. Check especially when operating at higher RPM's than at idle or stop. At these levels there is enough gas being provided to keep the engine going. At higher RPM's the Pressure/Volume may not be enough causing the stalling.
2. When was the last time the Fuel Filter was changed? Change this and check operation before moving onto to #3.
3. The Fuel Pump. If the Fuel Pressure and Volume at the Fuel Port is falling at higher RPM's and the Fuel Filter did not help: It sounds like the Fuel Pump is failing. These will fail especially after they warm-up. This problem (losing power and dying) will happen more and more frequently and the Fuel Pump will eventually die all together.
You have to replace the Fuel Filter when you install a new Fuel Pump - it is part of the warranty.
4. The Fuel Injectors: If the Fuel Pressure/Volume at the Fuel Rail is fine, then it is not the Fuel Filter or the Fuel Pump. The problem is "downstream". It may be the electrical aspect of the Fuel Injectors or the mechanical side of the Fuel Injectors themselves. Check each Fuel Injector for correct voltage. If the voltage is correct - Pull and replace that corresponding Fuel Injector. I actually recommend: if you have to replace more that one Fuel Injector - go ahead and replace them all.
Jan 05, 2010 | 2000 Dodge Intrepid
I have 2005 chevy cavalier that stalls .
Check to see if you emission system sensors are plugged in, such as the air intake sensor which is plugged into the air hose at the front of the engine. Another possibility is your gas cap. Replace it, its very cheap. If it only occurs at higher speeds it may be clogged injectors. Dump a bottle or two of injector cleaner into the gasoline tank after a fill-up. You might also try some octane booster which is methanol and will mix with and help remove any water in your fuel tank.
Sep 22, 2009 | 2005 Chevrolet Cavalier
Cannot get 1987 chevy van 20 to keep running... stalls out
Best do a fuel pressure test. Should have chg. fuel filter from the get go. The only other filter is on the end of the fuel pump in tank. Bad gas and dirty gas will plug up fuel filter, hense burn pump up.
Apr 11, 2009 | 1987 Chevrolet G20
My engine stalls intermittently. It appears to be a fuel supply problem. I've installed fuel pressure gauge that reveals that the pressure is steady, even when the engine stalls. What do I test next and...
will be more helpful if you describe in more details; how often and if is at idle or when driving?
if you suspect fuel,did you try fuel filter?
Jul 24, 2008 | 1989 Jeep Comanche
OE Aftermarket 1990 - 1993 Infiniti Q45 Camshaft Position Sensor W013 Logo
Top OE Aftermarket GPS Experts
John Feinauer
John Feinauer
Level 1 Expert
Timllfixit
Are you an OE Aftermarket GPS Expert? Answer questions, earn points and help others
