I need circuit diagram for a dixon tms8 power mixer
No output
5 Suggested Answers
artiedc
  • 35 Answers
SOURCE: I need a circuit diagram for a Behringer PMX 2000
Here you go..
I posted your schematic on my temporary web files site; so,
download and save within the next two weeks cause it might go away..
http://ca.geocities.com/artiedc/PMX2000.pdf
Ed
Posted on Jun 21, 2009
  • 5603 Answers
SOURCE: my audio mixer horns, i
We can't understand what you are saying... DO NOT PLUG the speaker output(s) of this unit into anything BUT speakers !!! There is a hazard if using 1/4 inch speaker cables that can fry the amp.
Posted on Mar 25, 2011
  • 3698 Answers
SOURCE: How can I fix my mixer problem? I have a Dixon PMX8 Professional mixer. When I switch it on it goes teeeet. I checked the fuses, fan and there is nothing popped on the circuit board. Where can I look
www.dixon-ztr.com/service-and-support
Posted on Sep 14, 2014
Testimonial: "I have a Dixon audio 8 channel mixer it is for sound purposes."
  • 3107 Answers
SOURCE: Where we got Schematic diagram for mixer model 1002fx
You can download a copy here-
BEHRINGER XENYX 1002 SCH Service Manual free download schematics eeprom...
Posted on Feb 12, 2015
I have a dixon 8channel powered mixer model no.fx8-400 non of it's channels seems to work there's no sound what must i check
If it lights up when you turn it on, it won't be the fuse being blown. If there is no sound, not even hum, when it's turned up, it's probably the output section is blown and it needs to go to the shop.
Feb 01, 2017 | Dixon Music
I have shure 101 console audio ..how can i connect to power speaker
this is the manual for your mixer. see page 2 for the rear panel diagram. on the rear panel diagram 24-27 are all outputs, you can run them directly to powered speakers, or thru an equalizer to powered speakers or thru power amps to passive speakers.
outputs 24 and 25 are both the right channel outputs, and 26/27, lkeft channel outputs. the reason each channel has 2 outputs is to support either 1/4 inch or trs connectors
http://cdn.shure.com/user_guide/upload/1597/us_pro_sr101_ug.pdf
Dec 31, 2014 | Car Audio & Video
Im looking for a dixon tms8 circuit diagram
Are you trying to repair it? If so you dont need one. Test the mosfet to see if they are shorted. Replace all needed, look on board for bad components, such as bad or leaky caps, burned diodes, check other parts around each one. Check in transistors for short or opens, replace as needed. Look for input caps swollen etc, etc. they are all built almost the same way, some with better parts cheaper ones with lesser an weaker parts.
Mar 20, 2014 | Computers & Internet
How do I hook up two powered 15's and two passive 15's to this mixer(1202-VLZ3)?
You connect the powered 15's using balanced cables. The passive speakers you will have to get an amplifier for as the mixer does NOT have a powered output, only line-level audio outputs.
The powered speakers MAY have audio line level outputs to continue to other powered speakers or, as in your case, external amplifiers to drive your passive speakers.
Remember to power ALL interconnected equipment from the same receptacle or source to avoid ground bounce faults that can destroy sensitive circuits in your equipment.
Mar 05, 2011 | Mackie 1202vlz3 12 Channel Mixer
Xenyx 1002fx Mixer 10 Input 2 Bus with Efx: behringer mixer power goes off after running about...
Problem is likely thermal. Open unit carefully and use freeze mist (circuit cooler) to find bad component.
With that long a time period, it is possibly a component mounted on a heatsink.
May 18, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Connecting two powered mixers
Hi, If you have small electronics knowledge this might help you. First fine in each mixer the amplifiers line In if your mixer has two amplifiers then you have four line In. Disconnect this line from your mixer and build a circuit Line out multiflier. You can use op amp for this application this is a simple circuit. You made two input and four outputs. If you are interested i can send you a schematic diagram.
Aug 10, 2009 | Audio Players & Recorders
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
