Question about Dewalt Planer (DW734)
My planner won't draw the wood thru my planner.
When you start the wood thru the planner it won't draw it on thru. It just sits there.
    Master:
  • 550 Answers
Check that blade is correct and guides correct
Posted on Apr 08, 2014
Feed extremly hard to push board thru
my be you planning to much wood at once or the cutter is dull
Mar 15, 2014 | Dewalt Planer (DW734)
Dw735 planner thickness
Is it cold in your shop? The rollers won't work if they're cold because the rubber gets stiff. Clean your rollers also with mineral spirits. Hope that helps.
Jul 11, 2013 | Dewalt DW735 13 Inch 2 Speed Planer With 3...
Wood planer
Unplug the machine and readjust the blade setting to sit just past the blade support
Apr 13, 2013 | Tools & Hardware - Others
77gl1000 won't start
overhaul and clean carbs ,drain tank and cHeck for rust and clean and seal tank. change filters,get new battery,get fresh fuel,give it a try to start,if it doesn't start,take to reliable dealer and have it gone thru!
Jan 24, 2013 | Motorcycles
The rollers which feed the wood thru the planner arn't turning.
could be a loose set screw, chain problem or gear. You didnt specify what the model number is so I am just going from experience. Let me know what brand and model and I will try and find you a manual or breakdown for the tool.
Jun 26, 2011 | Dewalt Tools & Hardware - Others
I HAVE SHARPENED THE KNIFE BLADES HOW DO I SET THEM IN THE PLANNER
Planer blades can only go in one way, the set plate must go into the groove on the blade. If you sharpened them by hand, or even with a machine, you have to be absolutely sure both blades are EXACTLY identical and that the edges are true and straight. If not you are going to get some real interesting patterns on your wood. It's rarely advisable to sharpen planner blades and they are cheap enough to make it unnecessary.
Dec 23, 2010 | Makita 3-1/4" Planer Kit N1900B
Keurig when drawing water in takes a long time then turns off, sounds like it is clogged in some way
The water reservoir tank probably isn't seated properly. Try wiggling the tank a bit and if that doesn't do the trick, completely remove the water reservoir and then replace it. Once it's seated properly, it should start drawing water and brew as designed. Hope that helps! Best of luck...
Feb 01, 2010 | Keurig B60 Coffee Maker
New DeWalt DW735 planner not pulling wood through machine
Planers were not designed to remove old finish, They were designed to plane new lumber which would be much softer., so likely the need for cleaning seems reasonable. I woudl think a wire brush on the serations of the feed rolers woudl serfice.
Jan 07, 2009 | Tools & Hardware - Others
Dewalt Planer (DW734) Logo
248 people viewed this question
Top Dewalt Crafts & Hobbies Experts
Ivan
Ivan
Level 1 Expert
CliffOnTheRo
Level 1 Expert
Tony Crow
Are you a Dewalt Craft and Hobby Expert? Answer questions, earn points and help others
