Question about Home Security
My Scalex 880 Piezo constantly leaks at the handpiece when it's plugged into the water line
I think we just need an o-ring replacement, but can't find where to buy one.
5 Suggested Answers
ftw1952
  • 10319 Answers
SOURCE: placement of O-ring in fuel line to pump assembly 1998 Astro
Was it a clean new o ring? If not get a new one for used ones will leak. Yes they simply slip onto the outer lip of the pressed line too
Posted on May 25, 2009
vincob
  • 718 Answers
SOURCE: Our Kohler bathtub is leaking
The drain portion of your tube is fort he most part universal, go to the local Home Depot or Loews and ask some questions sometimes they even have samples set up on boards in the plumbing dept you can look at. Get out there! Good Luck
Posted on Nov 10, 2010
  • 744 Answers
SOURCE: garbage Disposal Leaks from the bottom.
Hi GF,
Unless there is a leak at the sink gasket that makes it appear that the unit is leaking from the bottom, it's probably the main seal in the unit. It's generally not worth it to attempt disassembly and repair, especially if the unit is 10 years old or older.
Just remember to make sure the power is off before you attempt any
troubleshooting or replacement.
Be safe...
Posted on Aug 18, 2012
  • 45531 Answers
SOURCE: 2002 Ford F-350 Super Duty, w/7.3 Diesel, I have a leak where you drain water from the Fuel Filter, I think the "O" Rings are cracked or completely gone, Can I not just replace the "O" Rings that are
You can use "o" rings for this problem or if the thread is still good you can a soft copper/ washer. If the problem is in the drain bit itself and the thread is good in the body you can use a short bolt and a fibre washer to seal it off. It only means removing the bolt to drain the water when it needs to be done . The water in the fuel comes from condensate from the hot fuel cooling down and one way to prevent the condensate from appearing is to not shut down on
anything less than 3/4 tank of fuel (Fill up on the way home ). With less air space there is less air that has water vapour in it Any way go to a ford wrecker if the drain plug is not repairable and get one from there.
Posted on Jan 14, 2014
Leaking radiator... on drivers side, facing the engine, in the bottom corner, there is a place that appears to have had a hose...it also appears to be where the fluid is coming out at... difficult to see...
It's not the drain plug, is it? I don't think there would be a coolant hose there. Sometimes a drain plug will have a short hose to direct the drain downward.
There may also be two lines to the radiator from the transaxle-they are cooling lines to a separate reservoir inside the radiator, to cool the transmission fluid. Examine the fluid and see if it is coolant or transmission fluid. Your radiator may have to come off to stop the leak if it is not a drain plug that just needs a new o-ring seal or needs tightening.
Sep 26, 2013 | 2005 Chrysler Town & Country
Which part do I need to replace to stop the leak in my Sta-Rite multi-port valve ?
I couldn't see the video, but which o ring to replace depends on where the leak is. If it is coming from the side of the valve, that would be the lid o ring. If it is coming from the top center of the valve, that would be the diverter shaft o ring. If your losing water out the waste line, that means the spider gasket under the diverter needs replacing.
Jan 28, 2013 | Sta Rite Pool & Spa
I have a F350 diesel non- tubo with a fuel leak in back at top. replaced o ring at back injector and replaced all hose clamps but still bad runing leak. What next?
This engine has fuel lines that run to each injector from the injector pump. On the older Fords they touch each other in places. This constant vibration from the engine has caused a pin hole in one of your fuel lines to the injector. You will need to find the bad line. Can be hard as some of these are buried and hard to see. The replacement line will need to be purchased from Ford as each fuel line has to be a certain length and they are all high pressure lines. I have seen this many times in the older Fords.
Apr 05, 2012 | Cars & Trucks
My x08 shower is leaking. I replaced the mixing cartridge O-ring, and that did not fix the leak. Today I replaced the 2 piece assemble with the one piece upgrade part 974-042, but it is still leaking, so...
Replaced Price Pfister hot water cartridge but it is still leaking! I removed several times and flushed the line then replaced without solving problem. Help!
Apr 27, 2011 | Price Pfister R897EBK Brushed Nickel...
Karcher G 3050 OH the pressure is not constant, I think that is the pumps pressure regulator but I'm not sure
Check the suction line for leaks. It needs constant water
supply to build a constant water pressure. You may also
check the pressure regulator for leaks. You may also
check the carbide or ceramic pistons for breaks. Send you e-mail for further assistance.
Sep 06, 2009 | Karcher G2500PHR Factory Refurbished 2,500...
Water leaking
simply an O-ring needing replaced
Aug 05, 2009 | Washing Machines
Placement of O-ring in fuel line to pump assembly 1998 Astro
May 25, 2009 | 1996 Chevrolet Astro
GE Profile water filter housing leaks
Hi there is a grommet you can replace.
#WR02X10678 it is about $7.00 It can help seal the plug sometimes. Ge does want you to buy the whole filter assembly it is number
#WR17X11618 $51.50 . You may also consider putting a new filter in. It seals better than the plug it is number
#gwf $42.95. I dont know why they dont sell a o-ring kit. I guess they just dont make much money on o-rings. I hope this will help you. Have a nice day.
Michael Anderson
Anderson Appliance Repair
(865)945-3808
Feb 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
92 accord lx leaking on fuel rail
Dont replace just one O ring on the injectors. You need to replace all when you replace them. It sounds like you still have O ring leaks.
Jan 19, 2009 | 1992 Honda Accord
Home Security Logo
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
