Question about Breville Bdc600xl YouBrew Drip Coffee Maker
Bdc600xl won't brew
My Breville You Brew system grinds coffee and it ends up in the hopper, however it never brews. Display say heating and brewing but nothing comes out?
4 Suggested Answers
SOURCE: Why is the grind from my Breville BCG450XL in the
The Breville was designed to be used with Pressurized Portafilters, which most Home Espresso Machines have. These filters use a courser grind, so when it says Espresso on the Breville, it's really closer to Drip. The Turkish setting is barely fine enough for Espresso. There is a limiter on the Breville that prevents the user from going any finer, if you crack it open and remove the limiter, you can go as fine as the Solis. Becareful though, the burs can come so close to each other that they can chip and break.
Posted on Jul 10, 2009
  • 58 Answers
SOURCE: My Breville Keurig won't brew the coffee
Contact Keurig customer service at 1-866-901-BREW (2739) -- everyone i have spoken to was very kind and helpful
Posted on Jun 24, 2010
SOURCE: Hi. On the Breville CG10 coffee grinder, is the
Yes, 1 is finest and 9 is coarsest.
From the manual: 8 - 9 Percolators 4.5 - 6 Espresso Machines - Steam System 3.5 - 5 Drip filter coffee makers 2.5 - 4 Espresso machines - pump system 1.5 - 2.5 Espresso machines - semi automatic pump system
Posted on Dec 28, 2010
My cuisinart automatic grind and brewthermal shuts off every minute or so it douse not brew strate through.
HI,
• Remove the hopper from the unit
• Lift coffee channel cover
• Clean out coffee chute
• Replace channel cover and hopper
• Your coffeemaker is now ready to brew again
Oct 06, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
A breville you brew bdc600xll coffee maker basket overflowing water and grounds
I have that problem also when I use the wrong filter in my BUNN but when I use only BUNN filters it does not do it . you could try them they seem to be a little deeper .
Oct 09, 2015 | Breville BDC600XL Coffee Maker, You Brew...
I own a Breville 800ESXLespresso machine which i already decalcified, that leaks from brew head and handle moves while brewing
If you've had the machine for a while, your brew head seal (gasket) is probably damaged or shrunken from age/heat and needs to be replaced. That's most likely why the filter holder moves and leaks while brewing. Breville brew head seals are rather difficult to locate, but I personally stock them and sell them at a reasonable cost. I sell lots of new and used parts for various coffee machines, but specialize in Krups. If interested in purchasing a Breville brew head seal, contact me at cowboy_romeo@yahoo.com and I'll make arrangements. I accept Paypal to make the transaction safe and secure for us both.
Nov 27, 2010 | Breville ESP8XL Espresso Machine
Is there a way to increase/decrease the pressure of the brew unit tamper?
Hi
Yes in a way. There is a lever on the right side above the center of the door. It has a + and -, on it and the + will increase how much coffee is put into the brew unit and - will decrease the amount. + is for stronger coffee and - is for weaker coffee. The grind will also affect the compactness of the brew unit but you can get too much pressure if you get it too fine and this can also clog the passages of the grinder if made too fine. If you ever get the machine to say that "you are out of beans" and there are beans in the bean hopper, your grind is too fine. If the flow from the brew unit slows down your grind is too fine. If it dumps the grinds or makes a clicking noise you have too much coffee going into the brew unit. Pull the lever back 1 click from the +.
Oct 23, 2010 | Saeco Magic Comfort 103467 Espresso...
May 31, 2010 | Breville BKC600XL Coffee Maker
My machine grinds coffee without stopping for what seems a long time, then the bean light comes on and it will not make a cup of coffee. I took out the brew unit and cleaned it, now the brew unit light...
Hi
You have a couple things wrong now.
First you have a blockage in you grind passage. Try removing the brew group. Then inside on the roof of the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder (towards the rear of the machine). Vacuum it out. It will be on the right side of the drop chute.
Once that is cleared go to the bean hopper. There is a lever on the right side below the bean hopper. Push the lever back to the largest number. You can push the lever to a larger number any time but it has to be grinding to pull to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can pull back to a number that was higher than the one you had it on, but only when the grinder is running.
The second thing brew unit missing.
Open the door. Push hard on the upper left side of the brew unit. When you hear a click, close the door and the light should be out.
Nov 16, 2009 | Saeco Magic De Luxe Espresso Machine
Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Jun 20, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Grinder won't stop
Hi
You have a micro switch on the doser that is in need of a replacement. It is a special micro switch that is just for the doser. It is very sensitive. If the micro switch is not activated the grinder will run until it times out, but the coffee will fill the brew unit and that could break the brew drive.
May 01, 2009 | Saeco Magic De Luxe Espresso Machine
I have a 12 cup cusinart grind & brew. The hopper is not working
You may have to clean the grinder....even more. That happened to me once. First I cleaned out the coffeemaker with the brush, and "dug" out more coffee, then I used this product which you can find on Amazon: "Urnex Grindz Coffee Grinder Cleaner - Urnex 17-GRINDZ12-40." It's expensive, but it really worked well.
Apr 02, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Breville Bdc600xl YouBrew Drip Coffee Maker Logo
157 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
