Question about Kyocera wild card Cellular Phone
Not `workingh i not connect or working.
When I hold the buttons down, nothing happens.
if it is a new digital watch there is a small bit of plastic under the winder knob that holds it slightly out
this prevents the battery from going flat while in the shop or storage
remove that plastic bit and push the knob all the way in and it should start workingh
Dec 18, 2015 | Watches
I have craftsmen 19.2 volt tools while using the electric sander my batteries have died and when i put them in the charger the green indicator light comes on saying they are fully charged , when in reality...
It sounds like your charger is faulty. Try to measure the voltage of the batteries. If the nominal (workingh voltage of the batteries are 19,2 volt, then they should invrease to about 22 volt while in the charger. If the voltage does shoot up when the charger is on, maybe even to 25 volts, (which should turn the green light on) the new battries are dead!
It happens!
The other possibility is that the batteries are OK & fully charged!
But!
Your sander is damaged. Again, try & measure the voltage in the sander, before & after you switch it on. A large drpop in voltasge can indicate the sander drawing too much current. Also try them in another machine if you can.
Andy
Sep 03, 2011 | Craftsman 19.2v 3/8"drill/driver W/ Work...
My acer 5534 touchpad is not working... HELP!!!!!
There are three buttons near the right internal laptop speaker. The button directly to the right is the dvd drive eject button. One of the ones to the left which has the satellite icon will enable/disable the wifi receiver. The other one with the hand icon (which is the one you're looking for) will enable/disable the touchpad. If you press it, you should see a message printed in all caps in green saying that the touchpad is either enabled or disabled.
Feb 11, 2010 | Acer Aspire 5315 Notebook
DI 624 Was working ,disconected , reconnected work no more.
If you connect the computer to the modem , does it works ?
If it works then modem is working. now connect the computer and modem to the router.
open the set up page of the router. change the Internet settings according to the ISP.
Click Here for more information about router and networks.
Jan 10, 2010 | D-Link Computers & Internet
PC will not connect unless Laptop is turned on?
first reset the connection, and try to connect the pc with switch and when net start working the connect the laptop
Mar 11, 2009 | Linksys WRT160N Wireless Router
Pc camera installation
hello ms_sweetlvin
you can try there site A4 tech under support/downloads see if its listed there.
riz.
Apr 27, 2008 | A4tech PK5
Kyocera wild card Cellular Phone Logo
15 people viewed this question
Top Kyocera Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
