Fast flashing edges on the left and upper edge of my beovision 7-40 television when I attach my PS33 to it with a HDMI cable
Hi, I get fast flashing edges on the left and upper edge of my beovision 7-40 television when I attach my PS33 to it with a HDMI cable, also when I start up a game on my PS3 I hear a loud bang twice coming from the speakers. The edges are approximately 3mm thick and flash very fast the color of de edges is constantly changing. I already tried using another HDMI cable but that did not help. And on other televisions I have no problems. Adjusting screen location or format doesnt help either.
  • 18 Answers
SOURCE: Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
Posted on May 31, 2008
mistersony
  • 320 Answers
SOURCE: Flashing Standby Light (6 times every 2 second interval)
A 6 flash error indicates a problem with the backlight. Your set is less than a year old and still in warranty, so you should contact Sony and arrange for a service call to get it repaired.
Posted on Nov 10, 2008
gage8405
  • 5 Answers
SOURCE: TELEVISION - PS3 AND XBOX HDMI COMPATIBILITY
You have to use the scart connector for on screen menu settings. Go to the video option and enable HDMI and/or match resolution output to your set.
You did not mention the model of the TV so here is another scenario,
Just because the TV is 1 year old doesn't mean that it is a 1080p capable, you could have set the HDMI resolution settings to 1080p and you will not get any picture if your set cannot process the information.
Posted on Jul 03, 2009
  • 53 Answers
SOURCE: Mitsubishi 46in. LCD
The TCON board at the top of the panel is causing the issue. You will need to replace the whole panel.
When the set warms up, the TCON behaves. Replace the panel now to avoid what will eventually become a permanent line (if not several)
Posted on Aug 01, 2009
  • 16 Answers
SOURCE: Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
Posted on Sep 20, 2009
Picture and sound flashes on and off
We recommend you test your HDMI device on a different HDMI input on the TV. If the problem persists then we recommend you replace your cable or satellite box.
Mar 24, 2014 | Panasonic TC-L50EM5 VIERA 50 Class 49.5...
Samsung hcn5529W hmdi input dispaly issue
then try using RY able instead of HDMI input to test if its a cable problem
Mar 29, 2008 | Samsung HCN5529W 55" Rear Projection...
Where do I find my wireless switch on my acer 2355LCi?
Its either in the front edge or at the left side edge of your laptop. when you press it, you will be getting the display " Wireless Enabled" in your screen.
Dec 24, 2010 | Acer TravelMate 2355LCi Notebook
How do i connect to pc using hdmi cabel its a sanyo pdp-42xr9da lcd
You have a cable called as the DVI-D to HDMI cable. Using this cable you can connect PC to LCD.
You have a HDMI port on left side of your LCD.
For easy understanding i am attaching a image.
Jul 24, 2010 | Sanyo DP42746 42 in. Plasma Television
I have a 2007 Ford Edge SEL and the rear blinker is flashing really fast I trying to figure out how to get at the bulb to replace it Shawn
flashes fast because you have another bulb out, its not the one flashing.......check the front.........if it flashes it works
Mar 06, 2010 | 2007 Ford Edge SEL Plus
Lcd tv has a black line near edge of screen it feels like a rubber gasket when you push gently on the screen
Samsung always had problems with their front masks buzzing or rattling at certain audio frequencies. What they started doing is putting a rubber or foam "edge" around the inside of the mask to stop the noise. It sounds like yours has started to bulge out. You would have to remove the LCD panel to really access it and get it back where it belongs.
Oct 13, 2009 | Samsung LN32A540 32 in. LCD HDTV
Change of CMOS battery in IBM Thinkpad 1400 2621
This battery is hidden under the keyboard slightly up and to the right of center of the keyboard. To get it out is a pain.
Start with the computer sitting flat, lid closed, lid latchs facing you.. just like you were getting ready to open and use it.
Spin it around, rear ports facing you. Right above the external video port, on the right hand side, there are two screws, at a diagonal UP from the port itself, very close to the bottom edge of the LCD. Remove them. There is a small notch between the screws, using a small flat-blade screwdriver, pry up in the notch and pop the platic backing free from the rear of the laptop. DO NOT open it more than a small crack, you are just popping loose a small plastic tab. Open it too wide and you will lock it closed again or break the plastics when you open the LCD lid.
Spin the machine around again, and open the LCD carefully as far back as it will go normally. Find the Power Button. The Power button is to the far right of a plastic 'strip, with 4 other buttons on the far left. There is a small clear plastic strip overlying this button 'tray'. Find the small notch in the bottom edge of the clear plastic strip, use the flat-bladed screwdriver, and gently pry up, popping the plastic strip out of the tab holes in the tray. Under this plastic strip is a black adhesive 'strip' that has a house, magnifying glass, etc. markings on it, and 'i Series' or somesuch printed on it.
Using a razor blade, peel up the black adhesive strip on the left and right ends of the button 'tray'. You will find two small silver screws. Remove these. Then using your screwdriver, or as I did, a dental pick, *gently* pry up the entire tray from the BACK edge of the tray, and by lifting up the left side of the plastic tray. You will have to work it out from under the edge of the LCD bottom on the left side. DON'T yank on it, there is a small cable attached to the bottom of it. You will be able to rotate it toward you and roll it over, exposing the small latch holding the cable in place. Its a small, press-fit latch like what holds a keyboard cable in place. You'll need to work it open by lifting the left and right edges till the latch becomes loose. Pull the cable straight out of the slot, remove the entire plastic 'tray', and set it aside.
On the far upper right of the keyboard there is a small metal tab holding the right upper edge of the keyboard. Reach around to the back of the computer, right-hand side rear, find the little square thumb-notch, and pull it out. The latch on the upper right edge of the keyboard should retract. Now, while lightly pressing down on the keyboard, push the keyboard away from you. It should slide backwards and the front tabs on the front keyboard edge will pop out of the slots. Lift up the touchpad area, popping up the bottom edge of the keyboard, clear of the plastics, then pull the keyboard slightly toward you. It should pop loose all the way around. DO NOT yank on it, there are 3 small cables attached underneath. You wil need to lift the keyboard up enough to reach the cables and pop the lockdown tabs loose, then pull the cables straight out of the slots they are in. The cable slots are attached to the motherboard, the cables are attached to the keyboard.
Removing the keyboard will expose a flat silver panel underneath. There are 5 screws holding down the panel, 4 in a 'box' configuration on the left, and a single one on the right, and several slide-tabs around the edges. Remove all 5 screws, then slide the whole tray to the right, while lifting up. The entire tray will pop up, with the video card heatsink attached on the left-underside of the tray. Set this aside. Directly in the middle of the big hole you now have is the battery. Its smaller than a standard desktop motherboard battery, looks like a small silver button. Gently pry up on the bottom-left edge of the battery, very carefully or you will break the plastic clips holding it in place, and pop it out.
All done. Reverese order to put it all back together.
Feb 21, 2009 | IBM Thinkpad I1400 2621 Planar TV...
Green line down left side and geen snow
Horizontal or vertical bars on the screen could be from an ac line interference, adjacent magnetic field, bad input wire connections.....especially HDMI connector cables. A bad HDMI cable causes all kinds of unwanted picture interference. Check the conditon of all connection wires for proper fit and function. Keep in mind the method in which you connect your tv will result how the tv performs. As well this line problem could be a circuit issue too, requiring a technician to look at it.
Jul 23, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Can't view entire screen
make sure that you tv is set to the "standard" format and then try changing the aspect ratio on the cable box.
Jan 26, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Dishwasher Kitchenaid KUDS25SHHBLO
It sounds like your touchpad is faulty. It can be removed by opening dishwasher door and removing 4 Torx screws along upper edge. Be sure power to unit is off before working on it.
Nov 09, 2007 | KitchenAid 24 in. KUDS25 Built-in...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
