Question about Alesis MasterLink ML-9600
Cd drive won't recognize cd
It scans the disc, then says insert blank cd-r. Have tried multiple cds with no success. worked yesterday.
    New Friend:
I had many problems with the disc recorder on mine.contacted Alesis, told them the problem & they sent a list of places to have it repaired. Your CD drive needs to be replaced.
Posted on Mar 20, 2014
  • googler too Apr 16, 2014
    Replace the CD drive. It's an easy job, similar to replacing an optical drive on a computer, and there's guides all over YouTube and the web showing you how. There's an online list somewhere of compatible drives, you should google this to ensure you buy the correct type.
DVD drive read/burn problem
From the description the new DVD driver is defective and should be returned if still under warranty. The only concern that I have is the replacement you got is identical to the original and that it is not a aftermarket product, because they don't have the same specifications as the original.
Apr 05, 2012 | Lenovo 3000 Y410 Laptop
The laptop burned a disc, then ejected as usual. Another disc was place in the tray, inserted as normal but this time a cd was unable to be burned because the laptop did not recognize the disc or any other...
The automatic ejection takes place when the burn process has completed successfully. Have your tried another writable CD or DVD? If your laptop is not recognizing any more writable CDs/DVDs, then the problem might be a failed CD/DVD drive. Otherwise, it is probably a bad CD or DVD.
Hope this helps.
May 26, 2011 | Computers & Internet
Hi mine is Acer Aspire 4520. I was playing movie from a DVD yesterday all fine. I left it inside the drive. Today I found that my DVD Ram device has gone bad; it's showing all empty space in whatever...
Can you suggest which OS you are using?
Does this problem exist for all the CDs/DVDs?
Try to insert bootable CD and try boot from it and check if it works.
You can try blank cd and just write it using NERO and check.
May 11, 2011 | Acer Aspire 4520-5582 Notebook
The pc won't burn cd's seems like it doesn't recognize cds or dvds
Does the cd/dvd drive read cds? This is a good test to ensure that the drive is functional.
Sometimes, generic cd/dvd burners do not recognize certain types of blank discs. Try another type of
brand blank discs, it should work.
May 01, 2011 | E-Machines eMachines Desktop PC
Cd burner makes blank cds
try isolating the problem by plugging an external cd/dvd drive via the USB. use this to burn CD/DVD if the process works, replace your laptop dvd drive.
Jul 07, 2009 | Dell Dimension 4600 PC Desktop
CD drive wont read blank or music CDs
It sounds like the drive is ready for replacement. It may be that the laser lens is dirty so the drive never detects a disc, or it's gotten too weak from age and use. Replacement drives are very cheap, so the best thing to do is replace the drive. You can get a DVD burner now at Newegg (www.newegg.com) for $25.99.
Apr 17, 2009 | HP Compaq FS7600 17" CRT Monitor
Sony VGC RB53 wont recognize blank writeable cd/dvd's
Insert a blank CD, try to burn something on to the disk, if that is successfully done than the CD drive is fine, unless you have a problem. Sometimes blank discs don't show up with direct click.
Mar 22, 2009 | Sony VAIO VGC-RB53 PC Desktop
Replace Tascam DP-01FX/CD -- the CD R/W won't work
I don't think there is a problem with your CD writer.  You have not inserted the type of disc your write drive requires.  You must use a BLANK "AUDIO CD-R".   Check your instruction manual concerning the type of disc required.  Data CD-R's will not work in this type of drive.  if the disc has "DATA CD-R" or "700"mb or "800mb" printed on it it will not work.  audio CD-R's are not as common and are a bit more costly.   They are the only type of disc that will RECORD in your drive.  Regular audio CDs should play in your drive.  I hope this solution will work for you and I wish you every success! Michael Mittelsdorf
Nov 03, 2008 | Tascam DP01 All-In-One Recording Package...
Device Won't Recognise Blank CD-R Media or Certain Music CDs.
try and see if you can pull a directory using explorer,, sometimes if you record to the full 80 minutes capacity, the disc will return an error,,,even if you recorded it on that drive...also i know this may sound strange but on the drive tray itself take the mount where the laser is mounted and extend it out to the furthest travel point ,,,gently,,,do not force...load the disc, and see if it is now recognized,,,sometimes it is a timing issue, and this way the tray/laser recalibrates itself....
Jul 03, 2007 | LG GSA-2166D DVD RW Dual Layer Burner
Alesis MasterLink ML-9600 Logo
145 people viewed this question
Top Alesis Televison & Video Experts
Are you an Alesis Televison and Video Expert? Answer questions, earn points and help others
