Question about HP TBD420NR Hewlett-Packard Laptop Lcd Inverter For F700 P/N: TBD420NR -
TBD420NR power supply requirements
I am trying to use a laptop CCFL as a light source fir a light box. I have the inverter it uses but need to know what the input voltage(s) need to be and through which pins of the 6-pin input connector. I am expecting there to be tow voltages, one to power the CCFL and one as a "switch" voltage to keep the CCFL on. I haven't been able to find any circuit diagrams or tech specs that help. Can anyone help?
  • 32 Answers
SOURCE: Type of power supply and what where is the +/- 5v or color coding for the 4 pin connector?
Dhen: This monitor uses a special Power Adapter as shown... Also the Pin designation is from the NOTCHED PART BEING ON TOP: NOTCH U +V O O +V GND O O GND SithPitt
Posted on Jul 04, 2007
aparsons
  • 3 Answers
SOURCE: HP zd8000 laptop power supply
I found the solution - and implemented it, it works. The blue (ID) line needs to show 7.5v. The simple way to acheive this is to simply put a 47k resistor from the +19.5v line to the ID line. Apparently there is a pull down at the computer end that means it ends up at 7.5v.
I cut the cable about 6" from the old HP power supply. I then soldered a female power socket onto the loose cable and soldered the 47k resistor between the ID line and the +19.5 line. I then plugged this onto my two pin power supply and the plugged it into my computer. It works very nicely.
Not wishing to junk the HP power supply unecessarily - it was still producing the 19.5v - I then soldered a power plug onto that ignoring the ID line. That now works as well. It seems that the circuitry that provided the 7.5v ID voltage in the HP power supply became flakey. I could have just opened up the power supply (I have already done that) and disconnected the blue line from the circuit board and just tied it to the +ve line via the 47k resistor and then wrapped it with the usual insulating tape.
Posted on Apr 03, 2009
bob_computer
  • 3153 Answers
SOURCE: Pin Name Color Description
Yes this is a good list of the voltages to be expected from a newer power supply on just the main header
Posted on Aug 11, 2009
  • 69 Answers
SOURCE: 920-fan command 2 pin connector from power supply not connected
then connect the fan to a 2-pin connecter if you cant do it take it to a computer place to do it for you
Posted on Sep 24, 2009
Well thats not good, however if you can identify the Positive, usually RED, and Negative, usually BLACK. on the Fan, You can actually carefully insert the bared wire into a spare drive power connector, fans are all 12 V. You can use the YELLOW.. +12V & the alongside BLACK - 0V. This will power your fan. BE CAREFUL doing this. Once inserted use a piece of tape to secure the wires and fold them back against the Plug and secure. You may be able to buy a converter that plugs into that power connector & the fan?
Posted on Feb 22, 2010
Why is my replaced lcd screen not lighting up?
1) Wrong LCD screen
2) Video Cable (LCD Cable) is not connected tightly.
Motherboard side, or LCD screen side; or both.
3) IF, a screen Inverter is used, the small cable from the Video Cable, that connects to the screen Inverter; is not connected, or has a loose connection to it. (screen Inverter)
4) An LCD screen, and a screen Inverter are a Matched unit.
If it's the wrong LCD screen......................?
5) IF, a screen Inverter is used; the diagnosis was wrong, and the LCD screen was replaced.
90 PERCENT of the time, the fault is a bad screen Inverter.
A) Laptop's LCD screen uses a CCFL, (Or more than one), for a Backlight; the laptop uses a screen Inverter.
Diagnostic flowchart leads from Graphics Chipset, to Video Cable, to screen Inverter, THEN, LCD screen.
Expensive LCD screen was replaced, instead of the actual part that needed replacing;
Video Cable: $9 to $22
Screen Inverter: $9 to $22
LCD screen: $60 to $245
B) Laptop's LCD screen uses LED backlighting, and does NOT use a screen Inverter:
Diagnostic flowchart is;
A) Video Cable;
A Video Cable should have it's connections PHYSICALLY checked.
You have to try to push the connectors in tighter.
Visual inspection alone will NOT do.
Making sure the Video Cable connections are tight, and this does not fix the problem, then the Video Cable needs to be removed; and every wire in the Video Cable checked for Continuity with a multimeter set to OHM's. (1K)
Not feasible, then take the Video Cable down to the nearest small computer shop; and have the resident tech check it for Continuity.
Should only be a few bucks.
Or just replace the Video Cable.
(Parts changing I know, but...........?)
Primer:
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, (Or more than one), or a series of LED's.
(Light Emitting Diode)
A CCFL is a Cold Cathode Fluorescent Lamp. (Bulb)
Similar to Fluorescent lighting used in homes, and businesses; but on a MUCH smaller scale.
Average thickness is 2mm. That is a little large than 1/16th of an Inch.
Average thickness is almost as long, as the LCD screen is in height.
View the last 8 photos,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
A screen Inverter is used to convert the power, (Electricity), from the laptop; for the LCD screen, and Backlight.
As previously stated, Backlighting that uses CCFL, uses a screen Inverter.
LED backlighting MAY, or MAY NOT use a screen Inverter.
When the LED backlight technology first came out, it seems some did use a screen Inverter.
It also seems as the technology advanced, LED backlighting does Not use a screen Inverter.
Regards,
joecoolvette
May 14, 2013 | Sony Computers & Internet
How to fix a fuzzy screen
1) Shave it
2) Use NAIR
3) Wipe your glasses
Brought to you by some guy who thinks he's funny.
What?
Jerrilynn?........................Jerrilynn?.................
...........Oh. c'mon I wuz just playin...........
A) Is the Screen resolution correct?
B) You may have a problem with the screen Inverter, or Video Cable, or LCD screen.
A short primer if I may;
An LCD screen does not produce light,
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/
(Click on the monitor image)
A Backlight can be a CCFL (Or more than one), or a series of LED's
Average thickness is 2mm. That is a little larger than 1/16th of an Inch, or about the width of this capital letter -> O <-
Average length is almost as long, as the LCD screen is in height.
Not knowing what laptop is in reference here, I cannot tell you whether your laptop uses CCFL/s, or LED's.
A screen Inverter is used to convert the power from the laptop, for the screen Inverter.
Laptops that use a CCFL for a Backlight, also use a screen Inverter.
Laptops that use LED';s for a Backlight, may or may Not use a screen Inverter.
90 PERCENT OF THE TIME, the fault can be attributed to a bad screen Inverter.
Primer over.
What is the laptop manufacturer name, and model number?
The model number is on the bottom of the laptop.
Please post back in a Comment.
Regards,
joecoolvette
Mar 14, 2013 | Computers & Internet
Toshiba satellite M305 S4907 comes on but monitor is blacked out can barley see
http://www.screentekinc.com/Toshiba__Satellite__M305-series-laptops-lcd-screens.shtml
The Toshiba Satellite M305-S4907 Notebook PC, uses a single CCFL for a Backlight.
Primer before we go on;
An LCD screen cannot produce light. It needs an additional light source,
Click on the monitor image.
The additional light source is a Backlight.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
View the last 8 photos.
A screen Inverter is used on laptops that use CCFL for Backlighting.
A screen Inverter converts the power (Electricity), from the laptop, for the LCD screen, and Backlight.
Laptops that use a series of LED's for backlighting, do Not use a screen Inverter.
90 PERCENT OF THE TIME the fault can be attributed to a bad screen Inverter.
http://www.sparepartswarehouse.com/Toshiba,Satellite,M305-S4907,PSMD8U-02R015B,Laptop,Inverters.aspx
The plastic thin frame in front of the LCD screen, is the Display Bezel. (Toshiba = LCD Bezel)
The screen Inverter is located behind the Display Bezel, and mounted at the bottom of the LCD screen.
(LCD Screen Frame, actually)
Easy to get to; easy to replace.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-M305/remove-screen-inverter-video-cable-1.htm
How to test a screen Inverter? Requires a Sensitive multimeter.
Read fairly expensive,
http://www.fonerbooks.com/test.htm
Because of this; and the low cost, plus ease of replacing; most home users just opt to replace it.
Know this;
Fluorescent lamps have MERCURY inside. HIGHLY poisonous.
Now couple that with the long thin makeup of the CCFL, and how easy it is to break it.
This is why if the screen Inverter is found to NOT be the problem; I would suggest replacing the LCD screen itself; instead of trying to replace the CCFL, and cause possible Mercury poisoning.
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 12, 2012 | Toshiba Satellite Computers & Internet
I need a replacement screen and i'm not sure which cffl/backlight to order
Here are the eBay search results for your exact system model -
http://www.ebay.com/sch/i.html?_trksid=p5197.m570.l1313&_nkw=Toshiba+Satellite+L355D-S7809+screen&_sacat=0
Sep 20, 2012 | Toshiba Satellite L355D-S7809 NoteBook AMD...
My compuetr screen does light up when power is connected it dark
You may have a faulty inverter or defective CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Dec 14, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Power supply to the screen backlight keeps going out
www.ladparts.net
Dec 14, 2009 | Dell Inspiron 1525 Notebook
Screen is black
If the notebook appears to boot up and the LED hard disk light flashes then :-
www.ladparts.net
Dec 13, 2009 | Acer Aspire 5100 Notebook
I have a toshiba Satellite a135-s2386. It powers on but nothing on the display. I think I need a new motherboard. But am not for sure. What is the part number for this motherboard. any help will be...
Does the laptop appear to boot up but the screen id blank?
Does the hard disk LED light flash?
If so you may have a faulty inverter or defective CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
www.ladparts.net
Dec 09, 2009 | Toshiba Satellite A135-S2386 Notebook
Unite powers up, but screen stays dark. Unite is 11 months old, and used daily.
www.ladparts.net
Dec 08, 2009 | Acer Aspire 5610 Notebook
Acer 4070 travelmate cable inverter wiring sequence
assuming that u have electronics knowledge.so there r basic 4 pins are require to make ccfl circuit working. 1. power supply 10 to 18 depends upon circuit. 2. ground. 3. ccfl circuit on off. 4. bright ness.
to identify them. power supply wire is easily identified by checking voltage.
ground wire u may ceck by continuty from ground.
rest wire u may test by try basis one by one. there will not any fault for doing so.
i hope u can solve ur problem by this method.
plz let me know .
Aug 23, 2009 | Computers & Internet
HP TBD420NR Hewlett-Packard Laptop Lcd Inverter For F700 P/N: TBD420NR - Logo
Top HP Electronics - Others Experts
Tape-Techie
Raj Patel
Are you a HP Electronics - Other Expert? Answer questions, earn points and help others
