Question about NEC VT465 Multimedia Projector
Ghosting The image on the screen seems to have a ghost. i.e. any words have a faint image off to the left. I've tried to Clock and Phase manually but the image still is ghosting. I even hit default and because the projector is ceiling mounted everything was upside down however when the image is upsidedown the ghosting switches to the right.
Get firmware upgraded.
Posted on Feb 07, 2008
WD 73835 has ghosting images during dark or red scenes
Make sure your contrast isn't set too high. Most ghosting is caused by either contrast, brightness or tint issues. Try adjusting these settings. Also check if there is a Dynamic contrast setting for your TV as well as this can cause ghosting also.
Apr 06, 2014 | Mitsubishi Diamond 835 Wd-73835 73" 1080p...
Screen ghosting
Hi !
How old is your iMac ?
SOunds to me like it has been left on too long for too many years..
THese screen eventually burn in and then it's the end...
Mar 04, 2013 | Apple iMac 24" Desktop
Blue and yellow convergence? problem...power light blinks 6 times
This is a common problem. Its called a convergence failure. You can get all the parts from
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
You can see some examples and find a fix here...
Jan 28, 2010 | Sony KP-51WS510 51" Rear Projection...
My printer is leaving faint marks of other words down the side of the page...any way to fix that?
Yes, It sounds like a ghosting issue. Several components can cause a ghosting issue. The distance between the first occurance(the one on purpose) and the second occurance(ghost image) can determine the part of the machine causing the image problem
56.6mm - Fuser
54.5mm - Transfer Belt
75.4mm - Drum unit (1 of toner carts)
Dec 11, 2009 | HP Color LaserJet 2600n Printer
Ghosting image on canon c3220
Suggest to check the transfer unit. Especially the transfer cleaning blade..
Jun 12, 2009 | Canon imageRUNNER C3220 Color Copier
Westinghouse LCM-22W2 has "ghosting"
Usually, LCD monitor ghosting appears when the cable isn't tight, the cable is faulty, or low quality. The cable should be less than 8-10 feet long. Try using a different monitor cable (they're mostly interchangable) and see if the problem goes away. I'd put my money on the cable or a loose cable connection.
May 13, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Wavy and ghosting
  1. words at top left corner have same word under it in red also on bottom of screen have seen were changing ic;s part# stk392-110 will solve problem if so what are ic;s
Apr 27, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Ghosting problem with Christie LX 45
reset the settings to factory default and make sure the resolution matches. you can adjust the clock and phase in the menu.
Nov 16, 2007 | Christie LX45 Multimedia Projector
Blue image shadow on one side of the screen..Help!
Perfect! That is typically called "Ghosting" where there is a faint image shadow behind the image on your screen. I'm glad you were able to get it fixed!
Jul 23, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Sony KP-43HT20 ghosting effect.
may have bad convergence amps stk392-560 board location Ic8001 Ic8002 or the dcu unit is bad or the alignment drifted off and it needs service adjustments made to it.
Dec 28, 2006 | Sony KP-43HT20 43" Rear Projection...
NEC VT465 Multimedia Projector Logo
2,333 people viewed this question
Top NEC Office Equipment & Supplies Experts
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
