Question about Electro Brand Nostalgic Stereo CD Music System Shelf System
The cd player will not open when you press the open close button
The CD door seems to be jammed and won't open up when you press the open close button
Chances are that if the door will not open or close when you press the button, you have a broken belt inside the unit. There is a small motor that has a belt on it that opens and closes the door. This belt needs to be replaced. Easy fix if you kn ow a little about electronics and can find the part. I just opened one up for a friend and the small belt was broken. Otherwise it looks like a decent unit.
Posted on Apr 25, 2015
    Problem Solver:
  • 11 Answers
Unfortunatly the mechanism is jammed up for one reason or the other reason #1 a cd is stuck inside #2 the gear just wore out and or it was forced closed by hand instead of pushing the eject/load button..you can try to gently pry this door open while pressing open/eject button that works 40% of the time..if it does not work? it can then be deemed broken out of order.
it's worth a shot trying to pry it open but beware this could either work or really destroy the door/mech/player comes down to this "do you feel lucky" sadly? that's where we're at with this one.
Posted on Mar 20, 2014
  • kirk watstien Apr 20, 2014
    I agree...do you feel lucky is where this is at
After moving doors willnot open
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer · CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
Jan 05, 2016 | Audio Players & Recorders
My Marantz CD 53 CDplayer door is not opening. what is the solution
You probably have a broken belt on the cd tray so it's neither open or closed, if the laser's ok thats why it wont play
Mar 31, 2014 | Marantz Audio Players & Recorders
The gears are jammed, or the timing gear is out of sync, and possibily a bad loading belt.
May 20, 2012 | Philips Audio Players & Recorders
CD jammed inside player
Remover the player's cover. That will give you access to the player's internals and therefore also the CDs. That is the only way to go about a problem like the one you are facing.
Disconnect the player from the mains supply before doing this.
Good luck.
Nov 09, 2009 | Technics SA-AX530 Receiver
Jammed tray
Hi there, had a similar problem.
This unit is easy to open. the four screws on the sides and two i think on the back. When it is open you will have access to the discs in the machine. the last disc will probably be jammed between the facia and the caddy and will be impeding the carousel mechanism, once removed you should check the functions starting with eject, and again to cycle, load disc position 1 insert disc and check. this player i think rotated the disc on loading to a set position, would have to open one to check. hopefully the carousel is not out of sync and all is well.
May 01, 2009 | Sony CDP-C265 CD Player
Cdr20 drawer is jammed ERROR message
Try taking the unit apart it mostlikly jamed or jumped track try re ajusting it that would prob work, another thing is to try messing with the gears that could aslo work
Oct 18, 2008 | Harman Kardon CDR20 CD Player
CD drawer stuck, then won't close
1. Most of the player drawer fixed over the chasis for a rigid support
2. try to remove the drawer safely without damagind the chasis and drive mechanism
3. there might be some shaft jam.
4. Look for the thread. how does the player drawer moves in and out
5. there may be some sensors to sense the door close/open. if it is jammed then open/close function cannot be done. why because this problem occurs
6. unwear the mechanism read the mechanism moving technique. see which has got jammed.
7. if you feel too risky then
8.contact service centre... all the best
Dec 21, 2007 | NAD L40 CD Player
Electro Brand Nostalgic Stereo CD Music System Shelf System Logo
424 people viewed this question
Top Electro Brand Audio Players & Recorders Experts
Ben Armstrong
Shehu Pro
Shehu Pro
Are you an Electro Brand Audio Player and Recorder Expert? Answer questions, earn points and help others
