Question about Vacuums
Plug has come off the wire
How do i wind the wire out or get it out without the plug attached
  • David Wallis
    David Wallis Mar 20, 2014
    was meant to say its a henry vacuum
You should be able to just pull it out unless it is broke so take it to guarantee vacuum and sewing center they can get it fixed for you
Posted on Mar 21, 2014
What can you do to stop squeaking when I'm winding bobbin
Spray wherever the squeak is coming from with a dry silicone lubricant called 'Jigaloo' or WD40 Dry Silicone Lubricant. It is also great for sliding windows.
WD 40 300014 Specialist Water Resistant Silicone Lubricant Spray 11 oz...
Jan 13, 2016 | SewShop.com Singer Model CE200 Quantum...
I have a black, green & white wire, where do they attach on my new amazon furnished motor
well, without being there I would say they are the power wires.
Black usually goes direct to the switch then the other wire off the switch goes directly to the motor.
White is the neutral/ground wire it will be in a bundle of probally 3 and the Green is your secondary ground which without it you have a better than good chance of being shocked if the unit gets shorted. so it could be attached to a bolt on the motor.
What colors are the wires on the motor? are you replacing it or the power cord? need more input.
I have not worked on this model or make of vacuum and would need to research it and find bigger pics as I get older my eyes are not as good as they once were.
Jun 24, 2015 | Oreck Xl 2100 Bagged Upright Vacuum
The white wire from the plug came loose where does it go? Need to see diagram for wire.
It is the ground wire. If it broke off from the plug, replace the whole plug. There should be a place to attach the white wire to the third round prong on the new plug
Jun 02, 2015 | Filter Queen Majestic Canister Vacuum
I need to replace electrial cord attached to machine myself
Make sure all electric is off strip off plastic covers on all parts of the cordes to be attached about 5incs easy to do with a razor slice on both sides or wire strippers then twist wires together and wrap with black electrical tape. Plug in and should have power
Jul 09, 2013 | Vacuums
Hoover Wind Tunnel Bagless cord prong loose, Vacuum shutting off. Do we have to scrap the vacuum?
Home Depot has cord plugs. Cut off your plug, strip apart the three wires, black, white, green. The new plug will have a green screw for the green ground; a silver screw for the white neutral wire and a brass or gold screw for the black or hot wire.
Connect those wires, ensure that none are touching the others, plug it in and turn it on.
Good Luck,
Gary
Jun 22, 2011 | Hoover U6630-900 WindTunnel Bagless...
We have a Kenmore canister vacuum cleaner. the carpet cleaning attachment, I think is called the power mate has a beater that is intermittently working now
Your hose could be bad. The wires frequently go bad up by the handle switch. also could possibly be the wand, those go bad. You can check that by attaching your powermate directly to the nozzle without the wand and see if the same problem is there. Do you have the mini powermate also? the one that is usually mounted on the wand. If so plug that in directly to the hose and see if you have the same problem. If that tool works fine then the problem is in the powerhead.
Jan 03, 2010 | Kenmore 23812 Progressive PowerMate Bagged...
Our Miele S 271 i won't start. About 10 years old. Is there any hope? Rod, Tasmania
I had the same problem with mine and it was the power cord. There was a break in one of the wires, probably from years of winding and unwinding as well as the stretching that occurs when trying to reach distant places without unpluging and pluging into a closer outlet.
Apr 23, 2009 | Vacuums
Kirby Classic Omega 1-CB won't run
you need to get a new switch. These wires are semi-permanent inside the switch. You can get it from any Kirby dealer. Just before starting the machine, check the ground on the windings to make sure that you have no shorts. When running, check for volatage leaks by placing one probe of your voltmeter on the cover of the motor and the other probe on a ground source. If the meter reads 50 volts or hugher, check for worn or frayed winding insluation.
Nov 02, 2008 | Vacuums
Power cord won't retract on anaerus 5500 vacuum cleaner
What you can do is take out the six hex screws on the bottom of the machine while on it's back. When all the screws are out, flip the machine back over, making sure you don't lose any of the screws. From there, open the bag cover and leave it open. Remove the cord release button. (The big rectangular button near the rear of the machine. Usually a firm pull up will get that thing out without incident.) Grasp the handle with one hand and hold the machine steady with the other. With a firm pull, pull upwards. This should seperate the chassis from the main cover.
With the machine guts exposed, place the main cover on the side for now. Now, this next part you can do one of two ways. You can either leave the cordwinder wires attached, (there's only 2 connected wires to the cordwinder, the white and black. Black is on the inside prong while the white is on the outside) or you can take the wires off. I find it easier to disconnect the wires.
Now, remove the cordwinder from it's place, making sure you take note of how the cordwinder rests in the groove from the motor. From there you can rewind your cord fully. Once this is complete, continue winding the cord while holding the cord in place. Take note of the spring. Make sure you are winding in the direction that is TIGHTENING the spring. Make sure you don't overtighten as the center plastic piece will surely snap due to the overtension. This may take a few tries, but be patient. Once you have met your estimated tension needed, replace the cordwinder, put the cover back on WITHOUT SCREWING IT BACK IN PLACE and replace the cord rewind button.
Replace the large cord release button and pull your cord out at least halfway. Hit your Cord rewind button. If your cord rewinds fully, congratulations, you got it in one try. Replace the screws and you are finished. If not, re-open the machine and continue rewinding the cord in the direction that TIGHTENS the spring with emphasis on overtightening. Once you break that center plastic prong, you need to buy a new cordwinder, so emphasize patience. If you're getting frustrated, go take a break and come back. Repeat until the cord winds fully, replace all the screws and you are finished.
Apr 20, 2008 | Electrolux Vacuums
Rainbow D4C power switch replacement
As far as I know, that switch with 6 terminals is still available. But if not, I would wire the 2 for the power head and the 2 motor wires together. Then you would have 4 leads to attach.
Jan 31, 2008 | Rainbow 75th Anniversary Canister Vacuum
Vacuums Logo
18 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
