Question about Konica Minolta bizhub 200 Printer
My printer is not connected right
My printer is not correctly connected to m y modem
  • Konica Minolta Master
  • 6,161 Answers
Do you mean router or switch?. Is this network Bizhub 200? Do have print drivers if not go to konicaminolta web site a down load FREE
Posted on Jan 06, 2015
Cant connect modem to new wireless brother printer
It is best you contact Arris support. Mark Motorola Mobility Support ARRIS
Jun 17, 2014 | Motorola Computers & Internet
Printer cannot connect to wireless network
Make sure that you're typing in the correct WEP/WPA password for your network. If you're sure you typed in the correct password, powercycle your router and printer then connect the printer again to your network.
You can also connect the printer using an ethernet cable straight to your router. Your printer will still be shared to your network.
Oct 08, 2012 | Lexmark 90P3000 - Printer Office Edge...
Changed modems from motorola to a cisco for faser internet. Printer will not link up. It can see the modem and pin has been entered. no connection!
Is the printer is connecting wirelessly, the you may need to redefine it on the printer. There are two possibilities :
If there is a key defined, make sure your printer has the correct key (aka passphrase) defined on it.
If there is no key and it is an Open SSID, then you can go for FACTORY DEFUALT settings on the printer if it not an issue and again configure the settings on the printer.
Also a power cycle can help the printer to re-associate with the new CISCO AP.
Mar 12, 2011 | Kodak ESP5250 All-In-One InkJet Printer
My d link router will not connect to the internet from my phone jack. I where I receive my phone and internet connections. What steps do I take to install to receive the highh speed connections?
The phone jack must be connected to a modem, which is then connected to the router via an ethernet cable. To connect:
1. Connect the phone cord from the jack in the wall to the jack in your modem of choice. Turn on the modem. 2. Connect a CAT-5 ethernet cable from the correct jack in the modem to the correct jack in the router. 3. If using a wired connection, connect an ethernet cable from the router to your computer. Otherwise, simply activate the wireless card of your computer and select from the available wireless networks.
Mar 11, 2011 | D-Link Office Equipment & Supplies
How do I pair up my printer with my new moden?
Hello Melissa !
What you need to do is to physically connect the printer to the modem, now your computer should be connected hardwired or wireless to this modem.
When you connect the printer to the modem , the modem will assign an IP Address to the printer, you can look on this ip address by printing a configuration report from the printer itself.
Now we have 2 options here, use the software that came with the printer (installation disc) to install the device and at some point of the installation it should detect the printer automaticaly, just remember choosing "network install"
If you already have the software on your computer, you will need to uninstall / reinstall the software so the computer can detect the new ip address. Or you can set the ip address manually by going under printer and faxes on the control panel, make a right click on the P4350 icon, go to properties, then the "Ports" Tab and click Add Port, you will need to select Standard TCP/IP, click new .. and then type the IP Address
This should connect your printer with your new modem - computer
Good Luck !!
You can contact me at:
eliteprintersolutions@gmail.com
Jul 17, 2010 | Lexmark P4350 All-In-One InkJet Printer
Alcatel 1000ADSL modem not working with new Wireless router
Delete your broadband connections in start ->control panel -> network connections
it is currently set as your default connection type. Remove it and if you set up the D - Link correctly, you'll go right online.
spin
Jun 15, 2009 | Alcatel (1000ADSL) Modem
Not sure if i have the fax connected correctly in
You don't need a modem to send/receive a fax.Plug it into the wall jack. Plug the other end into the "line" jack" on the fax machine. That's it.
Apr 10, 2009 | Office Equipment & Supplies
Connect Linksys 8-Port Switch to two PC's, a modem and printer
What's the model number of it? Is it a router/switch? Or just a switch?
The modem would go into a WLAN port. Everything else would go into the numbered ports.
If you pass me the model number then I can provide more information.
You'll want to connect one computer or laptop to it first before setting it up so you can configure the correct settings. You'll need the admin password. If it's just a switch, then you can just plug in; however, I strongly advise putting a router in between a modem and switch. You want to have a firewall in place.
Mar 31, 2009 | Linksys 8-Port (SD208) 8x10/100 Mbps...
WILL NOT PRINT
when it's asking for fax modem means that the printer is trying to connect somehow to internet (to connect to the homepage of dell probably) ..easy to get rid off this ..but first is the printer correctly installed (is it shown in your printer's folder (start>parameters>printers) ?
Aug 15, 2008 | Dell Photo 964 All-In-One InkJet Printer
I can't receive and send fax
The splitter the technician is referring to goes on the wall jack. One should have come with the "modem" installation package.
Take a regular telephone cord and plug one end into the splitter and the other into the line jack on the Fax/printer.
When your done you should have two phone cords connected to the splitter - one going to the "modem" and the other to the printer.
Nov 11, 2007 | Office Equipment & Supplies
Konica Minolta bizhub 200 Printer Logo
47 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
