Question about Kitchen Ranges
Wfg540h0aw The oven won't light. I hear the igniters clicking (4 times). I purchased the range in 11/13. My husband converted it to propane when he installed it and it has been working fine. All 5 of the burners work fine. Thanks!
  • Margaret Prentice
    Margaret Prentice Mar 20, 2014
    I'm not sure how I posed this under range hoods, but it's actually a Whirlpool gas range.
  • Margaret Prentice
Noggin
  • 944 Answers
SOURCE: Airking Granada 36" Range Hood - fan doesn't work
often these motors have a condensor on the side - a bit like a cross between the little white cylinder in a flourescent light housing and a starter motor - they are a bit vulnerable but are pretty cheap and easy to replace. Sounds like that is the problem - little click is it trying to start but not getting the extra help from the condensor. any good electrician should be able to fix it quickly, unless a part needs to be ordered in. he should also check if there is a fuse inside, and if the main part of the motor is ok. If the motor has died completely (which is rare) then it is still probably worth replacing, but might be a but costly. also there could be a relay connected to the switch (a way for a small switch to transfer heavier current to something) - and sometimes these can also fail. Also easy for an electrician to check and fairly cheap to replace. some motors also have a thermal protection device, which may be able to be reset by pressing a small button on the side somewhere, also possibly faulty and cheap and easy to check/replace. if you can look at the motor easily, just see if there is a small plastic push button switch (almost certainly connected to the body of the motor somewhere) if so, make sure the power is off, push it in and it should click to an "in" position. Might solve the problem. If you get a guy in to look at it and he is struggling to find the parts, please post again and we can try and source them online for you. If you fancy trying it yourself then post again and we can try and talk you through it, not TOO hard but you would need a bit of electrical knowledge and tools. Hope this helps :)
Posted on Mar 29, 2007
james klgr
  • 362 Answers
SOURCE: Kenmore Gas Range - burners won't ignite
its possible your gas regulator is bad or the gas line to the ignitor is stopped up look at the line and see if some type of food has blocked the outlet
Posted on Dec 08, 2007
jyackle5
  • 8197 Answers
SOURCE: Coverting a Vulcan 260L commercial range to Propane
Yes you can convert to LP gas. go to this web site to get the parts.
http://www.vulcanhart.com/manuals/F-30536.pdf
Go to page 9 and look at parts # 57 - 60 that is the part you need to change. You need to know the sea level that you are at though so you get the right part.
Now if you go to page 8 you will find where it goes part # 53 thru 61
To order the parts go to this web site
http://www.vulcanhart.com/parts.cfm
If any ? please fill free to ask.
Posted on Dec 17, 2008
SOURCE: Kenmore Propane Range won't bake
oven or broiler wont work stove top works fine
Posted on Feb 21, 2009
  • 10865 Answers
SOURCE: viking range burners won't light
All of these ranges have a spark module at each burner sight and they all click when ever you attempt to light one burner. Therefore, it can not be assummed that the spark module for those nonworking burners are actually clicking. Remove the burner covers and actually look for the sparks. If there is no spark make sure the connections are nice and tight. IF they are, you most likely need to replace the spark module.
Posted on Apr 30, 2009
How to adjust the oven flame in a Unique Elite Gas Range UGP-36E ON1?
contact your gas supplier . perhaps the person that converted it forgot about the oven orifice needing changed too
Aug 18, 2017 | Kitchen Ranges
Maytag Neptune wont heat up what is problem
We just converted my neptune gas dryer to propane. It ignited yesterday but we could smell propane. So, my husband fixed that ,now it won't ignite and heat up
Nov 10, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Please help!!!! My husband bartered for a
re ck with thermadore or one of there dealers . even a local propane service . most all ranges / heater's/ dryers / water heaters / ect can run or either fuel . now they may have misunderstood you . things like orfices will have to be changed and pressure reg will . but you should be able to mike ti work .. mm 84095 slc.
Dec 07, 2009 | Kitchen Ranges
I have a kenmore range the oven burner does not work but the broiler does. The igniter on the oven element appears to glow in preparation of lighting but propane does not come out of the element. Now when...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
sgf
Nov 16, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Can't get stove to light
you must get some flame and put were the gas is
Sep 11, 2009 | GE Spectra JGBP30 Gas Kitchen Range
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore gas (propane) range Model #119.7488810 18-20 years old
you have a bad oven/bake ignitor, althoough you see ther glow, its not "hot" enough to allow gas flow or ignition, very common issue, 2 screws and 2 wires, probably about $75, service company gets min $225..
Oct 18, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Installation
I have a jenn air gas range with a convection oven and want to convert it to propane, but can't get an instllation manual to find the part numbers or instructions.
How do I get them?
Aug 09, 2008 | Jenn-Air JGR8775QDS Gas Kitchen Range
Kitchen Ranges Logo
82 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
