Question about Konica Minolta Bizhub-200 Minolta Printer
Computer can't find
I moved and trying to reconnect to my modem
  • Konica Minolta Master
  • 6,161 Answers
Modem refers to fax line?????
Posted on Jan 10, 2016
I had unplugged my wireless modem and now I cannot get it to connect to the internet. I tried to reboot and nothing worked. It is recognized in my computer.
Try unplugging and reconnecting Ethernet cable to modem. Reset the modem if there is a separate modem than the wireless modem (i.e. Cable modem). Your pc acknowledging the wireless modem does not mean your Internet should work, although a prerequisite... If this is no help, may need to connect to wireless modem (via http://ip address) and configure settings. It's likely though the issue is wireless modem not communicating with cable modem correctly if you have a set up like that.
Jul 25, 2011 | Computers & Internet
I have a linksys WRT54G, and I'm trying to hook up a wi-fi connection. As of now, my internet is Internet Explorer, and my current modem is a motorola SB5101. The Motorola modem is hooked up directly to...
Hello
Try this
1 disconnect all wires,including power from the modem and router.
2 Find reset button on router usually in the back,need a pen tip or paper clip to hold it in.
3 Hold in reset for 1 min.
4 Reconnect modem first,power up.
5 Reconnect router second, power up.
Try changing the ethernet wire from the modem to the router.
So your going to have your cable coax wire to the modem.Then a ethernet wire from the modem to the router,then a ethernet wire from the router to the computer.
Sounds like you may have one wire in the wrong place.
Dec 29, 2010 | Linksys : WRT54GS Wireless-G Router W/...
I try 2 plug my modem up 2 my ps3 but the ip address timed out wat do i do
After you have the Ethernet cable from your modem plugged into your PS3 press and hold the reset button on the back of the modem for about 5-10 seconds. This will reset the modem so that it will recognize the connect to your PS3. Once your done using your PS3 and reconnect the Ethernet cable back to your computer you will have to reset the modem again. Any time you move the Ethernet cable from one device to another you need to reset it after you have the cable connected to what ever device you want to get online with at that time. If you do not want to keep resetting your modem all the time a router will allow for you to have more then one device online at a time. The router will connect to your modem and then your devices will connect to your router.
Sep 24, 2010 | Arris Touchstone 450a (CM450) Modem
Reconnecting to internet after recovering from sleep mode
There are many causes of this, but the most common can be solved by going to the CMOS (BIOS) of your computer and disable the power saving on the ethernet, PCI or wathever where you modem is connected.
Jul 18, 2009 | Arris SURFboard SB5120 Modem
I was using this router without problem then I moved. After reconnecting I show I am connected to the internet, but cannot browse any page. Turned everything off. Unplugged everything. Started with...
the wireless router settings must be wrong, try pressing down the reset button and hold it for alteast 30 seconds to reset the Wireless, ones that is reset try again.
Also can you tell me the brand and model of the router so incase the problem is not solved I can get you instructions.
Thanks,
Ekse
Jun 19, 2009 | NetGear WGR614 Wireless Router
MODEM ON HOLD-
is pc showing this modem in control panel under system icon? now try uninstalling Modem and reconnecting it and plug in phone line......if software cant detect it on boot up ...then it sounds like a defective modem.....
Jun 11, 2009 | Agere All 56K Modems: 56K V.92 Lucent/...
Belkin Wireless G Router causes loss of internet connection
Does your router have one LED lamp for each "wired" port?
If so, does unplugging the Ethernet-cable (the one that connects to your desktop PC) cause the lamp to go off?
Does reconnecting that cable cause the lamp to go on?
Also, on your desktop computer, there could be a lamp right beside where the Ethernet-cable connects into your computer.
Again, disconnect the cable, and reconnect the cable, to see if that lamp goes off/on.
Have you tried a different cable?
Do *NOT* connect your desktop computer to the 'WAN' port on the router -- connect it to any of the "LAN" ports.
Dec 22, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Motorola SB5101 Modem disconnects
* If you can connect after disconnecting power and reconnecting, it means there is formation of static charge on modem
* Check whether there is any cordless phone or any other satellite devices next to the modem. If so, move the modem 10 feet away.
* If your modem is placed on carpet, please place it on wooden desk
If this doesnt work, please dont rate me down, if it works, please rate me as fixya!!! lol...
Have a nice day!!!
May 18, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Wireless Router Setup
There are a few things that might be wrong here. So let's go over the basics.
First off, make sure that everything is connected in the same way that it was previously. You have probably done this, but double check.
Second, try connecting your computer directly to the DSL modem through the ethernet cable. This will confirm where the problem has arisen. If you can get internet this way, but not after going through the router, than move onto the next step, otherwise, something has gone wrong in the DSL modem, or somewhere else, and it does not concern the router.
Lastly, your cable modem may have been only a modem, which means that it did nothing other than give you internet access. However, with many DSL providers, the "modems" they supply you with are more of a 1-port router than a modem. What I mean by this is that there is a good possibility your new modem blocks it's connection on certain ports.
Many DSL modems have a function to make them act as only a modem, and let a router do its job separately, but this will be specific to your modem. You may want to contact your ISP about this further.
Anyway, I hope this helps, and I wasn't too confusing. Good Luck!
Nov 15, 2007 | NetGear RangeMax WPN824 Router
21 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
