Question about Cuisinart DCC-1000 Coffee Maker
Inconsistent turn on
Sometimes the switch does not function. I started to try to take the unit apart and then the light s went back on
Inconsistent power
If it's totally dead, the main fuse may have blown. However, since it was inconsistent before it went dead, it might lead me to think that you have a loose connection. Sometimes they heat, lose continuity, and then work again when they cool. A defective thermal protector might also cause this.
Dec 20, 2013 | Whirlpool WMH1163XVS Microwave Oven
Inconsistent crisp images
Try raising the ISO setting to stop the action better.
Apr 25, 2010 | Panasonic Lumix DMC-FZ8 Digital Camera
I was playing and my system shut off. the indicator light was blinking red. i hit the power button once and the indicator light went back to a solid red light. i tried turning the system back on and the...
You need to have the motherboard fixed, do to so you need to take the PS3 apart then reflow the board.
there is a great 6part video guide on YouTube to view for free. 6 videos from the same fellow, each video about 10mins long, goes over everything for you.
http://www.youtube.com/user/gilksy1 and its free unlike some eBook site.
I actually used the videos shown by this guy to fix about 30 PS3 units with no problems, you just need a few things though like a heat gun and some thermal paste. sounds hard, but it's very easy once you start!
Hope this helps in some way.
Jan 04, 2010 | Sony Playstation 3 (PS3) Console
MOTU 828MK3 led's flash then no lights do they have a switching power supply ?? Any one have a diagram of the unit
I have a MOTU 828 MK3 and have had trouble with the display lights not working on one of my units. I tried the unplugging and switching from 120 to 220 and back. Sometimes when I started it up it would come on and quickly go off or not even come on at all. I was using the unit by reading the numbers using a flashlight. One day I noticed the light undulating as if trying to come on and I just rubbed my finger over the light as if to try and coax it to come on. The next time I turned the unit on the light came on and stayed lit for the entire session. The light has only gone out one time since, after many sessions. The time it went out, I just rubbed the top of a finger over the display and it came on the next time the unit was started. I now make a habit of rubbing it every time I turn it on. It has not failed since. Sounds funny as it might just be my karma, but I think it more likely that it works because of a slight static charge that I create with the light rubbing of my finger. Just thought you might like to know. Doc Mason
Nov 06, 2009 | Audio Players & Recorders
Noisy and inconsistent cooling
It could be that there is a problem with the Thermostat\low voltage switching. Some heat pumps have reversing valves activated for cooling , sometimes for heating. Whoever installed this for you is totally responsible for your unit still. There can be a number of things going wrong, like no filter drier in stalled and sporatically clogging the refrigerant and making a lot of noise. Call the installer back.
Jul 13, 2009 | Heating & Cooling
Brake lights don't work, all other lights do
THE PROBLEM IS IN THE MULTIFUNCTION SWITCH, REPLACE IT.
Jul 09, 2009 | 1996 Chevrolet K1500
Electrical problem???
Yup... electrical problem,,,, I'd start by checking body ground (only thing common to problems you listed) then, check sub-system power supplies for loose or corroded connections. Sometimes just unplugging and plugging back in is enough to get better contact, so pay attention to what you do and if something specific helps, take it apart again & clean it up better!
Dec 22, 2008 | 2004 Chevrolet Impala
Hello..my convertible top works 5 times out of 6 ... sometimes it goes almost all the way up and stops right before latching to the top of the windshield...but it is inconsistent. Any suggestions? Thank...
you need to adjust the motor. under the the rear window on the inside of the trunk there is three bolts holding it in. just move in small increments and test... do you have any lights on when this happens? like "convertable top"????? you have to reprogram it then.... let me know and i can guide you thru it
Oct 10, 2008 | BMW 325 Cars & Trucks
No Heat!
Sometimes too much dust around the heating elements can cause the heater to switch off to prevent a fire. Check for dust build up first. You can try using a can of compressed air that can be found at many electronic stores.
Oct 26, 2007 | Vornado EH1-0014-01 Compact Heater
Cuisinart DCC-1000 Coffee Maker Logo
26 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
