Question about Zanussi ZDC37100W Electric Dryer
Zanussi zdc37100 The red light on the start button keeps flashing
Red light keeps flashing green light will not come back on
  • 1294 Answers
SOURCE: Zanussi err problem
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 06, 2008
  • 3 Answers
SOURCE: Zanussi WJS1265 start button problem
I have had this problem which was caused by a mismatch between the power supply
socket and the 13amp plug. by changing either you can see if you get a result..what was happening was as soon as any current was drawn as the machine tried to start the high resistant contact causes the voltage to fall and the programmer stops . The same effect can occur as the heating cycle starts. a good quality plug may be the answer,
Posted on Oct 22, 2008
SOURCE: My zanussi zwf12070 washing machine will not do
If I am correct and 3 red flashes and 1 green then that is E31 which is normally a heater fault but can also be a faulty pressure switch or main programmer.This machine is covered by the 5 year major parts warranty.Does not cover the heater and it is normally the heater for that code.You can either get an Electrolux engineer to call out or your local service guy but be warned that only genuine heaters can be used on these machines they have safe fail fuse links in these elements.
Hope this was helpful.
Posted on May 05, 2010
Testimonial: "Thank you very much - very helpful"
SOURCE: hi my zanussi zwf1432s stopped halfway through
Hello Paula,
Do not know how many flashes but 1green/1red = 11 water pressure low.
2green/1red = 21 blocked filter or pump fault.
You would be best firstly checking the filter and make sure it is clean and pump turns.with water drained and filter out shine torch into filter put on spin/drain and see if pump blade spins if not then try and turn with long screwdriver to free out any debris then refit filter and check for leaks and try donnt fill fully until you are happy it can drain water.
Hope I was of some help.
Good Luck
SOURCE: HELP! My Zanussi Diplomat APM8702 will not start.
dryer not heating
Posted on Jun 16, 2010
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
Sep 08, 2014 | Zanussi Washing Machines
Just the power light comes on
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Dec 02, 2012 | Zanussi FJS1225W Front Load Washer
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Hope this helped.
May 18, 2010 | Washing Machines
Zanussi TCE 7276W Condensor Dryer - no red lights but won't go!
Hello, have you cleaned the condensor stack just recently if so check that the stack etc is fitted correctly and the door is closed fully.
Hope this helps.
May 14, 2010 | Dryers
My zanussi zwf12070 washing machine will not do anything. The start button flashes red three times and then turns green. The door opens but the machine does nothing. Please help. This machine is only...
Apr 22, 2010 | Zanussi ZWF12070 Front Load Washer
Has the condenser been cleaned lately if it is not put back in correctly then sometimes the micro switch on the door does not click in,check this door where the condenser sits.
Hope this helps.
Mar 25, 2010 | Dryers
Light keeps flashing red,amber, green
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing?
If you get no noises this usually indicates a board fault and you should look for a new printer.
Apr 07, 2008 | Brother HL 5140 Laser Printer
Indesit
hi there first of all check your filter located at the front of the machine for blockages as this is a comon fault, failing that next time the dial clicks round count the amount of times the red light flashes before it does a pause then starts again, and let me know how many flashes it does as this corasponds to a fault code
murdozzz
Dec 09, 2007 | Zanussi WJD1667W Front Load Washer / Dryer
Zanussi ZDC37100W Electric Dryer Logo
Top Zanussi Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
