Question about American Seating Company American Seating File Cabinet Keys and Locks
Why does key marked 131E work in my lock with code A4365?
Do different key makers use different codes when making replacement keys? Is there a crosswalk for codes on keys and locks?
2000 Trooper LS. Why won't the ignition key unlock any of the doors? (the metal key part)
  • Some of the locks have been probably changed before.
  • Or you need to get original keys for truck, copies just get worn out by use.
Here a link to your SUV manufacturer:
Good Luck!
JP
Help Isuzu com
Jul 13, 2015 | Isuzu Cars & Trucks
Tip
All nokia secret codes part5
 Mixed * # 92702689 #, then switch - system menu off (goes with me not)
The following code do not fold (with me also):
* EFR0 # (* 3370 #) EFR activate (EFR = Enhanced Full rate Coding - language optimization)
# EFR0 # (# 3370 #) EFR switch off
* HRC # (* 4720 #) HRC switch on (HRC = helped rate Coding - language compression)
# HRC0 # (# 4720 #) HRC switch off
SIM LOCK Simlock status query: (use "*" the key over "p,w" and "+" indications to enter)
# pw+ 1234567890 +1 # Provider LOCK status
# pw+ 1234567890 +2 # network LOCK status
# pw+ 1234567890 +3 # Country LOCK status
# pw+ 1234567890 +4 # Sim Card LOCK status
The code 1234567890 must be computed with a program e.g. SmartDCT4Calc and/or DCT 4 code Calculator from IMEI, etc....
Info. to Simlock: SIM LOCK makes it for the offerer/network carriers possible, subsidized (verguenstigte) Handys to offer. Thus one makes oneself if necessary punishable if one SIM LOCK deactivated - in addition the warranty can purged. I take over for it no adhesion or responsibility!
GSM code ... should function at each Handy - however Netz(betreiber)abhaengig are... and "harmless"...
Generally applies: First enter code, "send" afterwards (< send green key > press) and one moment wait...
SMS Tipps To Tipps & cheat about SMS (with appropriate codes) are immediately in the FAQ list .
For example for the topic: SMS "******" and/or deferred send, acknowledgment of receipt, reports...
Mark more simply To Tipps & cheat to the topic "mark" e.g. with SMS entrance.
Over simply to mark simply the "pin" (ABC key) hold some e.g. SMS and move then Jostick downward.
on May 12, 2010 | Cell Phones
I bought a geo prism year 1991,and they only had one key and my little brother borrowed my car and lost the only METAL key? What can I do?
have your brother go to a junk yard and get a used steering column and keys and switch it,or buy a new switch for 40 bucks, Search from over 10 Million Auto Parts
Jul 10, 2015 | Geo Cars & Trucks
Where would i be able to get a key for my door?
I go to a junk yard and purchase a set of locks and keys for all the doors and replace the cylinders with the new purchases. Now make copies of your new key. Some dealerships have records of your car or maybe you have a stamped piece of metal or documents with key code. The code once found in the dealership book gives the key codes so that they can punch another key up with a machine they have.
Oct 15, 2013 | 1997 Volkswagen Jetta
2000 Buick Century - Replaced steering column with salvage unit with different key, now vehicle wont start, please help!!
The BCM (body control module) is seeing the wrong passkey code. You will have to find out what passkey code is being used in the new steering column you installed them see if the BCM can be reprogrammed for it Some can not be reset.
Oct 17, 2017 | 2000 Buick Century
Does anyone have keys for Gunvault gv2000? Lost my keys during a move. Did not use the electronic key pad. Any ideals?
That is like asking if we have the keys to your house or car. They come keyed different, however if you are lucky there is a code on the lock it self. Best solution take it to a locksmith shop. Look for one that had been around for at least 10 years and preferably works on safes. This lock can be picked open and keys fit though not easily. The easy way is to drill it out and replace the lock. Unfortunately the cost of this is going to be close to a new container so I hope it has a code on the lock 20-30 bucks on the high end for a code key. Take it in to a lock shop.
good luck.
Sep 14, 2011 | Gunvault Multivault Deluxe Safe Storage...
Car has been running fine. Parked and locked from the inside, not with remote. Few hours later unlocked with remote and car will not start, not even a click. Have checked all connections, wires, fuses...
I just wrote a repair for a guy to replace the passlock sensor, but it doesn't sound that extreme. Your key has a chip in it for the passlock security system, there are 13 different resistences for these chips. Make apsolutely sure the key you had cut, has the same coded resistence (eg. code 2 will turn the cylinder of a code 3 ignition, but will shut down in a few seconds.) If you have a code 2 key make sure you order a code 3 key before you have it cut. All 13 different keys can be cut to be able to turn in the ignition but only the right code will stay running.
Jan 27, 2011 | Buick Riviera Cars & Trucks
Bought a barrecrafter car rack off craisglist...i bought it with no keys because the ownr lost them...i need a replacement
look and see if there are any letters and numbers scribed on the face of the lock cylinder, this is the key code-- with this code you should be able to go to your local locksmith and they will be able to cut you a ' key by code ' and it will work. if there is no code on the lock then you can also just take the rack to the lockshop and they will be able to pick and remove the cylinder from the lock and fit a key to it by hand. normal shop rates for making a key in this fasion is about $12-$15 dollars and if you want more than one key - duplicate keys cost about $1.75 to $ 2.50.
(( even if the lock does have numbers on it -- take the rack to the shop with you to make sure the key that they cut by code works before you leave the shop,,, saving you a second trip ))
c...
Jan 05, 2011 | Barrecrafters /sportrack, Sx-12...
Removal of ignition key lock
please be specific on year make and model and if your key had a chip in it there are special tools for dismantling steering columns each generation of cars are different to work on if your key has a chip in it you just cant change it because the code is stored in the cars computer ( anti theft ) you cant start the car without proper key new keys come blank and unprogramed the dealer cuts the key to work your lock then programs the transponder to match your computer code so the car will start
Oct 03, 2010 | Chevrolet 3500 Cars & Trucks
American Seating Company American Seating File Cabinet Keys and Locks Logo
76 people viewed this question
Top American Seating Company Luggage & Travel Experts
Dave braun
Dave braun
Tom Chichester
ray gallant
Are you an American Seating Company Luggage and Travel Expert? Answer questions, earn points and help others
