Question about Amana 4.8 Cubic Foot Self-Cleaning Electric Range Aer5830vab Bla
OWN SINCE JULY 2013. WAS COOKING SMOOTH ON 12/20/2013 WITH (RACHEL RAY PAN) HEARD A LOUD POP AND NOTICED THE GLASS HAD CRACKED UNDER THE PAN! AMANA REPLACED IT. ON 3/7/2013 WAS COOKING ON SMAE BURNER
HELP IF YOU CAN??
4 Suggested Answers
DeBruce
  • 145 Answers
SOURCE: left a empty pan on hot burner and glass top
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Posted on Aug 23, 2009
  • 1891 Answers
SOURCE: Amana Glass cooktop 2 out of 4 burners not working
it is not a fuse. as if it shorted it may blow it and then nothing .. the sw to either one burner is at fault replace the sw 's ( both and the cook top should be ok . sw cost around 25 to 40 ea ..
Posted on Jul 16, 2010
livewire874
  • 618 Answers
SOURCE: i have a cracked glass cooktop amana can i just
Top can be replaced but is around 4 to 500 dollars .
Posted on Dec 07, 2010
Can the glass of a whirlpool cerano hob suddenly crack?
You didn't need 'red hot' to simmer. When you got it red hot, and then put the pan on it, the pan sucked the heat out of the ring to fast, and caused stress in the glass causing it to crack. Tops are meant to be used the way you used it. Your fault I am afraid.
The top can be replaced.
Sep 19, 2016 | Whirlpool 30" Schott Ceran Surface...
Jenn-Air Cooktop JED8430BDS
That is an obvious burned wire, or burned thermal cutoff etc
Nov 09, 2013 | Jenn-Air JGD8130 Gas Cooktop
Jul 13, 2010 | Amana AKT3040 Electric Cooktop
I have an LG glass cook top stove. It is just 3 years old. While cooking pancakes on a flat pan, the top cracked down the middle..what could have caused this
Only a couple things would cause this First if it is to tight in the opening. Next is there was a small crack on the edge somewhere and when it heated up or the slightest vibration expanded it similar to a small chip in a windshield that grows over time.This could easily happen during installation if not being very careful. And finally is a defect in the material, This is probally unlikely but possible look at the glass very carefully for flaws. If you find any see if LG will repair for free.
Jun 18, 2010 | LG Cooktops
My amana model AKT3040 is making a loud "pow" when i turn it on with a white flash under the glass, then the breaker trips. It is 6 years old this month, not under warrenty, Should i try to get a repair...
Amana will confirm this - but I am fairly sure that the elements under the glass are replaceable. Most units by other manufacturers are repairable...but if yours is not, then careful shopping around will save a ton on parts cost.
Labor will vary by market...but it is typically better to have the replacement part when contacting a repair service.
Oh, yes, the snap is a broken burner element. the breaker trips because the resistance on a shorted element is insufficient - and the current draw becomes excessiver - popping the breaker.
Nov 06, 2009 | Amana AKT3040 Electric Cooktop
I was cooking popcorn on my glass cooktop and the pan appears to have scratched to surface.
You may have melted the bottom of the pan you were using into the glass. Copper bottom and alum pans sholdnot be used at high temps on a glass top. (never use porclin or glass pots)High temps can etch(mark or discolor) the glass.
Oct 30, 2009 | KitchenAid 30 in. KECC506R Electric...
Kitchenaid 36" glass cooktop with small crack
A small crack, turns into a big crack, Short of ordering a new piece of glass, there is no "fix" sorry. YOu can continue to use it, but eventually it will run across the cook top, and then shatter the glass... Better be safe than sorry.
Jul 31, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Left a empty pan on hot burner and glass top turned smokey under glass and left tiny pit marks on surface the color of the top is black
Jul 23, 2009 | Amana AKT3650 Electric Cooktop
Radiant cooktop blew a fuse?
Call the service tech it;s under warranty and, this model is notorious for this fault
Apr 21, 2009 | General Electric 36 in. Profile PP962...
Amana 4.8 Cubic Foot Self-Cleaning Electric Range Aer5830vab Bla Logo
59 people viewed this question
Top Amana Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Thomas Perkins
Thomas Perkins
Are you an Amana Cooktop Expert? Answer questions, earn points and help others
