Question about Kenwood KDC-400U CD Receiver with 3 Lines of Text and USB
Protect mode and want come out of it what do i do
SHARP BA200 Protect Mode?
Check the speaker wires for shorts, if okay! the audio output ic's are loading the circuits causing the protect mode to engauge, only option replacement of the above mentioned parts.
Apr 21, 2012 | Sharp CD-BA200 CD Shelf System
What's your problem?powerprotection mode unlock
If the protect function works and causes hindrance to trouble shoot, cancel the protection function as described below, and it will be possible to enter the self-diagnostic function mode. (The protection functions other than the excess current dtect function will be disabled.)
While pressing the "Tone Control" and "Info" keys, press the "Power" key to turn on the power and keep pressing those 2 keys for 3 seconds longer.
The seld-diagnostic function mode is activated with the protection functions disabled.
In this mode, the "Sleep" segment of the Flourescent Display flashes to indicate that the mode is self-diagnostic function mode with the protection functions disabled.
Caution!!!! Usiong this product with the protection function disabled may cause further damage to your unit, so use special care when using this mode.
Apr 18, 2012 | Yamaha RX-V671 7 Channel AV Receiver -...
In my samsung champ mobile one message had came in this message the protection mode is on and when I off the protection mode or try to delete the message the phone get restarted
Feb 02, 2011 | Samsung Cell Phones
Kenwood car stereo cd player reads protect mode how do i fix this
i have a kenwood kdc-241 car stereo and it has gone onto protect mode i have done everything it says in the manual and even taken it out of the car just in case it was damp i have tried putting it back in but still is in protect mode can anyone help me please
May 25, 2009 | Kenwood Car Audio & Video
Stuck in protect mode
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
May 04, 2009 | Sony STR-D1015
Protection mode
It's normal for some amps to go into protect for a few seconds when initially powered up. If it remains in protect mode, it may have shorted output transistors. To eliminate other possible causes, read through the following troubleshooting page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Dec 11, 2008 | Phoenix Gold Titanium 800.1 Car Audio...
How do I take my AG-8520 Audio/Video Receiver out of Protect Mode
go to the help and support section of your laptop, and type in protect mode. This should pop up a list of options for you to take it out of protect mode.
Nov 13, 2008 | Acer Aspire 3690-2196 Notebook
Why does my amp stay in protect mode?
The most common reason an amplifier goes into or remains in protect mode is shorted output transistors. To eliminate other possible reasons for it to go into protect, read the following page.
Troubleshooting - Amp in Protect Mode
Aug 03, 2008 | DHD NTX-2139 Car Audio Amplifier
Protection mode
you have to verify your connection cause if you are a short circuit in your different output or input the protection mode is on. it's an internal security
first disconnect all your output speakers, and restart your amplifier if the protection mode is on again try to disconnect all your input device and restart your amplifier, the protection mode should be off, so after connect one device after one to check who makes your protection mode on
Mar 31, 2008 | Onkyo TX-SR502 Receiver
Shuts off protect mode
i have a jvc stero and every time that i turn it on ...it show protect and shuts off!
Jun 25, 2007 | JVC HX-C6 Shelf System
Kenwood KDC-400U CD Receiver with 3 Lines of Text and USB Logo
27 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
