Mhw6000aw door will not unlock when done
    Sergeant:
    Champion:
  • 266 Answers
Probably a sign it has not pumped out fully. Press and run the rinse cycle again to see if there is a blockage..if door doesnt open try switch off, pull wall plug...wait and retry
Posted on Mar 20, 2014
Where are the fuses for the power dock locks on a 2006 montecarlo06ss
DR/LCK fuse 25 amp . located in the I/P block
Fuse Block - I/P
In the right front kick panel
Power Door Locks System Components
The power lock system consists of the following components:
• Body control module (BCM)
• Driver door lock cylinder switch
• Front passenger door lock cylinder switch
• Driver door lock switch
• Front passenger door lock switch
• Door lock actuators in each of the doors
• DR LK Fuse 20-amp
Door Lock System Controls
The Power Door Lock System is controlled by the body control module (BCM) and can be activated by any one of the following:
• A door lock switch lock or unlock actuation
• A door lock cylinder switch unlock actuation
• A keyless entry transmitter actuation
• An automatic door lock actuation (Personalization function)
• An automatic door unlock actuation (Personalization function)
Door Lock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the lock position, it switches the door lock actuator lock control circuit to voltage. Since the lock actuator unlock control circuits are at ground potential within the BCM, the door lock actuator motors transition to the lock position.
Driver Door Unlock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the driver door lock actuator unlock control circuit to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the left front (LF) door lock actuator motor transitions to the Unlock position.
The driver door lock actuator unlock control circuit is a dedicated control circuit used only for the driver door lock actuator motor. This is done so that the driver door may be unlocked by itself using a keyless entry transmitter or an automatic door unlock function (if programmed).
Passenger Door Unlock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuator motors transition to the unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuator motors. This is done so that the driver door may be unlocked separate from the passenger doors using a keyless entry transmitter or an automatic door unlock function (if programmed).
Mar 23, 2017 | 2006 Chevrolet Monte Carlo
2005 Buick Rendezvous you can hear the relay clicking but the door locks will not open and close
Check for broke wires inside the boot from body to driver door , this is a common problem . If you don't find broke wire's , pull the door panel to get at driver door switch . Check for voltage an ground circuit .
Rendezvous Door Lock System Components
The power door lock system consists of the following components:
Door lock system fuse into the BCM (BCM D 25A fuse)
Door Lock Operation
When the BCM detects a transition of either of the door lock switches to the LOCK position, it switches the door lock actuator lock control circuit to voltage. Since the lock actuator unlock control circuits are at ground potential within the BCM, the door lock actuator motors transition to the Lock position.
When the BCM detects a transition of either of the door lock switches to the UNLOCK position, it switches the driver door lock actuator unlock control circuit to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the LF door lock actuator motor transitions to the Unlock position.
When the BCM detects a transition of either of the door lock switches to the UNLOCK position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuator motors transition to the Unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuator motors. This is done so that the driver door may be unlocked seperate from the passenger doors using a keyless entry transmitter or an automatic door unlock function (if programmed). This video on testing computer controlled door locks on a Subaru , doesn't matter . test yours same way > The BCM controls your door locks .
Are all of the power door locks inoperative from both door lock switches?
Oct 12, 2016 | 2005 Buick Rendezvous
Maytag maxima XL washer is not spinning out the water how can I fix this?
Pump, filter or drainage problem.
Check there is nothing jammed in the pump or the filter.
Make sure the drain is not blocked or running "up hill"
Mar 14, 2016 | Maytag MHW6000AW Maxima XL 27" White Front...
My key not working for my 2002 BMW 330i cant lock or unlock doors
Unlock vehicle
enter vehicle close driver's door
switch ignition on and off
remove ignition key
press and hold unlock button
press lock button briefly 3 time within 10 second keeping unlock button depressed release unlock button .
job done
Jul 19, 2014 | Cars & Trucks
Front load washer. Door will not unlock get error code "do" or FL. Door lock light is not on but door is locked and wont unlock. You csn hear a buzz as the lock energizes but does not unlock. Allready...
Sturdy little door, isn't it? Make sure you don't have extra water in the machine, as this will cause the door to not unlock. With that done,unplug your washer. If you can get the top of the machine off and reach down the front of the washer, you should see the latch mechanism. Push this down. Door should unlock. Now. Buy a new latch assemby.
Mar 16, 2010 | Maytag MAH8700A Front Load Washer
Whirlpool range self cleaning oven door won't unlock after the cleaning cycle was done. gets error code -f5-
I took the back off the stove and manually moved the door locking mechanism to unlock the door. Then started a cleaning cycle untill the door locked. Cancled that cycle and the door unlocked just fine.
Seems OK now.
Oct 15, 2009 | Ovens
Can't unlock the driver door
sounds like door motor has packed up,take of panel inside car and try to get your arm down to the unlock motor and work it manually to unlock it,good luck cause it aint easy done a few of these ....
Oct 19, 2008 | 1999 Volkswagen Passat
2008 dodge caravan se minivan
hit menu on your message center and cycle through choices, press step to pick option
Aug 15, 2008 | 2007 Dodge Caravan SXT Minivan New Cars
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
