Question about MagnaFlow 2003 Chevy Impala - 3.8L V6, code K engine, with federal emissions system - Catalytic Converters - 49 State Legal
All gauges fluctuate
I just changed my whole coolent system but the last time i drove it my gauges kept dropping to zero. so i cut the car off and now it dont want to start back up. the radio and everything comes on but when i got to turn the key to start everything goes out
Temp gauge stays cold
If the thermostat is bad (i.e. stuck open at all times), this would allow coolant to circulate in the engine even when it is below the desired operating temperature. This leads to OVERcooling of the engine. You can either replace the thermostat as a first step or remove it and test it -- closed when cold, open when heated above 190-200F.
Jan 30, 2014 | Chevrolet Malibu Cars & Trucks
Oil pressure drops to zero on avalanche
If there truly was no oil pressure it would make a horrendous rattle sound from not only the rods but especially the hydraulic valve lifters. It sounds like probably the pressure sensor or the wiring, or both are not reading correctly. The older Chevy V8's had the pressure sensor on the side of the block, under the exhaust manifold where it would just cook it and make it leak and not work right. I always kept a direct reading pressure gauge with hose and adapters in my tool box when I felt I couldn't trust the onboard gauge. Many times it proved the gauges and idiot lights wrong.
Dec 07, 2013 | Cars & Trucks
The hold light is flashing, and the temperature gauge is not working. problem just started. Drove about 10 miles home.
my 2009 aveo hold light and rpm gauge stop working at the same time,what we did was change the coolent sencer. that worked
Aug 19, 2011 | 2009 Chevrolet Aveo
Dropping oil pressure
You need to put a mechanical gauge on it to read actual oil pressure, sometimes the sensor is wrong, have seen the gauge be off (even on newer than yours). The first thing anyone would do is the mechanical pressure test with a screw in oil pressure gauge. That would be my advise.
Aug 03, 2010 | 2002 Chevrolet TrailBlazer
Rpm gauge dropping to zero while cruising in car
My Grand Prix Pontiac 2000 stops for no reason. Have had the mechanic do a diagnosis test but couldn't find anything. Any help would do.
Apr 22, 2010 | 2000 Pontiac Grand Prix
Temp. gauge reads high some times. but the motor really isnt hot
It sounds like the coolant temperature sensor is beginning to fail. It is highly unlikely that the in-dash gauge is a problem. The coolant temp sensor inputs to the computer affecting everything from radiator fan speed, engine fuel/air calibration and a variety of other parameters.
Be absolutely certain to "burp" every bubble of atmosphere from the coolant system too. Air bubbles have the amazing ability to prevent coolant flow and will cause all sorts of problems, especially if the bubble wants to hang around the temperature sensor location.
Normal operating temperature is going to be around 210 F.
Most Autozone, Advance locations will read engine problem codes at no charge, so drop by one of those locations and let them read the problem code.
My guess will be the coolant temperature sensor. Then have the problem code reset, remove all air from the coolant and let us know how this worked.
Mar 11, 2010 | 2004 Chevrolet Impala
Transmisson shifting problem
Which engine ? is the car driving fine then RPM's rise higher and higher, and then...BANG it shifts, do you feel shutters ect ?
Feb 01, 2010 | 1995 Chevrolet Lumina
I have a 2005 Isuzu ascender, the gauge light keeps coming on. The oil gauge drops to zero. I have gotten an oil change and new filter. What can the problem be now?
It could be a bad oil sending sensor, or the oil pump. When it drops, does the gauge stay on zero or fluctuates. The sending sensor isn't to bad to replace or cost wise, but pump is a different story. Have someone check the sending unit or just have it replaced to see if that's the problem.
Jan 17, 2010 | 2005 Isuzu Ascender
Voltage Gauge drops suddenly to zero
Charging system grounding out, poss inside alternator
Jan 31, 2009 | 2001 Jeep Cherokee
MagnaFlow 2003 Chevy Impala - 3.8L V6, code K engine, with federal emissions system - Catalytic Converters - 49 State Legal Logo
27 people viewed this question
Top MagnaFlow Electronics - Others Experts
Fred Sops
gbob59
Lawrence Oravetz
Are you a MagnaFlow Electronics - Other Expert? Answer questions, earn points and help others
