Question about ibibo.com
Please check your internet connection or firewall settings while signing in ibibo games. can someone help me for fixing this problem
Hi, I have this problem with ibibo. Everytime i try to log in to ibibo games Sign in timed out, please check your internet and firewall settings?
Check that your computer's CLOCK and TIMEZONE settings are correct. Wrong values imply "too much time", which leads to the error-message.
Feb 04, 2014 | Microsoft Windows XP Professional
Feb 03, 2014 | ibibo.com
Problem of not connecting to the internet.
Your laptop frewall settings should be controlled. You may have two firewalls. One is dealing with Windows firewall, other one is dealing with your modem firewall settings. Check the both please.
Checking the firewalls:
Step 1 : open this address http://192.168.1.1 Log in with your admin password. Check the firewall settings. This will solve the problem. Or.
Step 2 Start/Desktop Manager/Security Center/Firewall
This will solve your problem I hope.
May 02, 2010 | Acer Aspire 5315 Notebook
Sir i cant access yahoo on my system can you provide me any suggestion
I have 3 suggestions: 1. Go to Messenger>Connection Preferences> then, you choose either connection directly to the internet or connect via a proxy server, and then choose type of internet connection>OK>Sign in again... let's try this, may be you can solve this problem. OR 2. Check your internet connection, may be your connection encountered problems...or i think better you should check your firewall settings. I think you should check your firewall settings. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you to sign in your yahoo messenger, check it out, may be it blocked your yahoo messenger from sign in. OR 3. Open your Internet Explorer>Go to File>Then, 'uncheck Work Offline', make sure your Internet connection is not working offline. Then, close Internet Explorer, try to sign in your yahoo messenger again. I hope these can be helpful! Try these! Good Luck! Hope it was helpful!
Jun 11, 2009 | Yahoo Messenger
Login error 81003004fo yahoo
You might have some options to fix it: firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Maybe, i think you should check your firewall settings. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you to use yahoo messenger,check it out, may be it blocked your yahoo messenger. if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren’t grayed out. Click OK and login again using the new settings. If this option doesn’t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Or other way, open your Internet Explorer>Go to File>Then, 'uncheck Work Offline', make sure your Internet connection is not working offline. Then, close Internet Explorer, try to sign in your yahoo messenger.thirdly, if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code“81003004” when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful and it works to solve your problems.. Please kindly support me.. Thank You!
Jun 10, 2009 | Yahoo Messenger
When I try to sign into Yahoo Messenger 9.0 I get this error message "Messenger encountered a connection problem. Please check the network connection and then click try again. (81003004)" I've changed my...
I cant log into my yahoo messenger
internet explorer might be offline... open iternet explorer and connect it to the internet... it worked for me
May 03, 2009 | Yahoo YHT-630 System
Yahoo messenger 81003005 error how do u fix it?
New 9.0 version: fix for sign-in issues February 5, 2009 on 1:32 pm | In 9.0 version | 32 Comments
emot_wink.jpgWe released an updated version of Yahoo! Messenger 9.0 today (9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code “81003005” when trying to sign in, this latest version should fix that problem. Even if you were experiencing a different kind of sign-in issue, we recommend installing this latest version.
Dec 19, 2008 | Yahoo Messenger
81003004 problem
go click preferences->click connect directly to the internet (again..even though it has been already chosen)-> choose your connection and connect..i guess it will work..it worked for me..try it!
Nov 02, 2008 | Microsoft Windows XP Home Edition
ibibo.com Logo
Top ibibo.com Computers & Internet Experts
David Payne
David Payne
Are you an ibibo.com Computer and Internet Expert? Answer questions, earn points and help others
