Question about Boating
I need type of motor for mercury outboard motor, I only have sn
I have a Mercury Classic 50 outboard motor sn:8298841, but the data plate is unreadable and I need more info about the motor.
    Champion:
  • 231 Answers
Good Morning Robert Please Take Photo And Post,
What Further Info Are You Looking For
Posted on May 11, 2014
SOURCE: mercury outboard over charging
Your motor is fine. It needs to put out more than 12 volts or the battery will not charge. Most alternators put out between 13 - 17 volts, so this is well within the range.
Posted on May 29, 2009
SOURCE: 9.8 hp mercury outboard shutting off in low idle speed.
My problem ended up being the spring on the reed valve being weak.But at the same time and while I had already had my carb broke down I took a can of carb cleaner to it and cleaned it. In order to replace the spring on reed valve you will have to buy a new one, but don't worry I only payed about $6.00 for mine. You may also look into replacing your primer bulb if you haven't already because may allowing air to build up in your gas line while you are basically idiling.Once you get the carb straightened out you may have to reajust it again. If I might be able to help you again you may contact me at j_speaks@yahoo.com.
Posted on Jun 16, 2009
finish line
  • 207 Answers
SOURCE: 1999 Mercury Mariner 9.9hp outboard motor
should be on the side with a lever but could you give me more info please
Posted on Jun 27, 2009
  • 302 Answers
SOURCE: How do I winterize my Mercury 115hp outboard motor
add Stabil to the gas tank and run the engine for a few minutes so it gets into the carb. Then pull the plugs and spray fogging oil into each cylinder and then turn the engine over a few times. If you are in a cold climate you should drain the lower unit in case there is water in it and then refill it with new lower unit grease. reinstall the plugs and you will be ready for winter.
Posted on Nov 01, 2009
  • 2926 Answers
SOURCE: 2000 Mercury 75 outboard 3 cylinder with 3
No spark can be attributed to two components; The stator or the trigger assembly. Even if you had a diagram (available online @ Mercury), you will still need a test harness,a DVA adapter and a meter to measure the resistance of the CDM's (capacitor discharge module) ,stator and trigger assembly. Best case fix would be the trigger, most expensive would be the stator. If you remove the flywheel, and inspect the stator, you can inspect the the coils that are coated with a white epoxy, and if one or more are bad, they sometimes leak a black resin, indicating the coil(s) have been shorted and no longer provide voltage for spark.
Posted on Jan 22, 2011
1976 mercury v-6 1750 hp outboard igot the motor and the lower end was already taken off and there isa part I never seen besides the impeller its a little housing wioth a plunger typ thing on one in
Hey Mark,
Find your engine from this list.. then continue until you find the correct parts diagram that corresponds to what you are looking for...More info would help.. serial number, ID number. any numbers on any plate..
Find Mercury Marine Outboard Motor Parts by Engine Model
Jun 09, 2017 | Mercury Boating
Where can I find a free service manual for a mercury 7.5 hp outboard
try going google and typing in--- workshop manual for mercury 7.5 hp outboard engine --- and if there is a pdf version then download it
otherwise it will not be free
Sep 24, 2016 | Boating
Where might I find a working fuel pump for a 1966 Mercury 3.9 hp outboard motor?
there is a pump for sale on e-bay --seller is western furniture (1918) used condition for $25.00 us 2 people watching it but it has a buy now tab
I found this by going google and typing in --fuel pump for mercury outboard motor 3.9 hp-- and the site is www.ebay.tv>sch>ebay-motors-
mariner is also a part of the mercury range so check for mariner 3.9 or 4 hp parts
Sep 11, 2016 | Boating
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
I need the type and info on my Mercury Classic 50 outboard motor
serial number is what you need and try looking on the starter or the switch box ( square box with lots of wires on as they have dates on also ) take pictures of engine in and outside as if decals are original it will date it as well ! take to or email your nearest dealer with all info and they date your engine no problem !
Mar 20, 2014 | Boating
Where is the thermostat on a 1993 mercury 40 hp classic outboard motor
If it has one,it will be at top of block on port side close to the top plug,cover plate held in by 3 bolts
Jan 25, 2014 | Boating
What year is my mercury outboard
What year is my Kiekhefer Mercury Outboard SN 389664, Mdl-KF-7
Jan 05, 2014 | Clymer EvinrudeJohnson Outboard Shop...
Boating Logo
111 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
