Question about Kenwood DNX570HD
Error code 3-1 when updating firmware on dnx570hd
Where do i find error code information and how do i fix it so gps works again?
Check error code 3-1
i got error code 3-1 while installing firmware update how do i get code information? gps doesn't work now either, white screen
Dec 17, 2013 | Kenwood DNX570HD
Error message?!?!
If this is a firmware update, use MyTomTom application and delete the firmware and try again.
Aug 03, 2012 | Tomtom XL 330 Car GPS Receiver
I updated my PS3 to OFW 3.55 (via USB), now i want to update the Kmeaw CFW3.55 (via USB) and get the error code 8002F997 (after 78% of PS3 copying the update). It does not work if i try the update in...
8002F997
- This error is caused by an issue with updating the PlayStation 3 firmware by USB drive. Ensure there are no problems with the USB drive. Download the firmware update to the USB drive again to ensure the firmware file is not corrupt. Try the installation of the firmware again. If all else fails, update firmware over the network.
Sep 14, 2011 | Sony Playstation 3 (PS3) Console
Webupdater crashed my etrex!!! I did everything they said and it crashed. I need this fixed for my trip up north please help!!!
never use the garmin webupdater, it is unreliable. download the previous version 3.10 firmware from http://www.tramsoft.ch/gps/garmin_etrex-venture-hc-firmware-upgrades_en.html, extract to c:\garmin, plug in your gps via usb, hold the front button in the down position until update process completes, run the updater.exe program and let it complete. You will see an error message at the end of the update process, ignore and let the garmin reboot and it should work again after that.
Jul 30, 2011 | Garmin eTrex Venture HC GPS Receiver
Distance to intersection or destination is off by 20-30 meters, how can I correct this?
Hi
connect your gps to your computer and run the garmin web updater program (free from garmin).
Make sure you have all the firmware updates as every now and again they readjust the satellite information to correct position errors.
Please dont forget to vote if you liked my answer
Many thanks
Feb 13, 2011 | Garmin nuvi 1390T Car GPS Receiver
USB port is busy error message
You don't because the magellan is having internal memory problems with corrupt files. You may try to update the firmware again but it probably will not work. Magellan Repairs are available at the jungleghost.com site.
Apr 02, 2010 | Magellan Triton 1500 GPS Receiver
Firmware Update 4.86 failed in mid-update. Maestro 4250 will not respond. Menu screen comes up but will not work.
try and run the firmware update again. make sure the its fully charged or plugged in. this usually works though sometimes it wont depending on what files are missing..they are other ways to fix this problem, but i recommend you call magellan to get it fixed. they will repair any of their gps that were rendered inoperable do to there updates.
you can go here to contact magellan support
Jul 19, 2009 | Magellan Maestro 4250 GPS
Gps screen has frozen
Have you tried firmware update for your gps .
If you have not tried it try to update the latest firmware .
By updating firmware your problem can be fixed .
Feb 24, 2009 | Navman F15
Garmin Nuvi Firmaware Update Complete, Unable to catch satellite signal
my garmin nuvi200 keeps on searches for satellite,but it couldnt able to pick up signal. A question mark over a map is always im seeing througout
Apr 06, 2008 | Garmin nuvi 350 GPS Receiver
Kenwood DNX570HD Logo
63 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
