Error code 6607 displayed on all remote controllers. AC units are still running and central controller (G50) has no malfunctions or errors. Any idea whats going on here?
  • jeff5may32 Mar 31, 2014
    Hi Aodh Carlyle, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Make and model of equipment
5 Suggested Answers
notsomot
  • 67 Answers
SOURCE: Error code E39 for Mitsubishi Heavy Industry Ceiling cassett type
E39 Fault is thermister, Mitsubishi way of saying im not going to start because there is something wrong. Generlly it is compressor fault or short of gas. Im guessing if you turned the power out. Waited twenty seconds, turn it back on. Now if you go to the outdoor part. Wait exactly 3 mins. If you hear the compressor try to start and fail then it would more then likely be your compressor if you dont hear anything and the unit faults out it will either be a board or short of gas.
Either way If the unit is under five years old get a warrenty agent out to look at it.
Sorry I couldnt tell you for sure but MHI are very vague when it comes to fault codes
Posted on Mar 05, 2009
SOURCE: E o4 error code on remote control display
HEAT AND AIR WONT TURN ON
Posted on Jan 23, 2010
hvac1960
  • 2133 Answers
SOURCE: My AC Samsung get program
Your blower motor mechanism faulty. Replace bearing or motor.
Posted on Dec 19, 2010
hvac1960
  • 2133 Answers
SOURCE: I have a new LG
Reverse or open phase. Check all 3 phases are present and correct. If correct voltage appears at all three phases, swap any two to cure the fault. Thanks. Helpful?
Posted on Feb 12, 2011
Tip
Whirlpool duet F70 and F71 error codes.
F70 and F71 are two logic board error codes that point at a communication error between the main logic module and the control pad (user interface and CCU), and between the motor control unit and central control (MCU, andd CCU that is main control module).
Repair is difficult, as motor, wiring and voltages from control modules must be tested.
Try first doing a reset, by disconnecting power cord or tripping circuit breaker and leaving power off for five minutes.
If that does not help and errors come back, then the best thing to do is calling the service number listed on the user manual.
Here extensive explanation of error codes and relative troubleshooting:
F70: CENTRAL CONTROL UNIT HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface.
1. Check for continuity of the User Interface harness.
2. Check wire harness connections to the User Interface and the Central Control Unit.
3. Replace User Interface if drum is rotating.
4. Replace Central Control Unit if drum is not moving
F71: USER INTERFACE HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit.
4. Replace Central Control Unit if drum is not moving.
To get parts and diagrams try entering the full model number in one of the websites below:
Enter the model number ..
To contact a repairer, call the number listed on the owners manual or use the Fixya directory (US only)
on Nov 05, 2010 | Whirlpool WFW8300SW
I have a front loader MHWE3000VW12 it's giving me a code F70 Ineed to know what it means
Thanks
Jul 26, 2012 | Maytag Washing Machines
Whirlpool duet getting error code F70 and F71. When hitting start button, getting a clicking sound and nothing is happening. Cannot open the washer door as it is locked with clothing inside it.
Hi jreib29,
Hope this helps.
Thank you for using FixYa.
Sep 17, 2011 | Whirlpool Kitchen Ranges
My sairon split system ac unit does nothing and comes up with e3 on the display
if split ac display shows e3 what is the solution for that problem
Dec 10, 2010 | Heating & Cooling
Error code f70
F70 Error code means Central Control Unit Heartbeat Failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface.
F71 error code meansUser Interface Heartbeat Failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit.
In both the above situations the following things are required to be checked and replaced where required:
1. Continuity of the User Interface harness.
2. Wire harness connections to the User Interface and the Central Control Unit.
Oct 04, 2010 | Whirlpool Duet WFW9550 Washer
Can anyone tell me what an F70 code is? When I push the start button it beeps at my twice and then in about 30 seconds I get a long beep and the error code F70 is on the display. Thanks in advance for your...
F70 error code indicates Central control unit heartbeat failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface.
Thank you !!
Jun 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F-70 f-71 what do they mean
Hi!
F71 error code means User Interface Heartbeat Failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 16, 2009 | Whirlpool Washing Machines
Dl codes and f11
dL= Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
-Door Lock Mechanism broken or removed from the Door
-Check Door Lock/Switch Assembly
-Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
-Door Lock/Switch Assembly Failure
F11=Serial Communication Error
Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
Check the Drive system for any worn or failed components
Check MCU
Check CCU
Check Motor
Check Wire Harness
Feb 07, 2009 | Kenmore Elite 45986 Front Load Washer
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
