Question about ASUS MeMO Pad HD 7
Black Screen no battery picture
I have a Asus Memo Pad and I tried disconnecting the battery like one of the solutions and plugging back but it still will not charge. Is there anything else I can do? The screen is completely back and nothing will come on. Thought it was the charger but it works on my cell phone.
  • ASUS Master
  • 928 Answers
If you are having this problem with the tablet, but the charger works fine with the cellphone, then mKe sure that you are using the right charger for the tablet, or it could be that the charging port in the tablet is damage, or the battery needs to be replace.
Posted on Mar 20, 2014
How do i fix my asus tablet its froozen on screen cant turn it off
Take a flat object like a butter knife, start near a corner and pop the back cover loose...then work your way around removing the cover, pull the battery out, press and hold the power button for a few seconds, put the battery back in, put the cover back on, turn the tablet back on.
Feb 17, 2015 | ASUS MeMO Pad HD 7
Can you fix a bad charging port on my asus memo pad 7
Asus seems to be having some serious issues with their memo pad and if yours is out of warranty doing it yourself may be your only option. There are a few videos on you tube about this problem so I would check them out. I had to open my Asus tablet when my cat knocked it on the floor and I had a black screen. Be aware that if you decide to fix your memo yourself that you need to be very, very careful every step of the way; take pictures, write notes...whatever you need. Good luck!
Aug 05, 2014 | ASUS MeMO Pad ME172V-A1-WH 7" 16 GB Tablet...
Asus MeMO Pad HD 7 won't turn on or charge.
Ah ASUS. I have a Memo 10. Had the same problem when it was 6 days new. Asus has a UI that is bad.
1. First try to charge via USB to your computer. If you get any result good, leave it a bit.
2. Leave it plugged in and see if it will turn on. If you can get it to turn on ... do this.
3. Find the back up and restore/factory reset. Back up your data, pics, music. etc.
4. Do a factory reset... it will say everything of yours will be delted. Proceed.
5. Restart the tablet.
6. Go into settings and TURN OFF Asus's UI. On my Memo 10, under settings is a menu called "Asus Customized settings" in the sub-menu turn OFF "Use ASUS Quick Setting" yours may say something a bit different.
7. Restart. The look will be different but no worries. On the upper right see if your tablet it charging. It will be a battery with green and black and a lightening bolt in it. If it is charging try your wall wart charger.
Jul 20, 2014 | ASUS MeMO Pad HD 7
Asus Memo Pad HD 7 won't turn on or charge.
1. how old is your tablet 2. have you tried another charger such as a phone charger. My blackberry charger works fine for my tablet. Also with your tablet you should have had a usb cable that connected from mini usb to the asus plug in transformer.
Tablet will not charge or come on.
I did this with my Asus memo pad 7 HD and it worked. http://www.youtube.com/watch?v=PXcQgpISSi8
The difference is only in removing the back cover. Use your nails to pop the cover to prevent damage. Do not use knife. Unplug the battery for 15 minutes than plug back in and pop the rear cover back on. After plugging the charger you should have the battery symbol on the screen. Then leave on the charger until fully charged.
Apr 01, 2014 | ASUS MeMO Pad HD 7
Bypass screen lock asus MeMO pad
check your setting memo pad... uncheck automatic update...
Mar 13, 2014 | ASUS MeMo Pad Smart 10
Asus Memo Pad 7 will not turn on
It did work for a while? I've had occasions where I plugged in my tablet but it didn't charge because the plug wasn't seated correctly. Also I discovered it only worked with one of the cables I have even though any mini USB cable will fit. Do you have another cable you can try to plug into the unit
Jan 03, 2014 | ASUS MeMO Pad HD 7
Will not turn on
check the voly out in you vcd adapter if this exist go to open you pad and rebulding soldering the conector volt in and then ready you pad work again please vote
Dec 03, 2013 | ASUS MeMO Pad HD 7
Turn off demo mode on asus memo pad
If it's the issue we had, that is an asus video clip plays over and over when the tablet isn't used, I found the solution. It's in fact a screesaver! so go to ASUS apps, and click screensaver, and deselect the screensaver check box.
Cheers,
Jeff
Oct 26, 2013 | ASUS MeMo Pad Smart 10
ASUS MeMO Pad HD 7 Logo
242 people viewed this question
Top ASUS Tablets & eReaders Experts
Alun Cox
k24674
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
