Question about Dishwashers
Miele heating element
I have the above dishwashing machine and need a new heating element and have been checking out new/used elements for sale on the web. There seems to be at least three different elements for the G590SC listed as follows: 1) Element (referred to as the "Outermost Heating Element") - 2000W/230V. 2) Element (referred to as the "Innermost Heating Element"- 2400W/400V dishwasher. 3) 2700W element. In my case, the heating element I need to replace is at the bottom of the dishwasher. It runs around the bottom of the machine underneath the spinning water sprayer. If it helps, I live in Toronto, Canada so maybe the electric specs are relevant. How do I know which element suits my dishwasher? Could you please let me know. Thanks,
  • 1 more comment
  • John Eckert
    John Eckert Mar 21, 2014
    Thanks. Just to be clear though, my element is burnt and you can see the burnout right on the element. The repairman told me this is why the machine won't stop running as it gets stuck somewhere in the cycle. My user manual states the power supply as 120V, 60 Hz, 1-phase, the rated load is 1.5 kW and the fuse rating is 15A. My question is which replacement element (and maybe there is more than one) will fix this problem? Thanks again.
  • John Eckert
    Thanks for the manual. I have been searching like mad to find someone in NA who would have spare Miele parts, but am incredibly frustrated because I can't seem to find anyone. I am sure this cannot be the case, however. Any advice as to where to go? Somebody must be collecting parts! Thanks,
  • veenstrajim Mar 23, 2014
    john i spent 4 hours searching for just the part - but i did find out that bosch and miele have compatible part - hope this helps - if you have a part number your search takes less time
  • 24 Answers
Sorry - may seem odd - but your hot water tank is set to 120 or higher yes ? so why are you re-heating you water? - if you want to know you need the 2000w /230v - but really turn the re heat off - at 120 you kill the bacteria and will save $$
Posted on Mar 20, 2014
  • veenstrajim Mar 21, 2014
    sorry - you are correct dishwashers here are 120v - so niether will work you will have to order one - good luck on that - miele dw parts are not easy to find on line - i did find a teck manual for youhttp://www.mieleservice.com/techservice_... - i thought i saw a test/reboot in it
4 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: How is element removed from Miele Dishwasher
Procedure to remove element :)
http://www.acmehowto.com/howto/appliance/dishwasher/repair/heatingelement.php
Thanks.
Posted on Jan 06, 2009
SOURCE: Miele G661 Dishwasher heating element
Loosen element-retaining bolt plus clips in dishwash chamber. Upend machine and take base off (held by four crosshead screws). Disconnect spade connectors from end of element and gently tap/push old rubber block through. Element will drop out with retaining rubber.
Hautebrian.
Posted on Jan 21, 2010
  • 177 Answers
SOURCE: Miele dishwasher not heating
hi,
you would have to turn the unit on it's side and remove the bottom plate and check with a multi meter the resistance of the heating element to see if the heating element is defective. i doubt the dishwashing liquid caused a fault other than causing the unit to over sud and spill water into the base. You could remove the panel under the door and have a look and see if you have flooded the base. if you have a float switch in the base (white polystyrene disc and switch) this will stop the unit from working as well. dry up any water and try it again. hope this helps and don't use the dishwashing liquid in the unit.
Posted on Jan 22, 2010
Does the Miele G665 dishwashers have a heat element as no heat is coming from my dishwasher
If it like other Mieles, it has an element to heat water if required to reach cleaning temperature, but does not have a drying element. Even then, it should give off some heat in the drying cycle and be hot after finishing.
Nov 17, 2014 | Miele 24 in. G665 Built-in Dishwasher
My miele dishwaher is not heating the water thus not wahsing the dishes properly
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Apr 26, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
Not drying at end of cleaning cycle
heatman101
Apr 18, 2011 | Miele Optima G2470SCVi Built-in Dishwasher
On normal rinse aid the dishes do not dry
heatman101
Apr 16, 2011 | Miele Optima G2470SCVi Built-in Dishwasher
Miele Dishwasher - Not cleaning
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
heatman101
xxz
Apr 26, 2010 | Miele 24 in. G892SCU Plus Built-in...
hi,
Jan 05, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Miele G572 is not cleaning dishes correctly, I have pulled all arms off and cleaned, cleaned filters. Powder is not been flushed completely from door. Does the machine require servicing?
heatman101
aqggffb
Jul 04, 2009 | Miele Premier-Plus Built-in Dishwasher
Hautebrian.
Mar 06, 2009 | Miele 24 in. G656SCi Plus SS Built-in...
Miele G892 SC dishwasher not heating/cycle won't stop
Miele have cold inlet only. Either element is open circuit, or the relay that switches the element has failed. My money would be on the element first, then the relay. The machine will sit in that mode forever as it is waiting for the temperature of the water to reach a certain temp before telling the electronic unit to move to the next part of the wash. If you need assistance in how to test & how to get to these parts just let me know. But you will need an ohm meter to test the element. Regards
Aug 20, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Dishwashers Logo
119 people viewed this question
Top Dishwashers Experts
Owen Barnes
