SOURCE: Dryer heats but no condensing of steam
The cold water feeds for condenser cooling and for wash cycle drum fill are controlled by separate solenoid valves (manifolded together at the cold water inlet hose union). When the solenoid on my condenser coolant valve failed a couple of years back, I got symptoms like yours. A new pair of valves isn't expensive to buy and is a trivial job to fit. If this is what has been happening, suggest you also inspect the insides of your dryer fan and of the pump - neither of mine took really kindly to having been cooked for hours on end. Alastair.
SOURCE: Oven will work for about half an hour and then turns itself off.
it sounds like the thermal cut out is broken can be replaced quiet easy need to disconnect oven from mains remove outer cover and has four wires two blue two white all with spade connectors can be bought from e spares on the web
SOURCE: Baumatic oven not heating up
Hi Damien,
Many thanks for your help - unfortunalty have tried this and it dosent work... BOO
Thanks,
Chris
SOURCE: Intermitten Heat up
I would like to thank the ones who responded to giving me a 'hand' in repairing my dryer. I did like you said & changed out the coils & now the dryer is working like it should.
