Question about Coffee Makers & Espresso Machines
Ventilate Issue Ariston MCA 16/HA
Machine keeps asking to ventilate. When push water button to ventilate no water comes out. Don't no what to do next? Tried resetting to factory settings as well. Did not work.
SOURCE: trying to ventilate and hot water not flushing through on button 26
Before you press water button to vent you need to restore to factory settings.
First press menu (far right button) then toggle to restore factory settings (using far left button), press menu button then far right again until yes comes up, then press menu button. Press esc button (3rd from left), machine should now be back to normal. Then press water button (3rd from right) and turn steam knob to vent until free water is coming through.
This is the only way I could get mine to work!
Posted on Oct 23, 2008
  • 1089 Answers
SOURCE: Machine Is Stuck on "VENTILATE" Command
Sounds like you all have the same problem. Your flow meter has been obstructed with a small chip of coffee bean that got into your water tank receptacle when your tank was off. You need to remove the top or back depending on your machine and remove the flow meter. It twist apart. The intake is a small opening and that is creates the jet of water that spins the flow meter. If it gets obstructed the meter doesn't spin and you will get the ventilate message.
Posted on May 23, 2009
  • 1089 Answers
SOURCE: ventilate warning came on and machine no longer works.
Hi The first thing that I would check is the tip of the steam wand for a plug. If that is clear then I would suspect a clogged flow meter. If you can get the flow meter out it twists apart and don't loose the parts and the dot on the turbine goes up. Clean out the small opening on the bottom pipes where the hoses attach. Look inside and make sure that they are clear before reassembling.
Posted on Jun 14, 2009
  • 109 Answers
SOURCE: The ventilate button is not working
There is no ventilate button.
You will need to open the steam valve on the side of the unit.
Ensure your milk frother is not blocked.
Posted on Feb 22, 2010
espressonist
  • 1711 Answers
SOURCE: Screen displays :ventilate: having used for year,
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out.
Good luck
Posted on Jul 01, 2010
Testimonial: "Thanks for the advice. I have tried this but it did not work. In deed, the "Ventilate" message came back even during the machine was running the hot water. "
Ventilate problem on gaggia titanium coffee
You need to push the hot water button on the machines panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
May 27, 2010 | Gaggia Titanium Espresso Machine
Gaggia Syncrony "ventilate"
You need to push the hot water button on the machine panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
May 04, 2010 | Gaggia Syncrony Espresso Machine
My gaggia titanium keeps coming up with ventilate in the display have cleaned the whole machine out made no difference
Apr 19, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
How to ventilate a saeco cafe royalecoffee machine
Hi
There is a water button you need to push. It has a water drop on it. This will clear the ventilate message.
Jan 22, 2010 | Saeco Royal Professional Espresso Machine
Machine says ventilate
When it says to ventilate, it is asking you to prime the pump. Put a cup under the panarello wand ( the steamer/frother) to catch the discharged water and press the hot water button (upper left button on my machine). Wait until air stops coming out with the water, usually 3-5 ounces, and then press the hot water button again.
You machine is now ventilated (primed) and should be ready to go.
Jan 11, 2009 | Saeco Royal Digital Plus Coffee...
My coffee machine says "ventilate"
When it says to ventilate, it is asking you to prime the pump. Put acup under the panarello wand ( the steamer/frother) to catch thedischarged water and press the hot water button (upper left button onmy machine). Wait until air stops coming out with the water, usually3-5 ounces, and then press the hot water button again.
Jan 05, 2009 | Saeco Royal Digital Plus Coffee...
Ventilate sign on my coffee machine
Dec 15, 2008 | Saeco Royal Digital Plus Coffee...
Ventilate!
Can you get water out of the machine by pushing the hot water button?
This is how you would remove the ventilate message in the first place, but if no water comes out then the machines electro-valve is not opening and you will not be able to remove the ventilate message. You will have to get the machine serviced.
I would also give descaling the machine a try before servicing the machine.
You can also find the user manual for the royal professional on our website: http://www.cerinicoffee.com/Saeco_User_manuals_free.asp
We are a Authorized Saeco Service Center based out of New York.
For Saeco Parts and Cleaning supplies visit www.CeriniCoffee.com
May 29, 2008 | Saeco Royal Professional Espresso Machine
My coffee machine says decalcify ventilate
For ventilate:
For decalcify:
Recommend downloading and following these directions.
http://www.partsguru.com/user/Safe%20Descaling%20method.pdf
Apr 27, 2008 | Saeco Royal Digital Plus Coffee...
Ventilate
I fixed my ventilate problem! After 2 days of utter frustration and pushing many buttons, I read another guest comment about resetting to factory settings. Push the up button under the small coffee icon. It should say factory setting with the asterick next to it. Push OK. Then push "yes" for factory settings. Then my machine started working again! Hallelujah! It erased my personal coffee cup setting, but who cares.
Big thanks to the person who posted their solution on Dec. 2007.
Jun 11, 2007 | Gaggia Titanium Espresso Machine
Coffee Makers & Espresso Machines Logo
212 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
