Question about Dyson Washing Machines
Hi there i have a dc07 that was working fine and then it had a funny burning smell and a lack of suction so i turned it off and emptied the canister cleaned all the roller brushes and filters made sure all the pipes are free from debris and clear i did notice a little water in the base of the u bend and on the roller but it was only a little could someone tell me what has happened it wont power up now at all ......i have no idea what it could be , thanks in advance
  • Official Brand Answer
  • 2,572 Answers
Hi Carl, it's Jack at Dyson.
From what you've described it sounds like this could be a motor issue, particularly if your vacuum has picked up water in use. If your machine has made a burning smell, please do not attempt to use it again and contact our experts directly so we can take some further details.
You can reach us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Posted on Mar 21, 2014
SOURCE: Bosch wlf2260
clean the detergent tray especially the part for the conditioner. on some bosch the rinse water valve is seperate uie different valve for water for main wsash. check valve is not open circuit resistance should be about 3.8k. could also be due to low water pressure
Posted on Mar 19, 2007
  • 5 Answers
I had a similar problem and found that the holes above the softner section were blocked by black mold. All I had to do was push a small wire into the holes to clear the blockage
Posted on May 16, 2007
  • 1294 Answers
SOURCE: Whirlpool AWM6120 Front Load Washer
Cleaning depends on use. 8 years is a bit over the top! When your water does not drain, check the outlet filter first, then the pipe from below the tub to the filter. Your washer wont spin 'cause the pump/filter is blocked.
Posted on May 21, 2007
Timon90
  • 126 Answers
SOURCE: Zanussi IZ161S Water filling problem
Check the drainpump. It may be clogged with lint or something, or blocked.
Posted on Jan 25, 2008
SOURCE: Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Posted on Feb 05, 2008
Loss of suction
Did you check to make sure the rotating brush is working? Did you remove the removable channels to check for obstructions? Also, is the canister empty?
May 15, 2012 | Dyson DC07 Animal Bagless Upright Cyclonic...
My vacuum was working fine, then started to smell a little funny like something was burning. Turned it off. Now when you turn it on it will run for a few minutes and then shuts off, like something is...
The smell is usually the fan belt. When the brush is stuck in place, the belt spins and burns. Check to see if the brush is free to spin. If the Belt is burnt, it needs to be replaced.
Jan 31, 2018 | Kenmore 28015 Bagged Canister Vacuum
Canister doesn't rotate; debris blows back out.
Check for clogs. That could be the problem with the mess getting spread around and not being sucked up.
Here's a fix that could help you with your upright issue.
Mar 21, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 keeps cutting out and smells of
does it smell like an electrical burning smell? sounds like your motor has went bad.
Mar 06, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuum sounds funny and doesn't have any suction.
I love the Dyson (DC07), but after 7 or 8 years it lost suction and needed some attention beyond filter cleaning. After much online research I found the few bits of advice that for me were the holy grail. After all of the standard stuff, clear clogs, clean filters etc..... In this order: 1) Remove & empty the canister, ***important****-leave the canister bottom lid open. 2) remove the three star screws at the top of the canister. It'll take a bit of pressure to pull the top up, there's a rubber seal. When you pull it up there will be a rod running down into the canister, leave it be, just pull up the top high enough to clear out any debris. 3) Put the top back on aligning the screws, when you lower it make sure the bottom of the rod engages with the hole at the bottom center of the canister, this is why you left the bottom lid open. Put the three star screws back in. 4) Turn the canister upside down, lid open, and keeping in mind this is thin plastic, gently tug upwards on the four fins that surround the bottom rubber seal. This part is held in by friction, so work your way around the four fins gently pulling until you work the ring they're connected to free. This will give you access to the inside of the canister. 5) remove the round perforated section by tugging upwards on it, set it aside with the fin part. 6) Take the canister to a laundry tub or large sink and holding it bottom up fill it with hot/warm water. Grasping the center section shake it vigorously and turn it upside down while shaking and a bunch of sh*t will come out. Repeat several times. 7) Dry thoroughly, you might use a hairdryer held to the center tube, but only if you can switch off the heat and use air only. Make sure its 200% dry, water will kill your machine 8) clean and replace the round perforated section 9) replace the fin section, I'd suggest pulling the round rubber part off of the fin part and setting it in place on the canister first, then follow with the plastic fin part. If you don't do it this way the rubber won't seat properly and the bottom lid won't close. 10) Close the lid, replace the canister, and staaaaaart suckin like it's brand new.
Jan 18, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Lack of suction
you should check the round filter casing on theleft and the right side of machine to make sure they are snaped in right also the clear hose on the bottom sumtimes comes unhooked.
Dec 25, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Slight burning smell when dc07 is in use
Sounds like your belt can either be rubbing against something or its stretched out. Either way you should check into getting the belt changed.
Aug 11, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
BURNING SMELL
Hi.
Try this site http://dysonmanuals.llc.nu/ has service manuals covering removing the Dc07 motor.
Aug 13, 2008 | Dyson DC07 All Floors Bagless Upright...
Washing Machines Logo
32 people viewed this question
Top Dyson Washing Machines Experts
Starnley Johnwells
Starnley Johnwells
Gerry Harvey
Gerry Harvey
Are you a Dyson Washing Machine Expert? Answer questions, earn points and help others
