Question about Kitchen Appliances - Others
Rational oven Hi, my oven, a rational CD 63 turns off after a half an hour on dry heat. we turn it on and off and it comes on again with the same result your advice is appreciated
zeusfaber
  • 247 Answers
SOURCE: Dryer heats but no condensing of steam
The cold water feeds for condenser cooling and for wash cycle drum fill are controlled by separate solenoid valves (manifolded together at the cold water inlet hose union). When the solenoid on my condenser coolant valve failed a couple of years back, I got symptoms like yours. A new pair of valves isn't expensive to buy and is a trivial job to fit. If this is what has been happening, suggest you also inspect the insides of your dryer fan and of the pump - neither of mine took really kindly to having been cooked for hours on end. Alastair.
Posted on Jan 31, 2007
SOURCE: Oven will work for about half an hour and then turns itself off.
it sounds like the thermal cut out is broken can be replaced quiet easy need to disconnect oven from mains remove outer cover and has four wires two blue two white all with spade connectors can be bought from e spares on the web
Posted on Dec 08, 2007
SOURCE: Baumatic oven not heating up
Hi Damien,
Many thanks for your help - unfortunalty have tried this and it dosent work... BOO
Thanks,
Chris
Posted on Mar 29, 2008
SOURCE: Intermitten Heat up
I would like to thank the ones who responded to giving me a 'hand' in repairing my dryer. I did like you said & changed out the coils & now the dryer is working like it should.
Posted on Apr 12, 2008
SOURCE: Dishwasher won't unlock
MY GE SPACEMAKER MICROWAVE IS LOCKED HOW TO UN LOCK
Posted on Jul 02, 2008
Cleaned my fan oven . try to turn it on the fan will come on but try to turn it up slowly for heat it cuts all the electric off . same with the grill
Could be that water got in some ware ware it shorts to ground and the earth leakage are tripped. I had a similar problem with a microwave oven. You can leave it to dry for a day or two? I left the microwave in the sun for a few hours.
May 10, 2011 | Microwave Ovens
Our brand new kitchen aid oven will blow hot air for up to a half hour after it has been turned off. This seems unusually long- what is the expected time of cooling off?
That depends on the ambient temperature in the room..if your room is fairly warm you can expect it to take longer then if the room is cool...
I would say though that 1/2 hour is pretty normal...it is good to get the unit cooled down, the less time it is warm the longer it will last... heat kills ovens...even though they are made to take heat...
heatman101
Apr 24, 2010 | Ovens
Baumatic oven not heating up. Grill and fan fine.
if it is the b180, the answer (having just fixed this) is really simple.
The coily bit is the oven element - it will have gone. A new one from eBay cost me about 6 quid.
[WHEN IT ARRIVES !]
Turn the power off.
Inside the oven use a philips screwdriver to remove the 4 screws (KEEP THEM !)
You will see a coily thing and a fan.
You unscrew 3 more screws (2 on the left and 1 on the right).
(KEEP THESE TOO!)
now ... bit tricky, have the new one inside the oven and take each wire off one at a time and put it on the new element.
Screw it back on but DONT put the last panel back in.
Turn the oven on maximum for about 2 minutes and see it glow red.
Turn the oven off. Make a cup of tea and have a couple of biscuits while admiring how good you are and waiting for the element to cool down!!!
Put the final panel back in place. Whole thing (including a cup of tea) takes about half an hour.
Jan 27, 2010 | Baumatic B180 Electric Single Oven
Oven heats very slowly
If your top burners work ok, regulator should be ok. Majority of times the fail part in the oven is the ignitor...turn oven on and check for a flame after 10 mins. small flame could mean a bad safety valve.
Jun 09, 2009 | Maytag MGR5870 Gas Kitchen Range
Oven and broiler: no heat
Flipped the breaker switch! Although we had looked at the breaker first thing, and it was not flipped off, plus everything else on the range was working: we found out it is actually a double breaker, with one half controlling just the oven, and it can be just partially flipped and you don't notice it. So as soon as you toggle it off and on again, you are back in full power.
Apr 08, 2009 | Kenmore Kitchen Ranges
When my LCD TV has been off for an hour or so upon turning it back on there is a low humming sound and only the sound comes on and then after half an hour or so and turning it off and on 20 times the...
plse dont move when there are working, inside them are components which gets heat, vibration causes separation or desoldering them from board.(dry joints)
it may be coming from cables having dry joints take your set for repair.
Mar 26, 2009 | Televison & Video
DRYER RUNS ABOUT 15 MINUTES, HEAT WORKS,MAKES NOISE AND STOPS
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
gdhi64
Feb 13, 2009 | Whirlpool LGR5636L Gas Dryer
Furnace
change indoor sirkit board.
Feb 17, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Nov 04, 2007 | AEG B4101-4 Electric Single Oven
Kitchen Appliances - Others Logo
44 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
